3/4" tube drag race steering column coupler question #2246251
02/03/17 12:31 AM
02/03/17 12:31 AM
Saskatchewan, Canada
cudabin Offline OP
cudabin  Offline OP
I am going to replace my stock steering column with a 3/4' chrome moly tube, and use the Strange 1200 SFI quick release with a 633 Grant 5bolt wheel.
I am planning to use a needle bearing ujoint style coupler on the box like the borgeson, or AFCO
https://www.summitracing.com/int/parts/afc-30305/overview/
Are all the A body manual steering boxes 3/4" 36 spline?
Is it OK to just use a 3/4" rod end to support the shaft under the dash??
Pictures of how you guys did it are welcome!
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...) 70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
Re: 3/4" tube drag race steering column coupler question [Re: cudabin] #2246258
02/03/17 12:39 AM
02/03/17 12:39 AM
MR_P_BODY Offline
MR_P_BODY  Offline
There is a 3/4 oversize heim that I used on
the chassis.. its a slip fit for 3/4 tube
wave
https://www.summitracing.com/parts/fla-fr1810
EDIT
You can see where I put it on my chassis in this
pic
Re: 3/4" tube drag race steering column coupler question [Re: MR_P_BODY] #2246280
02/03/17 01:03 AM
02/03/17 01:03 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Mike is right you definitely want to get the heim that is oversized for what you want to do... up
I've also seen a couple dumasses tack the u joints on before the heim was put over the shaft... tsk fan
Be sure to align(index)the U joints if you use more than one... twocents
...FAFO...
Re: 3/4" tube drag race steering column coupler question [Re: cudabin] #2246393
02/03/17 08:28 AM
02/03/17 08:28 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Mine uses a gutted stock column tube with a roller bearing at the top only. It has no lower bearing in the column. after market U-joint at the gear box. Steers very well.
Doug
Re: 3/4" tube drag race steering column coupler question [Re: cudabin] #2246396
02/03/17 08:48 AM
02/03/17 08:48 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Doug ...that bushing at the bottom of the shaft housing, is that something you fab. up was it from some manufacturing item? My reason for asking is that I had to fab. up something similar on my housing.
Sorry op. not meaning to steal your thread.
Re: 3/4" tube drag race steering column coupler question [Re: cudabin] #2246399
02/03/17 09:29 AM
02/03/17 09:29 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I made a washer and welded on. It doesn't actually support anything, just a coverage . It's intended use was in case of fire. A path blocker
Re: 3/4" tube drag race steering column coupler question [Re: MR_P_BODY] #2246439
02/03/17 11:54 AM
02/03/17 11:54 AM
Az
Crizila Offline
Crizila  Offline
Az
What's the max on angles? I have heard 30*, but ?????
Fastest 300
Re: 3/4" tube drag race steering column coupler question [Re: Crizila] #2246448
02/03/17 12:09 PM
02/03/17 12:09 PM
moparx Offline
moparx  Offline
several joint descriptions state 35* for a single joint, but there are double joints out there from several companies that allow more angle. unfortunately, i can't at this minute, state what the maximum angle is for the double joints are. the "oversize" 3/4" heim measures .757 ID. using a common 3/4" heim won't work on a bare 3/4" shaft [even if it measures a common .749 OD. size], and any paint makes it even worse. [can't think of anything being worse than not fitting in the first place]
beer
Re: 3/4" tube drag race steering column coupler question [Re: moparx] #2246560
02/03/17 03:12 PM
02/03/17 03:12 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
We made a tubular column for my Challenger. I adapted the factory woodgrain steering wheel to the quick release.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: 3/4" tube drag race steering column coupler question [Re: cudabin] #2246668
02/03/17 06:00 PM
02/03/17 06:00 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
I made my own column also. Mated a stock steering wheel to a Wilwood quick release. Also used a 3/4" heim to to support the shaft.
69 GTX 68 Road Runner
