Repairing rocker pads ? #2243387
01/29/17 02:51 PM
01/29/17 02:51 PM
14437
HOTHEMI Offline OP
HOTHEMI  Offline OP
14437
does anyone repair damaged rocker arm pads >? I have some Hemi rockers with some scaring on them Thanks
Re: Repairing rocker pads ? [Re: HOTHEMI] #2243400
01/29/17 03:22 PM
01/29/17 03:22 PM
You would need this attachment on your valve grinder.
Re: Repairing rocker pads ? [Re: HOTHEMI] #2243455
01/29/17 05:12 PM
01/29/17 05:12 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Tim at FOR HEMIS ONLY does them.
Re: Repairing rocker pads ? [Re: HOTHEMI] #2243525
01/29/17 07:01 PM
01/29/17 07:01 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Does grinding them wear through the hardness? Do they have to be heat treated after they are ground?
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Repairing rocker pads ? [Re: Hemi_Joel] #2243653
01/29/17 10:20 PM
01/29/17 10:20 PM
14437
HOTHEMI Offline OP
HOTHEMI  Offline OP
14437
good question Joel..and how much can you grind them before you alter the ratio ?
Re: Repairing rocker pads ? [Re: HOTHEMI] #2244598
01/31/17 12:19 PM
01/31/17 12:19 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Yes, that's what they do.
HOWEVER: there is no fixture that actually restores the original radius to the pad, the accuracy of the finished product depends largely on the skill of the operator.
Boffin Emeritus
Re: Repairing rocker pads ? [Re: polyspheric] #2244679
01/31/17 02:08 PM
01/31/17 02:08 PM
Agreed, you need a very light touch/minimal material removal.
Re: Repairing rocker pads ? [Re: HOTHEMI] #2244792
01/31/17 04:57 PM
01/31/17 04:57 PM
Cab_Burge Online work
Cab_Burge  Online Work
Rocker Arm Specialitys AKA RAS( not the new name, sorry) does complete blueprinting and rebush the rocker arms that need it or want them up Not cheap or fast though shruggy 530-242-1316 scope
Re: Repairing rocker pads ? [Re: Cab_Burge] #2244813
01/31/17 05:22 PM
01/31/17 05:22 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: Repairing rocker pads ? [Re: John_Kunkel] #2244845
01/31/17 06:24 PM
01/31/17 06:24 PM
Washington
madscientist Offline
Washington
Originally Posted By John_Kunkel
I never remember the new name. Thanks for posting it.
