Win Saturday, new best on Sunday...
#2244050
01/30/17 04:44 PM
01/30/17 04:44 PM
Posts: 2,363 Cotati, CA
Dave Hall
Cotati, CA
Throttle stop linkage came apart on New Years Day. I "fixed" the car in the garage while going over everything for this weekends race. I thought I had it fixed but I connected the linkage with a cam in the wrong position and while the secondaries were opening the primaries were closing. Not an easy fix on a hot car at the track. I got burned but I got it done and got one good time run Saturday then went 5 rounds for the Super Pro win at Sonoma. Sunday I sat out the first two cold a$$ time runs. I cleaned up the car and went over everything. I made the last time run and got out past 60' and noticed the car hadn't made the shift so I reached over and shifted it. The pass seemed really good and fast and I was surprised with a -.002, 9.15 at 146 and change. It went 5.82 at 118 in the eighth. I went back and checked the shift routine and low and behold my shifter was missing the piece that the automatic plunger rams into to move it forward. No time to get it apart and fix it so I replayed the run on the Mega450 and I shifted at 7,200 rpm. A little bit more rpm than I really wanted to run so I set my shift light to 6,800 and put a 9.20 on the car for 1st rd. When I let go of the button I thought all day long that I was RED! The tree came down and lo and behold it was .003 green and the chase was on. Because of the thought process about being red, not to mention the force of habit, I forgot all about the shift light and short shifted at 6,400 according to the replay. My opponent was .005 and dead on 7! I got waxed! I probably could've got under him if I had shifted correctly but a 9.24 on the brakes wasn't close. Great weekend at Sonoma with perfect weather in the afternoon. It's funny that I was having a good conversation that morning with another racer who was telling me all of his automatic shifter woes and why he disconnected his. So! Do you think that if I removed the 240lbs. of ballast and replaced the throttle stop with a super sucker my car would go 8's???
Re: Win Saturday, new best on Sunday...
[Re: Dave Hall]
#2244078
01/30/17 05:17 PM
01/30/17 05:17 PM
Posts: 19,375 Las Vegas
Al_Alguire
Las Vegas
The weight will help more than anything for sure. Don't get caught up in the 100lbs is a tenth BS cause it pretty much is just that BS. Especially as you start to go faster. I would expect 240lbs might net you .1 or so, unless the 60' picks up markedly. FWIW we ad 195lbs to the heads up car to run back east and slowed us MAYBE .02 and that was all down low. BTW I am sure the air was really good as well. It sure was in Vegas as the Dragster had a new best too by a boatload.
Apparently it likes a bit more RPM, could be a couple reasons why it does that. Could be happier at more RPM or could be fallback on shift is closer to where the engine wants to be allowing it to accelerate quicker. The stoo is costing some power too, we tested mine on the dyno and found it cost mine 10-15hp, the old butterfly was 40ish hp!! Spacer may help a tad as well, don't remember which intake you have. At any rate congrats on the new best and best of luck chasing those bracket points this year!!
[Re: Dave Hall]
#2244116
01/30/17 06:23 PM
01/30/17 06:23 PM
Al_Alguire
Las Vegas
Hey I love my disc stops, but they do require maintenance from time to time. Never used an electric one though We even got the old two ton Chevelle working great with one, even though it is kinda slow Man work on the 60' and it should fly. I assume you have the smaller RB intake like we do on the dragster. We run the same OOTB head with a good valvejob too. I deal has a nice 2" shearplate/spacer on it and seems to work well. Engine will be coming out of it soon and a B1 taking its place. Be fun to slide the B1 in that car of yours and see what it will do
[Re: Dave Hall]
#2253010
02/13/17 04:41 PM
02/13/17 04:41 PM
Posts: 13,374 Marion, South Carolina [><]
an8sec70cuda
[Re: Dave Hall]
#2253348
02/14/17 02:15 AM
02/14/17 02:15 AM
Dave Hall
Cotati, CA
This is the 493 when it was new with the Edelbrocks. 2005
[Re: Dave Hall]
#2253357
02/14/17 02:46 AM
02/14/17 02:46 AM
Thumperdart
State of confusion
Sacramento Raceway New Year's Day 2017. Congrats and bad ass lookin car man............
[Re: Dave Hall]
#2253358
02/14/17 02:52 AM
02/14/17 02:52 AM
Dave Hall
Cotati, CA
Thanks Dom! This is Al and I in the LVMS staging lanes, spring 2013, when he was winning EVERYTHING!
