mechanical fan vs electric
#2246501
02/03/17 02:06 PM
02/03/17 02:06 PM
Posts: 8,031 Mt Morris Michigan
mopar dave
Mt Morris Michigan
Thought I would start another post about cooling a 500+ BB in an A body. Still not sure which way I'm going with the radiator,but as this point I could go A or B body down flow. I would like to cool this with a 440 source mechanical 40gal water pump and a flexi-lite 6 blade fan with a full rad. shroud. Can this be done or do you think it would be easier to cool with electric fans? Heres the fan.
Re: mechanical fan vs electric
[Re: mopar dave]
#2246532
02/03/17 02:38 PM
02/03/17 02:38 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Mechanical fan on a clutch or electric. Never a direct drive fan.
Mechanical can move a lot more air, but the advantage of electric is you can cool the radiator while the engine is off. If you are over heated, kill the motor, let the fan run a minute, then fire it back up to circulate water, and repeat till you're cool.
I like electric because it's only on when you need it. Not turning the clutch/fan when you don't need it. I kept a 500 hp big block cool with a properly sized fan and clean, well maintained radiator
**Photobucket sucks**
[Re: mopar dave]
#2246615
02/03/17 04:44 PM
02/03/17 04:44 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Thought I would start another post about cooling a 500+ BB in an A body. Still not sure which way I'm going with the radiator,but as this point I could go A or B body down flow. I would like to cool this with a 440 source mechanical 40gal water pump and a flexi-lite 6 blade fan with a full rad. shroud. Can this be done or do you think it would be easier to cool with electric fans? Heres the fan. El decapitate..........those things are dangerous and I run the HHR chevy fan w/a Moroso w/p. and they work well together and the new pump cools a bit better. Street car, desert heat.............
[Re: 70Cuda383]
#2246653
02/03/17 05:43 PM
02/03/17 05:43 PM
Posts: 5,080 organ
maximum entropy
organ
never say never.
[Re: maximum entropy]
#2246656
02/03/17 05:46 PM
02/03/17 05:46 PM
Posts: 21,819 Kirkland, Washington
Pacnorthcuda
never say never. Yep. I ditched the clutch in favor of direct. Best way to move air if that's your goal.
[Re: mopar dave]
#2246661
02/03/17 05:52 PM
02/03/17 05:52 PM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
Those flex fans are notorious for losing blades and hurting people. Get a good electric fan setup. I use the fan and shroud setup off a 2003 dodge Viper.
[Re: mopar dave]
#2246663
02/03/17 05:54 PM
02/03/17 05:54 PM
Posts: 7,506 Az
Crizila
Az
Thought I would start another post about cooling a 500+ BB in an A body. Still not sure which way I'm going with the radiator,but as this point I could go A or B body down flow. I would like to cool this with a 440 source mechanical 40gal water pump and a flexi-lite 6 blade fan with a full rad. shroud. Can this be done or do you think it would be easier to cool with electric fans? Heres the fan. What you propose would be the way I would go, ( Simplest, least costly, best cooling capability, no additional amp draw issues to contend with ) especially for the street. I would lean more to electric for race only application.
Fastest 300
[Re: Crizila]
#2246673
02/03/17 06:06 PM
02/03/17 06:06 PM
Posts: 516 ,Pa.
68dodge
,Pa.
I like the electric fans and pump, for street or strip in my big block A-Body. On the street, if you would run into a problem with the car running hot because of traffic on a hot day. You can just stop and let it cool down. Same when you at the track between runs. But that's your own choice.
[Re: mopar dave]
#2246693
02/03/17 06:24 PM
02/03/17 06:24 PM
Posts: 4,457 Washington
madscientist
Washington
Then fan you posted is the fan I use.
I can tell you that a quality mechanical pump and fan with the correct pullies (I overdrive my WP 6% and would have done 10 I'd I could have found pullies).
I have a hard time getting heat in the engine without a Tstat.
The WP, speed you turn it and the area of the radiator is what counts. Most guys don't run enough pump or pump speed. Flow is what cools. The fan pulls air at idle and low speeds.
[Re: mopar dave]
#2247079
02/04/17 10:18 AM
02/04/17 10:18 AM
Posts: 2,915 A shed in England
Tig
A shed in England
Word of warning, we bought an Ebay unbranded chinese electric fan to supplement the stock fan on our mild small block a body build, just in case we needed it. Never had to use it. During a burn out, the stock fan pulled enough air to exceed the electric fans safe working RPM and it promptly exploded taking out the radiator and part of the grill. Messy Another point of note is we noticed the car would pick up on et and mph if the fan belt slipped those stock 8 bladers must take some power to turn at high (ish) rpm.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: mopar dave]
#2247128
02/04/17 12:41 PM
02/04/17 12:41 PM
Posts: 7,506 Az
Crizila
Az
Remember you will be putting an additional 25 - 30 amp draw on your electrical system - at idle, which could necessitate an alternator change. If you have to run the fan with the engine off because of an over heat, you got "other" cooling system problems that you sure don't want to deal with on the street. Some of the HP losses quoted with a mechanical fan are way on the high side (IMO) and usually don't take in to consideration the HP loss caused by the additional 25-30 amp draw that the alternator has to supply. Due to clearance issues with my street rod, I have to run a 16" electrical fan. Draws 24 amps and I can actually watch the rpm drop when it kicks on. Unless it has been damaged, Flex fans are as reliable as any metal fans. Mine sees 7K at the track all the time.
Fastest 300
[Re: mopar dave]
#2247156
02/04/17 01:22 PM
02/04/17 01:22 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Ron, what radiator and shroud set up do you have? Dave its an Afco aluminum rad I bought from Mancini as I just told them it was a 63 Sport Fury and they new which one would fit. I did not want to spend the money most places wanted for a good shroud to fit as most wanted over $200 for a shroud ! So I went to the salvage yard and got a shroud from an early 90's Dakota and modded it some to fit. It works pretty good and was alot cheaper then the good ones they sell. Ron
[Re: mopar dave]
#2247199
02/04/17 03:06 PM
02/04/17 03:06 PM
Thumperdart
State of confusion
Dom, what size is that pump? I was looking at the summit pumps earlier and i think they are 35gal pumps. Would that be enough flow. The newer Morose say bet. 35-37 gpm and should be more that the old ratings based on what Moroso told me............The HHR fits perfectly on my 26" tank to tank Griffen..............
[Re: mopar dave]
#2247227
02/04/17 03:57 PM
02/04/17 03:57 PM
Posts: 11,709 Portage,michigan
B3422W5
Portage,michigan
I am soon going to install the updated Moroso pump and an electric fan on my 318 Moroso says 30-37 gpm, way more than the one they sold years ago that I used on my old car. And that one even worked decently on the street on a 9 sec car. Btw, my brother and I years ago swapped on electric water pumps and fans on our cars. Both were sorted out cars and we both picked up a tenth with zero other changes.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: DrCharles]
#2247232
02/04/17 04:03 PM
02/04/17 04:03 PM
Posts: 7,506 Az
Crizila
Az
Some of the HP losses quoted with a mechanical fan are way on the high side (IMO) and usually don't take in to consideration the HP loss caused by the additional 25-30 amp draw that the alternator has to supply. Due to clearance issues with my street rod, I have to run a 16" electrical fan. Draws 24 amps and I can actually watch the rpm drop when it kicks on 30 amps at 14 volts is 420 watts. 1 hp = 746 watts. Allowing for alternator efficiency, belt frictional losses, etc. that's less than 1 hp to drive the electric fan. Even if that 45 hp from the magazine article is double what your experience is, I'll take 1 hp over 20 hp loss any day. The reason the RPM drops when that little load kicks on is that your idling engine is only making a couple of hp just to turn itself over, so the alternator load is a significant change... same thing happens on a non-computer-controlled car when the A/C compressor kicks in. Thank you doctor.
Fastest 300
[Re: DrCharles]
#2247248
02/04/17 04:48 PM
02/04/17 04:48 PM
Posts: 4,669 Wichita
GY3
Wichita
On my 505" stroker, I run a 318 poly radiator from a manual trans car. No lower tank for the A/T. I run the Hayden short "Jaguar" 2765 clutch on a Mopar fan. I had them move the saddles back 1/2 inch when they rodded out the radiator. It not only keeps it cool at the track but in stop and go traffic as well. Surprised the heck out of me it works so well! No shroud either. I have friends with high dollar aluminum radiators, electric fans and water pumps that shake their heads...
For a water pump I used the 440Source pump and housing. NO thermostat!
[Re: Crizila]
#2247492
02/05/17 12:48 AM
02/05/17 12:48 AM
70Cuda383
Marysville, O-H-I-O
For that post I was wearing my engineer hat instead of my doctor hat Since you seem to know Ohm's law, How long can his 650 CCA trunk mounted battery sustain a 25 amp draw with the engine off @ zero ambient temp before he can't start his car - causing him to miss his Doctors appointment? Zero degrees and he's overheating so badly he has to shut down but keep the fan going to cool the radiator? Sounds like the worst case scenario. At that point, I'd walk away from the car. No need to run the fan any longer than 90 seconds with the engine off to fully cool the radiator. I've tested this. From scalding hot radiator to cold to the touch. If the engine is overheating, that's the time to start it up, give it 2500 RPM to add amps back to the battery and circulate the water. If his battery can't supply power for 90 seconds with the engine off, again, he has other problems.
[Re: Crizila]
#2247584
02/05/17 05:03 AM
02/05/17 05:03 AM
Posts: 3,877 Oregon
hooziewhatsit
Remember you will be putting an additional 25 - 30 amp draw on your electrical system - at idle, which could necessitate an alternator change. If you have to run the fan with the engine off because of an over heat, you got "other" cooling system problems that you sure don't want to deal with on the street. Some of the HP losses quoted with a mechanical fan are way on the high side (IMO) and usually don't take in to consideration the HP loss caused by the additional 25-30 amp draw that the alternator has to supply. Due to clearance issues with my street rod, I have to run a 16" electrical fan. Draws 24 amps and I can actually watch the rpm drop when it kicks on. Unless it has been damaged, Flex fans are as reliable as any metal fans. Mine sees 7K at the track all the time. That's what's nice about the mercedes fan. With the fan running at idle (25%), the ones I've tested pull less than 10A if I recall correctly. It might have even been around 5a Certainly nothing near the 30-40a it will draw at full speed.
[Re: mopar dave]
#2247676
02/05/17 12:54 PM
02/05/17 12:54 PM
Posts: 7,506 Az
Crizila
Az
I have a serpentine pulley system. I had the electric pump and fan on last sb combo. They do have benefitts for sure. I already have the mech. Pump and fan. Just need the radiator at this point. Its good to get other ideas or opinions. Thanks I still contend that if you are running a large HP motor, mostly on the street, a large flex fan and good shroud are the way to go. It will move more air than most electric fans where you need it, Big improvement in street reliability ( no wires, relays, controllers, switches to contend with ), less than a quarter the cost, no additional burden on your existing electrical system. Trade off for the above will be a small amount of HP. Most cars today run electric fans. They were designed from the ground up to run them and only have to deal with cooling engines that are less than 1/2 the HP we are working with. "Yesterdays" cars only used mechanical fans - what they were designed for. IMO, it's really all about the application, as are many threads on this site. Both types have their +'s and -'s. Want reliability on the street, mechanical fan. Want that last bit of HP for the track, electrical.
Fastest 300
[Re: ccdave]
#2247856
02/05/17 05:13 PM
02/05/17 05:13 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
I'm running an old Direct Connection 5 blade clutch fan and stock repro pulleys from 440 Source on my 493 and it runs nice and cool at any speed. I'm running an older factory water pump that has less clearance to the Mancini housing. Later model pumps were designed with more clearance to run hotter for emissions purposes.(just a theory I share with a few other engine guys) Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Crizila]
#2248605
02/06/17 05:25 PM
02/06/17 05:25 PM
Posts: 5,080 organ
maximum entropy
organ
i run a flex-a-lite 19" 6 blade on my junk. i don't even have a shroud. my fan (and pump) are slightly overdriven (pulley size can make or break the combo). i have NEVER heard of, or seen, a flex-a-lite throw a blade. ever. their fans are rated at 8 to 10,000 rpm, depending on size. i tried every electric fan on the planet. wasted a lot of money, but learned a lot. the big dumb fan, and appropriate pulleys were the answer in my case. nothing fancy. the fan is quiet, and moves a preposterous amount of air. yeah, the electric freed up a couple of horsepower, but what good is that when you're stuck in a traffic jam, or hot lapping, and the temp is ratcheting upward? i'll gladly trade 10 hp for stonewall reliability. i actually won a race once because my competition couldn't make it to the line (it was a very hot day).
[Re: mopar dave]
#2248712
02/06/17 09:10 PM
02/06/17 09:10 PM
Posts: 4,384 Worst Weather USA
493_DART
Worst Weather USA
My setup never goes above 210 in the August heat..
A body , Rb , 12:1 , half filled , griffin alum rad. , 2007 HHR fan trimmed to fit , and stock water pump .
car trimmed to move the rad forward 1" .
I have around 1" from fan motor to w/p pulley .
Heres a link to the fan :
http://www.ebay.com/itm/Apdi-6016144-Engine-Cooling-Fan-Assembly-/361557605754?fits=Year%3A2007%7CModel%3AHHR&hash=item542e833d7a:m:mYc7ccvZDdaj_Sp_fQsp80Q&vxp=mtr
#2248804
02/06/17 11:12 PM
02/06/17 11:12 PM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
yeah, the electric freed up a couple of horsepower, but what good is that when you're stuck in a traffic jam, or hot lapping, and the temp is ratcheting upward? i'll gladly trade 10 hp for stonewall reliability. The electric fan moves the same amount of air whether idling or high rpm. However, the mechanical fan is moving MUCH less air at idle, which is exactly when you need it the most. Fan clutches help by slipping at higher rpm but now there's another source of reliability problems. What kind of "hot lapping" are you referring to?Any time the car is moving over about 20 mph the fan only gets in the way. If you're overheating while moving, either the airflow through the core is insufficient, or you don't have enough radiator. The type of fan won't matter here. Finally, it's not "a couple" or even "10 hp", didn't you see the fan test article (and other similar tests)? Would you gladly give up 30 or 40 hp?
[Re: mopar dave]
#2248825
02/06/17 11:40 PM
02/06/17 11:40 PM
Posts: 620 Deep DEEP SOUTH
LAD 524
Deep DEEP SOUTH
OEM dual fan setups often just turn on the one fan at a certain temp, and when under hi load, AC on, hot weather, towing etc will turn on the other to rapidly pull heat from the rad/system. For our cars, its the idle temps that usually are the issue, this is where the right elec fans shine. If elec fans were crap - OEMs would not use them. They have already spent a fortune doing the R&D, the secret is to adapt the right ones, wire them correctly and make sure the Alt has enough beans to keep the system topped up. In other words match your parts so that they work as a system
[Re: mopar dave]
#2248873
02/07/17 01:00 AM
02/07/17 01:00 AM
GY3
Wichita
Oh yeah, forgot, I use a 440Source wp pulley and a Moroso underdrive pulley on the crank was worried about it with the underdrive pully but no problem on even the hottest days!
[Re: DrCharles]
#2248925
02/07/17 02:31 AM
02/07/17 02:31 AM
Posts: 7,506 Az
Crizila
Az
yeah, the electric freed up a couple of horsepower, but what good is that when you're stuck in a traffic jam, or hot lapping, and the temp is ratcheting upward? i'll gladly trade 10 hp for stonewall reliability. The electric fan moves the same amount of air whether idling or high rpm. However, the mechanical fan is moving MUCH less air at idle, which is exactly when you need it the most. Fan clutches help by slipping at higher rpm but now there's another source of reliability problems. What kind of "hot lapping" are you referring to?Any time the car is moving over about 20 mph the fan only gets in the way. If you're overheating while moving, either the airflow through the core is insufficient, or you don't have enough radiator. The type of fan won't matter here. Finally, it's not "a couple" or even "10 hp", didn't you see the fan test article (and other similar tests)? Would you gladly give up 30 or 40 hp? Those #'s are "SLIGHTLY" high - IMO. I won't quote any numbers, but most electric fans actually run slower at idle and how much slower will depend on just how much your alternator is up to the task at idle, where it supplies much less current. A flex fan actually works just the opposite from your explanation. There is much less HP loss at speed ( higher rpm's ) where the blades flatten out -( reads "FLEX" fan). No one on this site really cares what the HP loss is at idle. They're just concerned with cooling. And as I said, todays cars are designed from the ground up for electric fans. They have well over 100 amp alternators with a very fast current rise curve ( very small pulleys, serpentine belt driven ) and they are cooling sewing machine motors that seldom see 5K rpm. - Apples and oranges. Flex fans don't use ( or need ) a fan clutch. Stick with your Doctor's hat.
Fastest 300
[Re: mopar dave]
#2248944
02/07/17 03:10 AM
02/07/17 03:10 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I've run flex-fans on a few cars, all with good success. I've read the horror stories, but never had an issue nor ever met anyone who had one come apart. My current setup is a summit 7-blade flex fan and a homemade aluminum shroud on a summit radiator. Water pump and housing are 440-source units, and I run a 160 stat. My car stays nice & cool on the street, and is generally plenty cooled down by the time I get back to the pits after a run. Just last year my buddies chevelle started getting real hot between runs at the track one day. We thrashed between rounds to find that electric water pump relay had crapped out. We had to bypass it. Turned out okay , but he almost missed a call. I know the OP is about fans, not pumps, but my point is I like simple & reliable.
[Re: DrCharles]
#2249139
02/07/17 03:45 PM
02/07/17 03:45 PM
Posts: 5,080 organ
maximum entropy
organ
yeah, the electric freed up a couple of horsepower, but what good is that when you're stuck in a traffic jam, or hot lapping, and the temp is ratcheting upward? i'll gladly trade 10 hp for stonewall reliability. The electric fan moves the same amount of air whether idling or high rpm. However, the mechanical fan is moving MUCH less air at idle, which is exactly when you need it the most. Fan clutches help by slipping at higher rpm but now there's another source of reliability problems. What kind of "hot lapping" are you referring to?Any time the car is moving over about 20 mph the fan only gets in the way. If you're overheating while moving, either the airflow through the core is insufficient, or you don't have enough radiator. The type of fan won't matter here. Finally, it's not "a couple" or even "10 hp", didn't you see the fan test article (and other similar tests)? Would you gladly give up 30 or 40 hp? which makes sense in theory, BUT, that fan speed, and type, make all the difference. my fan, at idle, pulls MUCH more air than all the electrics i tried. my combination didn't work until i bumped the fan/water pump speed up. it only took a little. i ran before/after at the track, and it ran EXACTLY the same e.t., regardless of which fan i ran. i did try a 7 blade, and it did slow about a half a tenth. it didn't run any cooler. as far as my definition of "hot lap", it was a 100 degree plus day at my home track in central oregon. i had gon out in the first round, so i bought into the "gamblers" bracket, which i won, because the last two opponents were unable to make it to the line. i made three passes in 10 minutes. THAT IS HOT LAPPING, methinks. flame on... i can take it...
[Re: StealthWedge67]
#2249143
02/07/17 03:51 PM
02/07/17 03:51 PM
Posts: 7,506 Az
Crizila
Az
I've run flex-fans on a few cars, all with good success. I've read the horror stories, but never had an issue nor ever met anyone who had one come apart. My current setup is a summit 7-blade flex fan and a homemade aluminum shroud on a summit radiator. Water pump and housing are 440-source units, and I run a 160 stat. My car stays nice & cool on the street, and is generally plenty cooled down by the time I get back to the pits after a run. Just last year my buddies chevelle started getting real hot between runs at the track one day. We thrashed between rounds to find that electric water pump relay had crapped out. We had to bypass it. Turned out okay , but he almost missed a call. I know the OP is about fans, not pumps, but my point is I like simple & reliable. Making use of the vacuum advance could also help in keeping it cool on the street.
Fastest 300
#2249149
02/07/17 04:10 PM
02/07/17 04:10 PM
madscientist
Washington
Most guys try and save a bit of HP by slowing the WP down. I'd rather run it a bit faster. I run my at 6% faster than OE.
[Re: Crizila]
#2249363
02/07/17 10:32 PM
02/07/17 10:32 PM
DrCharles
West Plains, MO
Those #'s are "SLIGHTLY" high - IMO. I won't quote any numbers, but most electric fans actually run slower at idle and how much slower will depend on just how much your alternator is up to the task at idle, where it supplies much less current. A flex fan actually works just the opposite from your explanation. There is much less HP loss at speed ( higher rpm's ) where the blades flatten out -( reads "FLEX" fan). Yes, if you have a properly designed electrical system, it won't slow down. That only happens when your alt can't keep up with the demand and maintain 14 volts. And once again, a flex fan takes less but not "much less". The flex fan, especially without a clutch, consumes a lot more hp at high rpm than you think. Look at the tables. Stick with your Doctor's hat. You can stuff that attitude. I may not be as much of an old-timer as you (built my first big-block A-body around '83) but I know what works and what doesn't.
[Re: DrCharles]
#2249384
02/07/17 11:10 PM
02/07/17 11:10 PM
Posts: 7,506 Az
Crizila
Az
Fastest 300
[Re: Crizila]
#2250059
02/09/17 12:26 AM
02/09/17 12:26 AM
StealthWedge67
Puyallup, WA
I've run flex-fans on a few cars, all with good success. I've read the horror stories, but never had an issue nor ever met anyone who had one come apart. My current setup is a summit 7-blade flex fan and a homemade aluminum shroud on a summit radiator. Water pump and housing are 440-source units, and I run a 160 stat. My car stays nice & cool on the street, and is generally plenty cooled down by the time I get back to the pits after a run. Just last year my buddies chevelle started getting real hot between runs at the track one day. We thrashed between rounds to find that electric water pump relay had crapped out. We had to bypass it. Turned out okay , but he almost missed a call. I know the OP is about fans, not pumps, but my point is I like simple & reliable. Making use of the vacuum advance could also help in keeping it cool on the street. Picture is current as it sits (on jackstands with all sorts of things unhooked). New HP carb doesn't have provisions for vacuum advance. I'll have to plug it, just haven't plugged it yet.
[Re: mopar dave]
#2250062
02/09/17 12:30 AM
02/09/17 12:30 AM
StealthWedge67
Puyallup, WA
I agree with you. I'm gonna need a upper hose just like the one in the pic. original # part? I've had it for years, don't have the part number handy. All I did was go to the local Napa, and start rifling through all of their hoses until I found one that I though would work. Had to get a sleeve to step down the size of the radiator side.
