5 speed auto issue in a 2004 Dodge 1500 #2246259
02/03/17 12:39 AM
02/03/17 12:39 AM
Niwot, CO Formerly denn...
dynorad Offline OP
dynorad  Offline OP
I had my transmission serviced with new filters and fluid. The mechanic also replaced a solenoid to resolve a code. Now the transmission freewheels for a period of time (2-5 sec or so) after shifting from reverse to drive. Does it hot and cold, no matter how long the truck has been running.
He's quoted me $4K (about half the value of the truck) to fix it.
Is there any inside knowledge to be had about the described symptom and transmission, which I believe is the 545RFE?
Re: 5 speed auto issue in a 2004 Dodge 1500 [Re: dynorad] #2246543
02/03/17 02:47 PM
02/03/17 02:47 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
It worked fine before the service (besides the code)? I know some guys have had the push on filter fall off and then have nothing in any gear, but I'd suspect your "new" solenoid pack to be the problem. Is it new Mopar OEM stuff or a rebuilt jobber?
Re: 5 speed auto issue in a 2004 Dodge 1500 [Re: dynorad] #2246557
02/03/17 03:03 PM
02/03/17 03:03 PM
kalispell montana
jwilson 61 Offline
jwilson 61  Offline
kalispell montana
did they perform a quick learn after replacement of solenoid pack? if not that could be an issue.
70 cuda 440 6bbl Auto with a dana 60
68 road runner QQ1 383 auto
1970 6 barrel 4 speed Superbird FY1 number matching
15 Challenger 6.4 SRT pearl White 6 Speed
72 Cuda 440 5 speed
71 Road Runner 440 4 speed
Re: 5 speed auto issue in a 2004 Dodge 1500 [Re: WO23Coronet] #2246558
02/03/17 03:04 PM
02/03/17 03:04 PM
God's Country Maryland
GODSCOUNTRY340 Offline
Almost sounds like he didn't replace the seal where the sump filter pushes in. Some filters come with the new seal, cheaper ones don't. Did he replace both filters?
Re: 5 speed auto issue in a 2004 Dodge 1500 [Re: GODSCOUNTRY340] #2247100
02/04/17 11:35 AM
02/04/17 11:35 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
This I agree with as I have seen many not get the sump filter all the way in and it sucks in air. And did he replace both filters ? My question is did it do this before he worked on it and how did it act when it had the code in it before he replaced the solenoid pack ? Ron
Re: 5 speed auto issue in a 2004 Dodge 1500 [Re: dynorad] #2247164
02/04/17 01:42 PM
02/04/17 01:42 PM
dynorad Offline OP
dynorad  Offline OP
The only symptom I had before the service was occasional sluggish starts from a stop.
I asked him to replace both filters. He mentioned something about learning but I'm not up on the details about that. I'm not sure about the solenoid, I'll have to check my receipt.
Is this something I can reasonably drop the pan to do myself? I have run out of trust with this mechanic.
Re: 5 speed auto issue in a 2004 Dodge 1500 [Re: dynorad] #2247183
02/04/17 02:27 PM
02/04/17 02:27 PM
He most likely didn't get the filter tube pushed through the seal, I'd say he just got it up against it and then installed the bolt to hold it up. There is only one small bolt that holds the filter in place. Drop the pan (messy job) and remove the bolt holding the sump filter, it will drop down as you remove it. If he correctly installed the filter you should have to pull and twist the filter to get it to come down out from the seal, if it drops right out it wasn't installed into the seal. If it were mine I'd buy both new filters from Napa with the seal and replace them both while you're in there.
Re: 5 speed auto issue in a 2004 Dodge 1500 [Re: dynorad] #2247225
02/04/17 03:55 PM
02/04/17 03:55 PM
dynorad Offline OP
dynorad  Offline OP
The receipt doesn't specify the solenoid, but the filters are Pro-King.
Re: 5 speed auto issue in a 2004 Dodge 1500 [Re: dynorad] #2247462
02/04/17 11:47 PM
02/04/17 11:47 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
Another point to remember on the RFE transmission is that the sump filter is specific to the driveline type 2wd vs 4wd. IDK if its possible to get the wrong filter and the pan will still install.
