SHAKER hood, OEM versus repro #2240631
01/24/17 08:55 PM
01/24/17 08:55 PM
Maryland
glenngomango Offline OP
Maryland
This Challenger hood is on a late build 440+6 with 6-13-70 SPD. Is this hood "assembly line" original or other?
Thanks,
Glenn
Re: SHAKER hood, OEM versus repro [Re: glenngomango] #2240653
01/24/17 09:36 PM
01/24/17 09:36 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Spotwelds look far from OE to me twocents
Older Alhambra Custom one IMHO
Re: SHAKER hood, OEM versus repro [Re: glenngomango] #2240741
01/24/17 11:50 PM
01/24/17 11:50 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Looks like a Harms Challenger hood kit, no others (ever) had the same details. The give away are the spot welds as compared to an original, on the above hood they appear wrong. .02
*Edit, after a closer look I'm not 100% sure about the spot welds looking wrong, however I'd need clearer/closer pics to make a final call. The small welds at the edges are what don't look typical of a factory example. There are also two non factory holes in the 2nd pic of the blue example above, possibly from an older modification that the restorer missed (should have been filled). Maybe the brace was R&R'd by someone doing an older rust repair or similar which would require welding it back on resulting in the non factory looking spot welds.
Re: SHAKER hood, OEM versus repro [Re: glenngomango] #2240784
01/25/17 01:06 AM
01/25/17 01:06 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Just to show how difficult identifying these can be, one of these hoods is a Harms kit conversion, the other is an original. Guess which one is which?
Re: SHAKER hood, OEM versus repro [Re: glenngomango] #2240785
01/25/17 01:07 AM
01/25/17 01:07 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
The raw kit (and for anyone unaware, I no longer sell these, it's been many years since).
Re: SHAKER hood, OEM versus repro [Re: glenngomango] #2240811
01/25/17 02:02 AM
01/25/17 02:02 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Nice even factory spotwelds for comparison..
same color to boot...
Re: SHAKER hood, OEM versus repro [Re: glenngomango] #2240814
01/25/17 02:10 AM
01/25/17 02:10 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yep, those look "spot" on smile.
Re: SHAKER hood, OEM versus repro [Re: glenngomango] #2240819
01/25/17 02:17 AM
01/25/17 02:17 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Here are the differences between a Cuda & Challenger under brace for those of you wondering. No other kit ever sold made a Challenger style with the correct factory details, only the Harms kits had them.
Re: SHAKER hood, OEM versus repro [Re: ScottSmith_Harms] #2240912
01/25/17 10:36 AM
01/25/17 10:36 AM
Maryland
Maryland
Thanks for the detailed info here. I believe the sloppy seam sealer in the rear triangular areas and the front leading edge is usually not duplicated on non-OEM hoods. This is an additional pic of the challenger with SPD of 6-13
Re: SHAKER hood, OEM versus repro [Re: glenngomango] #2241004
01/25/17 01:46 PM
01/25/17 01:46 PM
California
biggE Offline
biggE  Offline
California
Hard to tell in the pictures but what I always look for is wrinkling on the area that the shaker sticker is. Around that whole area if it's original there will be some wrinkling in places. The reproduction under structures don't have any wrinkling.
Re: SHAKER hood, OEM versus repro [Re: biggE] #2241040
01/25/17 03:22 PM
01/25/17 03:22 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
...like this....
Re: SHAKER hood, OEM versus repro [Re: mccannix] #2241057
01/25/17 03:49 PM
01/25/17 03:49 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
You guys are all killing me with these hoods. I have been looking for one for my 70' Challenger. I don't care if it's original, repro or fiberglass. I may have to do some hacking on it so I am not looking for a perfect one. But can't fathom paying how much everyone wants for one. Goodmark & AMD have been on nat'l back order.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: SHAKER hood, OEM versus repro [Re: 6PKRTSE] #2241142
01/25/17 06:03 PM
01/25/17 06:03 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
HEY Glenn, Scott on those hoods the ring nuts/studs shouldn't be painted like the reference one that was shown correct?
Ron
Re: SHAKER hood, OEM versus repro [Re: RJS] #2241171
01/25/17 06:57 PM
01/25/17 06:57 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
The nuts were supposed to be painted but were not always covered evenly.
Paint flaked off some over the years.
The original nuts for my blue hood are not on in those pictures, but I do have them.
Hard to see, but on this original paint hood some paint can be seen on the nuts
Re: SHAKER hood, OEM versus repro [Re: glenngomango] #2241468
01/26/17 03:48 AM
01/26/17 03:48 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Agreed, here's an example of an original paint Cuda hood with better coverage. On this example the nuts were painted, but some had bare areas on the opposite direction of the paint spray.
Re: SHAKER hood, OEM versus repro [Re: ScottSmith_Harms] #2241511
01/26/17 10:25 AM
01/26/17 10:25 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
That's a great example Scott.
I assume that is the 'cornfield' Hemicuda you were involved with.
Re: SHAKER hood, OEM versus repro [Re: glenngomango] #2241530
01/26/17 11:18 AM
01/26/17 11:18 AM
Maryland
Maryland
Thanks Terry, Scott for the reference photos. If only we could have seen these hoods being produced, I guess at the Hamtramck plant, back in the day!
Re: SHAKER hood, OEM versus repro [Re: mccannix] #2241567
01/26/17 12:18 PM
01/26/17 12:18 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes Terry that's the car
