Fuel Cell Leak Help #2247628
02/05/17 11:31 AM
02/05/17 11:31 AM
Bradenton, FL
Benforsp Offline OP
Benforsp  Offline OP
Bradenton, FL
I've found a pin hole size leak on my fuel cell. It's an aluminum cell. I prefer not to pull it out and clean it etc to have it welded. Any ideas? The fuel system is a return style with a vent so there isn't pressure on the tank. Any one had success with an epoxy sealer?
Thanks!
Re: Fuel Cell Leak Help [Re: Benforsp] #2247634
02/05/17 11:49 AM
02/05/17 11:49 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
May be able to peen the leak shut with a hammer and punch?
Re: Fuel Cell Leak Help [Re: Challenger 1] #2247667
02/05/17 12:43 PM
02/05/17 12:43 PM
okla.
sam64 Offline
sam64  Offline
okla.
sand it,clean it,JB weld it.I built up a spot on a 727 case and drilled and tapped it for 1/8 pipe plug to adjust line pressure.been like that 7 years.
Re: Fuel Cell Leak Help [Re: Benforsp] #2247698
02/05/17 01:38 PM
02/05/17 01:38 PM
Bradenton, FL
Benforsp Offline OP
Benforsp  Offline OP
Bradenton, FL
I see JB weld has one specifically for fuel tanks. Maybe I will give that a try. Do you think I should do it on the inside,outside or both?
Re: Fuel Cell Leak Help [Re: Benforsp] #2247743
02/05/17 02:48 PM
02/05/17 02:48 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I would scuff up the area on the outside and apply from there. I don't think that the JB weld should sit in the fuel if it doesn't have to.
[image][/image]
Re: Fuel Cell Leak Help [Re: Benforsp] #2247822
02/05/17 04:15 PM
02/05/17 04:15 PM
in front of the computer
8
80arrow Offline
80arrow  Offline
What about a small screw and gasket type washer? Or drain it and use a small bolt and nut and a rubber washer?
Re: Fuel Cell Leak Help [Re: Benforsp] #2248006
02/05/17 08:42 PM
02/05/17 08:42 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
There is a 2 part putty type gas tank epoxy that works very well. I think Permatex makes it,any of the auto parts stores will have it.
Nautilus Racing-
Re: Fuel Cell Leak Help [Re: Benforsp] #2248012
02/05/17 08:49 PM
02/05/17 08:49 PM
Cab_Burge Online work
Cab_Burge  Online Work
I used a two part five minute epoxy on the carb. on my old airplane to fix a crack in the upper body to get home from a FFA curtesy inspection in 1992, it was still on there working good in 2007 when it got total from hail damage on the ground shruggy
I now use it all the time to work inside or outsides of carbs. where needed up
Re: Fuel Cell Leak Help [Re: Cab_Burge] #2248353
02/06/17 11:50 AM
02/06/17 11:50 AM
moparx Offline
moparx  Offline
cab, what is the name of that epoxy if you don't mind me asking ?
beer
Re: Fuel Cell Leak Help [Re: Benforsp] #2248393
02/06/17 12:41 PM
02/06/17 12:41 PM
CJD AUTOMOTIVE Offline
Call and have Fuel Safe make a bladder to fit inside it. Safer and fixes the issue.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
www.CJDAUTOMOTIVE.com
904-400-1802
"I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
Re: Fuel Cell Leak Help [Re: Benforsp] #2248452
02/06/17 01:59 PM
02/06/17 01:59 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Where is the leak.. if its in a weld you can
try the epoxy stuff... or have it welded so
its right... if its not near a weld I would
look closer as to whats going on
wave
