Fender Turbo Mount
#2247828
02/05/17 04:26 PM
02/05/17 04:26 PM
Posts: 554 Mesa , Az
Jambbii
Mesa , Az
Anyone mount their turbos in their fenders? I am trying to hack the least amount of inner fender out of my challenger. I don't have much room with a gen II hemi an e body.
Thanks,
Josh
70 Challenger 1960 Town Wagon P Pump 24v cummins project 06 Mega 3500 Drw 2wd 12 Durango R/T 18 Power Wagon 67 A100
Re: Fender Turbo Mount
[Re: Cab_Burge]
#2248258
02/06/17 02:17 AM
02/06/17 02:17 AM
Jambbii
Mesa , Az
Of course not. Appropriate mounts will be built.
[Re: Jambbii]
#2248407
02/06/17 01:00 PM
02/06/17 01:00 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Of course not. Appropriate mounts will be built. Your question was not clear to me at first, so your question really centers on are the inner fenders robust enough to survive if you relieve them enough, to allow room for an engine mounted turbo, correct?
[Re: jcc]
#2248709
02/06/17 09:05 PM
02/06/17 09:05 PM
Jambbii
Mesa , Az
Of course not. Appropriate mounts will be built. Your question was not clear to me at first, so your question really centers on are the inner fenders robust enough to survive if you relieve them enough, to allow room for an engine mounted turbo, correct? I wanted to mount them behind (outside behind the tires) the fender so I have room in the engine bay. I have a cage to to build mounts off of as well. I have seen them on vettes and other brand x cars just never on a mopar.
[Re: Jambbii]
#2249025
02/07/17 12:19 PM
02/07/17 12:19 PM
Posts: 2,255 IL
furious70
IL
You want to mount the turbos to the body or frame instead of the engine? Unless you have solid mounted eng/trans and absolutely 0 movement you'll have trouble, even with flex pipes I would think. I'll also say my home made kit on my Fury needs to 'move' around quite a bit when installing/removing and definitely moves around when operating - but it's all hung off the engine (brackets and all)
70 Sport Fury 68 Charger 69 Coronet 72 RR
