Big block in 69 Dart which exhaust manifolds? #2241262
01/25/17 10:07 PM
01/25/17 10:07 PM
Texas
GTS440 Offline OP
GTS440  Offline OP
Texas
Are there any exhaust manifolds that will work with a 383 in a 69 Dart besides the factory big block A body ones? I've heard you can use the B body hi-perf manifolds but need to trim the steering column shaft outer tube back closer to the firewall. Anyone does this or resolved this problem before? Thanks!!
Re: Big block in 69 Dart which exhaust manifolds? [Re: GTS440] #2241277
01/25/17 10:33 PM
01/25/17 10:33 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
If you don't have the correct manifolds why not use the Schumacker headers.
Abe Lincoln
Re: Big block in 69 Dart which exhaust manifolds? [Re: dart4forte] #2241286
01/25/17 10:43 PM
01/25/17 10:43 PM
Texas
GTS440 Offline OP
GTS440  Offline OP
Texas
The last set of headers I ran was over 25 years ago & after the 3rd starter replacement I cut them off with a torch!!!!! I am satisfied with the quiet performance of exhaust manifolds!
Re: Big block in 69 Dart which exhaust manifolds? [Re: GTS440] #2241294
01/25/17 11:00 PM
01/25/17 11:00 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
B Body HP manifolds fit great and flow better than the A body manifolds. All you have to do is trim the outer steering column back.
Re: Big block in 69 Dart which exhaust manifolds? [Re: GTS440] #2241312
01/25/17 11:21 PM
01/25/17 11:21 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
You will have even more room with a 383!!
Re: Big block in 69 Dart which exhaust manifolds? [Re: GTS440] #2241319
01/25/17 11:30 PM
01/25/17 11:30 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I don't think you'll have that problem with the Schumacker headers
Re: Big block in 69 Dart which exhaust manifolds? [Re: R/T1968R/T] #2241330
01/25/17 11:47 PM
01/25/17 11:47 PM
Texas
GTS440 Offline OP
GTS440  Offline OP
Texas
Those are great pics & appears to be a beautiful car based on the under hood pics! That is the exact info I was looking for. Thank you!!!
Re: Big block in 69 Dart which exhaust manifolds? [Re: GTS440] #2241337
01/26/17 12:01 AM
01/26/17 12:01 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
You have to make sure that your column is a late 68 or 69 as columns did change, it must be like the picture above or you will need to find one like it. Even with the right column you can still have some issues with the bushing melting or getting hard and falling apart. If you don't drive it too much it will be fine, but if it is your daily then you can have issues. twocents
JB Rhinehart, Realist
A-Body's RULE!
Re: Big block in 69 Dart which exhaust manifolds? [Re: GTS440] #2241338
01/26/17 12:04 AM
01/26/17 12:04 AM
add me to the list (HP manifolds in 383 69 valiant). been a few years so I dont remember if I had to trim the column but I don't remember doing so. get the good 68-70 B body HP ones. the max wedge iron manifolds would likely (??) fit & flow even better than them & have 3" outlets but will run close to a grand at Mancini. EDIT www.bigblockdart.com has the part numbers
Re: Big block in 69 Dart which exhaust manifolds? [Re: GTS440] #2241351
01/26/17 12:09 AM
01/26/17 12:09 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
You could use the 68-70 C-body hp manifold.
Re: Big block in 69 Dart which exhaust manifolds? [Re: Rhinodart] #2241450
01/26/17 02:43 AM
01/26/17 02:43 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
You can use the early column, but you will need a custom bushing (like my son's Dart). May not need it with a 383 and 68-73 HP manifolds.
Re: Big block in 69 Dart which exhaust manifolds? [Re: Jim_Lusk] #2241568
01/26/17 12:20 PM
01/26/17 12:20 PM
moparx Offline
moparx  Offline
is there enough room a heat shield could be made to protect the plastic column bushing after trimming the column back ?
beer
Re: Big block in 69 Dart which exhaust manifolds? [Re: GTS440] #2242044
01/27/17 12:58 AM
01/27/17 12:58 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
We've put a lot of miles on my son's Dart with no heat shield. It has custom bushing (maybe Delrin) from a hot rod shop. The price was right ($35).
Re: Big block in 69 Dart which exhaust manifolds? [Re: BSB67] #2242263
01/27/17 02:18 PM
01/27/17 02:18 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
I agree. They're not long tubes and Schumacher makes some high quality stuff.
I was going to use these for my big block swap into an M body and the only reason I decided against it is the tubes are only 1 5/8". Not enought for a 512 build, but would be great for a 383.
Re: Big block in 69 Dart which exhaust manifolds? [Re: MarkZ] #2661069
05/31/19 09:52 PM
05/31/19 09:52 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I just bought a beater 1970 Polara with a great running 383. I am considering a swap into a 67 Dart that currently has a 360 & 904. This 383 has log style manifolds but I do have a pair of C body HiPo manifolds could use....but they have cracks. Are they repairable? I'd just use the log manifolds if I knew they'd clear.
Re: Big block in 69 Dart which exhaust manifolds? [Re: Kern Dog] #2661072
05/31/19 10:22 PM
05/31/19 10:22 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
You could put a bearing instead of a bushing in there.
Re: Big block in 69 Dart which exhaust manifolds? [Re: Sniper] #2661094
06/01/19 12:46 AM
06/01/19 12:46 AM
Park Forest, IL
slantzilla Offline
Happy Birthday slantzilla  Offline
Park Forest, IL
I had a '70 Dart with a 383 in it. C body logs fit very well.
Re: Big block in 69 Dart which exhaust manifolds? [Re: GTS440] #2661205
06/01/19 12:42 PM
06/01/19 12:42 PM
Boise
Moparteacher Offline
Boise
I installed a 383 in my 68 Barracuda. I used 68'-69' b-body HP manifold on the driver's side. I trimmed the column for clearance. It was easy and it worked well.
Re: Big block in 69 Dart which exhaust manifolds? [Re: Kern Dog] #2661449
06/02/19 10:13 AM
06/02/19 10:13 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Where are the cracks?
Abe Lincoln
Re: Big block in 69 Dart which exhaust manifolds? [Re: dart4forte] #2661457
06/02/19 10:27 AM
06/02/19 10:27 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I have a driver side A body big block manifold. It’s a date coded 67. Had to repair the front mounting ear due to it breaking off. Lessons learned, it’s a good idea to take the sharp edges off the front and rear mounting ears. It will reduce the chances of getting a crack.
To make the repair I had the area of the break fusion welded. One I got it back I had the mating surface machined. All that’s left is to whittle down the remaining weld until I get close to the original shape of the tab. Very time consuming being that I have to use a dermal.
I know the repair appears ugly but with a little messaging it will look better.
Abe Lincoln
