Re: T/A 'and AAR's
[Re: Little Detroit]
#2242808
01/28/17 02:45 PM
01/28/17 02:45 PM
Porter67
If things cant be backed up by real documentation then its just pure speculation.
Thats not directed at anyone here, just my thoughts of all mopar info in general.
Too many times ive seen things "shaped" only to be disproved.
But as for the TA cars, mine has the org. stamped block, so does my friends. Oddly a t/a motor out of a wrecked chally in the mid 70-s with 6k miles I used for parts had no vin and was a family members and was not replaced.
I havnt looked much into it but ive a block ive thought was always a t/a casting in my old dirt track car dated late 69 because its got the webbing of a t/a block and I dont know of any other block.
Do you guys ever take into account there are alot of t/a cars not put on the web, vins not shared? Not everyone like the internet.
From growing up around many t/a cars, they were beat, beat and beat hard, flogged worse then most hemi cars id seen. Rev them to the moon or until a rod bearing spun or broke, and many times that was the case.
Re: T/A 'and AAR's
[Re: Alaskan_TA]
#2242839
01/28/17 03:17 PM
01/28/17 03:17 PM
Posts: 29,655 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
I started reading the whole thread again since some posts were added while I was out.
So here is an elective homework assignment for you, note each of these things;
Date on the original Mylar.
Casting date on the engine.
Final assembly date on the engine.
If those three dates are original to any of the examples, neither of the dates on the engine will be dated after the date on the Mylar.
So, has anyone with their own theories done this yet? Also, as Kevin stated; I had ask about trans numbers because they were to my understanding stamped at the same time with the same machine. If your transmission & original & matches your car, the engines & transmissions were stamped one right after the other with the same stamp set. So if one matches & the other has a blank VIN pad, it was replaced at some point.
Re: T/A 'and AAR's
#2242848
01/28/17 03:22 PM
01/28/17 03:22 PM
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
If you would please ,The number of T/A and AAR's produced between 3-70 and 4-30-70 with vin #'s and other info if available? Impossible to answer, there is no way to know that. I'll quote myself from page 1; The date on the tags & broadcast sheets is actually the Scheduled Production Date, or SPD. It is the date that they hoped to build the car, not a 'build' date set in stone.
The original door stickers on the other hand were required to indicate the actual final build month & year. This is why the dates on the stickers do not always agree with the SPDs.
Lots of folks assume that the cars were built in VIN order, but it did not happen that way. The builds were also mixed with other models, other engines, other trim levels. So, without actual build records from Chrysler, the question is impossible to answer.
Re: T/A 'and AAR's
#2242859
01/28/17 03:31 PM
01/28/17 03:31 PM
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Its now been 5 days since I politely asked Berry if he would share the information he has collected from members and other sources; number of T/A's and AAR's and their vin numbers, Compliance decal sticker date, and fender tag, block date with or without , with pics of each if possible between 3-70 and 4-30-70. My registration forms have a line saying that personal data will not be given out. There are a lot of people who do not want there VINs posted. If they choose too, that is up to them - it is not my place to do so. I am not going to betray the trust they have put in me by posting data on their cars just to satisfy your request.
Re: T/A 'and AAR's
#2242861
01/28/17 03:36 PM
01/28/17 03:36 PM
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
yet another opinion! reminds of a soap opera You are Obviously another one of those people that can not comprehend [/quote [quote]If I understand your post correctly nobody including myself has a right to question the "MOPAR GOD or his DECIPLES" on their speculations or documentation . Dang, I missed a fun post. There are no experts or gods or disciples here in this thread. Chill out dude. lol
Re: T/A 'and AAR's
#2242866
01/28/17 03:43 PM
01/28/17 03:43 PM
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
As for insults don't believe I made any with the exception of the "Mopar God" thing but as one of his "disciples" I can understand your frustrations. Dang! Now I feel insulted! Not. You need to relax dude.
Re: T/A 'and AAR's
#2242872
01/28/17 03:50 PM
01/28/17 03:50 PM
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
2. made my first on 12/30/2016; took Berry 15 days to say I cannot share what I do not have. pretty much says it all. That was in response to Charles when he asked; I also asked anyone here to show me a PLYMOUTH AAR order sheet regarding the existence of the V02 option code, but nobody has come forward. I do not have one. I have seen one, but I do not recall who had it. Ken mentioned that he is looking for one, Bangert is also looking. So, 'I can not share what I do not have." Got it? 3. never bothered to check transmissions. OK, so you want the research of others to be dumped in your lap but you are not checking what you have access too?
Re: T/A 'and AAR's
#2242875
01/28/17 03:59 PM
01/28/17 03:59 PM
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
this will be my last "post "on this subject, not because I am surrendering my search or "succumb" to the content this post has graduated too. this post originally started as a request for information from anyone with information on T/A's and AAR's. the first response was from ALASKAN_T/A. Recognizing his response as an "opinion" I merely asked if he had any documentation to support his statements. Evidently that is where I went wrong. I have been subjected to numerous "opinion's" in response to my questions in order to avoid the production of the "documentation in support of their "opinions" to be a factual basis. This has been one man's quest for answers to his personal curiosity. Instead of replying as he did 5 days later('I can't give what I don't have '). I was subjected to questionable information with out documentation and ridiculed because I did not accept undocumented opinions as fact. Alaskan_T/A has his own website listed as the "official T/A Challenger Registry" with lots of vin #'s and broadcast sheets listed as found and other info I assume kept private. Because I dared to ask for "documentation" he has more or less he answered my question as no matter how you fraze the question you will not get the answer you desire, I have spoken. Hence the "Mopar God" has spoken and his "deciples" have come to his side. What this has turned into, instead of a car enthusiast asking for a little help to man trying to become the "Mopar God " that nobody questions. I can put up with sheep following the shepard blindly but I havn't been blinded yet. but the turning point for me was when a member exploited his child over subject matter that has absolutely nothing to do with his child or his handicap. If its that important to you that you have to exploit your child to make a point about a hobby ... well I guess you win. It's just not that important to me. Well, hopefully you now have a better understanding since I tried to clear some of it up? But you do come across as insulting. You have a wild theory. I have nothing to prove it, so the burden of proof is on you, not me. Some questions have no answers, hopefully I explained that above to your satisfaction. But start with the dates & stamps on your own car. Start your own spread sheet of the date coded items. No need to share it, just do it for yourself. I did that with my 4-door Valiant. 403 SPD, March sticker, Hamtramck build, numbers match. It was a fun exercise, nothing found on the car past the first few days of the last week of March. Researching your own car is fun, try it. If calling it names in the process makes you feel better, go for it. lol
Re: T/A 'and AAR's
#2242895
01/28/17 04:45 PM
01/28/17 04:45 PM
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
so if I understand you correctly everybody donated their the info of their car to you and for what reason was it again? Was it just for your own personal pleasure? It seams that you may have already violated some of their trusts, check out your own website and past posts. I assume that by personal info you relating that to car info correct? Your attitude in your post 1/28/17 @ 12:17 pm really explains the whole "Mopar God " thing and really can't get over the bloody snot rag you posted, the maturity of a 12 year old, and you expect people to take you seriously? As I said earlier I think I'll get along just fine without your help. I can see that your arrogance is leading down the same path as the other guy. One main purpose of a registry is reuniting original items, broadcast sheets, engines, transmissions etc. The photo was posted to show I really was sick since some doubt was apparent. I can not afford a doctor visit, so a doc's note was not in the cards. I am not over it entirely yet, but I am feeling a lot better. Thanks for your concern. I have mentioned ways you can help yourself gain knowledge. Start with your own car. You have access to it, we do not. I have no expectations on how people perceive me. From the amount of email I got about this thread alone though, I think that most people are quite OK with me. You have an interesting theory, so do some research. Start with your own car with the things noted by a few here about what to look at. Happy hunting, research is fun.
Re: T/A 'and AAR's
#2242903
01/28/17 05:07 PM
01/28/17 05:07 PM
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
I mentioned the spreadsheet I started for my March built, 403 SPD 1970 Valiant. Here is a list of some of the date coded items these cars can have. Obviously, some will not apply to an AAR. (AC as one example)
This list was compiled with help from Scott Smith, Dan Pausch, Kent Johnston, Ola Nilsson, Robert Schirmer & Grant Piche.
You can enter the relevant data into a spread sheet for your AAR if you choose to.
You may also find date codes on other parts to add in as you go.
AC clutch field coil * A/C evaporator/drier * AC hose * Air Grabber switch Alternator Battery Bellhousing * Blower motor * Bumper jack mechanism Calipers * Caliper mounts * Carburetor Carpet tag – front Carpet tag - rear Clock Coil Console * Convertible boot cover Dash pad * Differential ring gear Dimmer switch Distributor Door jamb switches Door panels * Engine casting date Engine final assembly date Engine mounts * Exhaust manifolds Engine main bearings Engine rod bearings Fan belt * Fuel pump * Gauge cluster Harmonic balancer Headlight switch Heads Headlights Headlight door motors Heater box * Heater fan / AC switch * Hood hinges * Hood latch Horn Horn Relay * Horn switch Intake manifold K-frame Lower control arms Muffler(s) Mylar door sticker Oil sender * Outside mirror glass * Plug wires * Power steering belt * Power steering hose * Power steering pump final assembly day * Power window motors Radiator Radio Rear window defogger Rear window defogger switch Rear end gear housing casting date Rear valence Scheduled production date from fender tag Seat belts Seat frame - rear, bottom Seat frame - rear, top Seat frame(s) front Seat tracks front Seat upholstery Shocks * Space Saver spare inflator bottle Speaker(s) Starter nose Starter case Steering column * Steering pulley * Sure grip carrier Tachometer Temp sender * Thermostat housing * Tires Transmission casting date Transmission final assembly date Transmission mount * Transmission tail shaft Trunk mat * Torsion bars * U-joint straps Vinyl top Voltage regulator Washer motor Water pump * Water pump housing * Wheels Windows Wiper motor Wiper motor switch
Re: T/A 'and AAR's
[Re: Alaskan_TA]
#2243026
01/28/17 09:05 PM
01/28/17 09:05 PM
Posts: 303 South Carolina
sixpackbird
South Carolina
I do safety certification for a major OEM and use to work for Chrysler back in the day. What is being referred to as the the mylar is the safety certification label (already discussed) that is required by the Code of Federal Regulations (CFR) to be applied to a vehicle as it completes its production and certifies that the car meets all safety regulations in effect on the day of production and can be sold to the public. Once a vehicle is certified, it can not be uncertified. The month and year of production must be the month and year shown on the label, but mistakes can and are occasionally made and since this label is not part of the Federal Motor Vehicle Safety Standards (FMVSS) (Part 571 of the CFR), it is not recallable if incorrect and would be considered an inconsequential non compliance if the date was wrong because someone in the factory did not update the software or typeset. That does not preclude a vehicle from being certified. Also, since the label is typically put on on the final assembly line, the vehicle still has some "build" to go through, which includes the rolls test, usually one of the last things before the vehicle is shipped, If something goes wrong on the rolls, such as they blow they engine, it would go to the repair hole, where it may sit for a while until there is time to work on it, especially if it requires an engine change. If it was an engine change at the factory, they would restamp the VIN on the block before they shipped it, as that is a anti theft requirement. So it is feasible that a vehicle has a March build date and an April engine if 1) the Cert Label was incorrectly printed or 2) there was an engine failure after the cert label was applied and the engine was replaced in the factory because the cert label would not be updated in this situation because you can not uncertify and re-certify a vehicle. I did not read the entire post, so I hope this point has not already been discussed. My 2-cents.
