Re: Big block in 69 Dart which exhaust manifolds?
[Re: GTS440]
#2241277
01/25/17 10:33 PM
01/25/17 10:33 PM
Posts: 16,155 Mesa, Arizona
dart4forte
Mesa, Arizona
Are there any exhaust manifolds that will work with a 383 in a 69 Dart besides the factory big block A body ones? I've heard you can use the B body hi-perf manifolds but need to trim the steering column shaft outer tube back closer to the firewall. Anyone does this or resolved this problem before? Thanks!! If you don't have the correct manifolds why not use the Schumacker headers.
Abe Lincoln
[Re: GTS440]
#2241319
01/25/17 11:30 PM
01/25/17 11:30 PM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
I don't think you'll have that problem with the Schumacker headers
[Re: R/T1968R/T]
#2241330
01/25/17 11:47 PM
01/25/17 11:47 PM
Posts: 219 Texas
GTS440
Texas
You will have even more room with a 383!! Those are great pics & appears to be a beautiful car based on the under hood pics! That is the exact info I was looking for. Thank you!!!
[Re: GTS440]
#2241337
01/26/17 12:01 AM
01/26/17 12:01 AM
Posts: 43,600 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
You have to make sure that your column is a late 68 or 69 as columns did change, it must be like the picture above or you will need to find one like it. Even with the right column you can still have some issues with the bushing melting or getting hard and falling apart. If you don't drive it too much it will be fine, but if it is your daily then you can have issues.
JB Rhinehart, Realist
A-Body's RULE!
[Re: GTS440]
#2241338
01/26/17 12:04 AM
01/26/17 12:04 AM
RapidRobert
add me to the list (HP manifolds in 383 69 valiant). been a few years so I dont remember if I had to trim the column but I don't remember doing so. get the good 68-70 B body HP ones. the max wedge iron manifolds would likely (??) fit & flow even better than them & have 3" outlets but will run close to a grand at Mancini. EDIT www.bigblockdart.com has the part numbers
[Re: BSB67]
#2242263
01/27/17 02:18 PM
01/27/17 02:18 PM
Posts: 4,446 Michigan
MarkZ
Worthy
Worthy
I don't think you'll have that problem with the Schumacker headers I agree. They're not long tubes and Schumacher makes some high quality stuff. I was going to use these for my big block swap into an M body and the only reason I decided against it is the tubes are only 1 5/8". Not enought for a 512 build, but would be great for a 383.
[Re: Kern Dog]
#2661072
05/31/19 10:22 PM
05/31/19 10:22 PM
Posts: 6,291 nowhere
Sniper
nowhere
You could put a bearing instead of a bushing in there.
[Re: Kern Dog]
#2661449
06/02/19 10:13 AM
06/02/19 10:13 AM
dart4forte
Mesa, Arizona
I just bought a beater 1970 Polara with a great running 383. I am considering a swap into a 67 Dart that currently has a 360 & 904. This 383 has log style manifolds but I do have a pair of C body HiPo manifolds could use....but they have cracks. Are they repairable? I'd just use the log manifolds if I knew they'd clear. Where are the cracks?
Abe Lincoln
[Re: dart4forte]
#2661457
06/02/19 10:27 AM
06/02/19 10:27 AM
dart4forte
Mesa, Arizona
I have a driver side A body big block manifold. It’s a date coded 67. Had to repair the front mounting ear due to it breaking off. Lessons learned, it’s a good idea to take the sharp edges off the front and rear mounting ears. It will reduce the chances of getting a crack.
To make the repair I had the area of the break fusion welded. One I got it back I had the mating surface machined. All that’s left is to whittle down the remaining weld until I get close to the original shape of the tab. Very time consuming being that I have to use a dermal.
I know the repair appears ugly but with a little messaging it will look better.
Abe Lincoln
