Re: 5 speed auto issue in a 2004 Dodge 1500
[Re: dynorad]
#2246557
02/03/17 03:03 PM
02/03/17 03:03 PM
Posts: 125 kalispell montana
jwilson 61
kalispell montana
did they perform a quick learn after replacement of solenoid pack? if not that could be an issue.
70 cuda 440 6bbl Auto with a dana 60 68 road runner QQ1 383 auto 1970 6 barrel 4 speed Superbird FY1 number matching 15 Challenger 6.4 SRT pearl White 6 Speed 72 Cuda 440 5 speed 71 Road Runner 440 4 speed
[Re: WO23Coronet]
#2246558
02/03/17 03:04 PM
02/03/17 03:04 PM
Posts: 2,505 God's Country Maryland
GODSCOUNTRY340
Almost sounds like he didn't replace the seal where the sump filter pushes in. Some filters come with the new seal, cheaper ones don't. Did he replace both filters?
[Re: GODSCOUNTRY340]
#2247100
02/04/17 11:35 AM
02/04/17 11:35 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Almost sounds like he didn't replace the seal where the sump filter pushes in. Some filters come with the new seal, cheaper ones don't. Did he replace both filters? This I agree with as I have seen many not get the sump filter all the way in and it sucks in air. And did he replace both filters ? My question is did it do this before he worked on it and how did it act when it had the code in it before he replaced the solenoid pack ? Ron
[Re: dynorad]
#2247183
02/04/17 02:27 PM
02/04/17 02:27 PM
GODSCOUNTRY340
He most likely didn't get the filter tube pushed through the seal, I'd say he just got it up against it and then installed the bolt to hold it up. There is only one small bolt that holds the filter in place. Drop the pan (messy job) and remove the bolt holding the sump filter, it will drop down as you remove it. If he correctly installed the filter you should have to pull and twist the filter to get it to come down out from the seal, if it drops right out it wasn't installed into the seal. If it were mine I'd buy both new filters from Napa with the seal and replace them both while you're in there.
