Fender Turbo Mount #2247828
02/05/17 04:26 PM
02/05/17 04:26 PM
Mesa , Az
Jambbii Offline OP
Jambbii  Offline OP
Mesa , Az
Anyone mount their turbos in their fenders? I am trying to hack the least amount of inner fender out of my challenger. I don't have much room with a gen II hemi an e body.
Thanks,
Josh
70 Challenger
1960 Town Wagon P Pump 24v cummins project
06 Mega 3500 Drw 2wd
12 Durango R/T
18 Power Wagon
67 A100
Re: Fender Turbo Mount [Re: Jambbii] #2248013
02/05/17 08:51 PM
02/05/17 08:51 PM
Do you think the fenders will hold it for very long before cracking around the mounting bolts shruggy work tsk twocents
Re: Fender Turbo Mount [Re: Cab_Burge] #2248258
02/06/17 02:17 AM
02/06/17 02:17 AM
Mesa , Az
Jambbii Offline OP
Jambbii  Offline OP
Mesa , Az
Of course not. Appropriate mounts will be built.
70 Challenger
12 Durango R/T
18 Power Wagon
67 A100
Re: Fender Turbo Mount [Re: Jambbii] #2248407
02/06/17 01:00 PM
02/06/17 01:00 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Your question was not clear to me at first, so your question really centers on are the inner fenders robust enough to survive if you relieve them enough, to allow room for an engine mounted turbo, correct?
Re: Fender Turbo Mount [Re: Jambbii] #2248551
02/06/17 03:57 PM
02/06/17 03:57 PM
Spencer NY
killermopar Offline
killermopar  Offline
Spencer NY
I've thought about that too. Plates and fabricated mounts would do wonders. I think heat and airflow would be the question. Anybody know?
Re: Fender Turbo Mount [Re: jcc] #2248709
02/06/17 09:05 PM
02/06/17 09:05 PM
Mesa , Az
Jambbii Offline OP
Jambbii  Offline OP
Mesa , Az
I wanted to mount them behind (outside behind the tires) the fender so I have room in the engine bay. I have a cage to to build mounts off of as well. I have seen them on vettes and other brand x cars just never on a mopar.
70 Challenger
12 Durango R/T
18 Power Wagon
67 A100
Re: Fender Turbo Mount [Re: Jambbii] #2248847
02/07/17 12:07 AM
02/07/17 12:07 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Seems with a cage and front down bars you have a lot more options retaining some front end stiffness lost by losing some front end inner fender material. However, it seems not very popular? from my readings to remote(?) mount a turbo vs engine mount, due to expansion issues, longer hot side, etc. if I understand your solution. work
Re: Fender Turbo Mount [Re: Jambbii] #2248960
02/07/17 03:59 AM
02/07/17 03:59 AM
If your working on a E body Challenger(1970-74) I would look at mounting them up near the radiator core support on the front sub frames so the exhaust pipe would exit the engine compartment in front of the front tires, not behind them work shruggy Closer to the inter cooler mounting also if it, intercooler, is mounted in front of the radiator shruggy
If the intercooler will be air to liquid mounted in the car then the turbo mounted further back will be closer to the intercooler shruggy
Re: Fender Turbo Mount [Re: Jambbii] #2248979
02/07/17 09:03 AM
02/07/17 09:03 AM
Mo.
racerx Offline
racerx  Offline
Mo.
^^^Also you probably can use the extra weight on the frontend to keep it down^^^
Re: Fender Turbo Mount [Re: Jambbii] #2249025
02/07/17 12:19 PM
02/07/17 12:19 PM
IL
furious70 Offline
furious70  Offline
IL
You want to mount the turbos to the body or frame instead of the engine? Unless you have solid mounted eng/trans and absolutely 0 movement you'll have trouble, even with flex pipes I would think. I'll also say my home made kit on my Fury needs to 'move' around quite a bit when installing/removing and definitely moves around when operating - but it's all hung off the engine (brackets and all)
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Fender Turbo Mount [Re: Jambbii] #2249086
02/07/17 02:01 PM
02/07/17 02:01 PM
Nampa, Idaho
Moparmatts72 Offline
Nampa, Idaho
Can always do a rear mount, or if you can fit them mount them low by the Trans like the kit for the new chargers and challengers.
