Question on removing the 1/4 panel trim on a 69 GTX #2244919
01/31/17 08:38 PM
01/31/17 08:38 PM
69x Offline OP
69x  Offline OP
The piece from the back bumper to the Wheelwell, looking inside the trunk its held on by 4 clips.
They look like the type of clip that you would use a pliers on to squeeze the prong like clip ends together and then push out.
Is this the way to remove the trim piece ?
And then how do you go about putting the trim piece back on the car? can you reuse the clips?
Thanks a bunch
Re: Question on removing the 1/4 panel trim on a 69 GTX [Re: 69x] #2245010
01/31/17 11:10 PM
01/31/17 11:10 PM
southern conn
1969gtx Offline
1969gtx  Offline
southern conn
If the clips are original thay should be white color the molding snaps on to remove pry off gently. The clip is held to the body with pin pushed in the center spreads out fingers in the hole in the body. As far reusing as long as the clip is not had and cracking
1965 A/FX Plymouth 9.50 et @139 mph
1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi
1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM
1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM
http://www.AFXER.com
