If the clips are original thay should be white color the molding snaps on to remove pry off gently. The clip is held to the body with pin pushed in the center spreads out fingers in the hole in the body. As far reusing as long as the clip is not had and cracking
1965 A/FX Plymouth 9.50 et @139 mph
1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi
1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM
1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM
http://www.AFXER.com
