Page 1 of 5 1 2 3 4 5
Bad battery cause of a rough idle? #2240184
01/24/17 12:46 AM
01/24/17 12:46 AM
Phoenix, AZ
Belvedere1 Offline OP
Phoenix, AZ
Could a weak battery or one that is going south be the cause of a rough idle or miss at a hot idle? Everything is smooth with the idle, revs nicely and idles great up until the temp reaches 180 deg and then it wants to idle down really rough to the point of a miss and surge situation.
Engine is a 451, solid cam 254/.520, MP electronic ign, MP distributor, chrome box, 800 Eddy carb, 20 deg initial timing. It will idle at 1000/1100 rpm when cold but as the temp comes up it will idle down to 600 or so. It runs really good except at idle. I'll have the battery tested here in the next day or so but just looking to see if this may be cause?
Re: Bad battery cause of a rough idle? [Re: Belvedere1] #2240189
01/24/17 12:54 AM
01/24/17 12:54 AM
Kirkland, Washington
Pacnorthcuda Offline
Possible? Yes. But the simple determinant is to measure the volts at the batt. Got 13.5 +?
While engine running.
If the batt is old and likely on its way out....replace it.
Re: Bad battery cause of a rough idle? [Re: Belvedere1] #2240190
01/24/17 12:54 AM
01/24/17 12:54 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
It could if it was drawing your system voltage down, like PacNorth says, what's the voltage?
Don't be the exception.
Re: Bad battery cause of a rough idle? [Re: Supercuda] #2240193
01/24/17 12:58 AM
01/24/17 12:58 AM
Phoenix, AZ
Phoenix, AZ
I cant find my meter, so I'll take it out and have it tested.
Re: Bad battery cause of a rough idle? [Re: Belvedere1] #2240201
01/24/17 01:05 AM
01/24/17 01:05 AM
That's not going to tell you the whole picture. If you get 12.5 give or take on the batt, great.
But the real story is the volts, while the engine is running rough.
Re: Bad battery cause of a rough idle? [Re: Pacnorthcuda] #2240203
01/24/17 01:08 AM
01/24/17 01:08 AM
Phoenix, AZ
Phoenix, AZ
OK, I see. If I cant put my hands on the one I have I'll get another one and test it running.
Re: Bad battery cause of a rough idle? [Re: Belvedere1] #2240213
01/24/17 01:19 AM
01/24/17 01:19 AM
I'm thinking elsewhere. I would start by removing the idle mixture screws & shooting a 2 second blast of brake kleen in the (2) ports with the thin red straw then reinstall the screws. turn them in to lightly seated before removal & count the turns to easily return them to their original positions when done & they might need richening. carb might need cleaning. Keep us posted.
Re: Bad battery cause of a rough idle? [Re: RapidRobert] #2240222
01/24/17 01:35 AM
01/24/17 01:35 AM
Phoenix, AZ
Phoenix, AZ
I went through the carb and rebuilt everything, it was spotless inside when I opened it. The screws are 1.5 turns out and have always stayed right I have them set.
Re: Bad battery cause of a rough idle? [Re: Belvedere1] #2240224
01/24/17 01:39 AM
01/24/17 01:39 AM
this just happened correct? Something changed (dirt or vac leak I'm guessing). I would still blast out the idle mixture ports (easy to do & not invasive)
Re: Bad battery cause of a rough idle? [Re: RapidRobert] #2240232
01/24/17 01:55 AM
01/24/17 01:55 AM
Phoenix, AZ
Phoenix, AZ
Its been in this situation for a while now but I noticed it after it had sat for an extended time. The car can sit for months before I drive it. I can try a blast of cleaner in the screw holes but it was doing the same thing before I rebuilt the carb.
Re: Bad battery cause of a rough idle? [Re: Belvedere1] #2240241
01/24/17 02:10 AM
01/24/17 02:10 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Bad gas? The new stuff goes bad a lot quicker.
Re: Bad battery cause of a rough idle? [Re: stumpy] #2240249
01/24/17 02:28 AM
01/24/17 02:28 AM
Phoenix, AZ
Phoenix, AZ
The gas here is pretty bad but I do put a few gallons of fresh gas in it when I get it out. I have ran it enough to use any old stuff that was in there in there and replace it with fresh gas and the problem is still there. The part I don't understand is why the rough idle at operating temp.
Re: Bad battery cause of a rough idle? [Re: Belvedere1] #2240250
01/24/17 02:33 AM
01/24/17 02:33 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Low voltage to a Orange box will eventually kill it. It's struggling to draw amperage from a weak system. As it starts to go south the motor may start backfiring. Put a good battery in the car and change out the box.
Think it runs bad, try running an MSD with a bad battery.
Abe Lincoln
Re: Bad battery cause of a rough idle? [Re: dart4forte] #2240252
01/24/17 02:40 AM
01/24/17 02:40 AM
Phoenix, AZ
Phoenix, AZ
I hope it hasn't started to wipe out the box. I do have a spare orange box that I ran for years with no issues. I just found the sticker on the battery and its much older than I thought, April 2010! I really don't know how it has lasted this long. Batteries here are good for about 2 years tops. Needless to say I will be getting a new battery.
Re: Bad battery cause of a rough idle? [Re: Belvedere1] #2240253
01/24/17 03:01 AM
01/24/17 03:01 AM
Someplace you aren't
SomeCarGuy Online content
SomeCarGuy  Online Content
Do you run a choke? Maybe it masks a vac leak. Check ground for your ECU, but likely that would just kill it and not run rough. While at it check to see if VR is getting a good ground too.
I want my fair share
Re: Bad battery cause of a rough idle? [Re: Belvedere1] #2240254
01/24/17 03:02 AM
01/24/17 03:02 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I would say that your box is toast. Doesn't take much for them to go. I've seen them loose their ground and pop. If you need a spare I have several laying around.
Abe Lincoln
Re: Bad battery cause of a rough idle? [Re: Belvedere1] #2240276
01/24/17 04:20 AM
01/24/17 04:20 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
My experience has been that the Mopar electronic will just quit, not cause stumbling and crap at op temps. I think that this has to be fuel related.
Re: Bad battery cause of a rough idle? [Re: Belvedere1] #2240287
01/24/17 07:06 AM
01/24/17 07:06 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Check fuel pump pressure.
Doubt vapor lock, but if fuel line is in contact with any hot engine components, all bets are off.
Fuel filter ok?
Is engine running on fast idle cam when first start because of a closed choke, choke opens engine off fast idle cam on regular idle screw setting which may be to slow?
Bad coil failing as it warms up?
Cracked or otherwise damaged distributor cap or rotor.
What does a vacuum gauge read at idle.
Do you have another carb to throw on it for testing?
Engines normally will run perfectly even without a battery if charging system is in order, doubt if it is failing battery.
Engine ground sound?
Run a jumper wire from battery positive to coil positive to rule out any ignition wiring issues.
Does engine have a ballast resistor in good condition.
Coil wire to dizzy sound?
Coil wires nice and snug?
Re: Bad battery cause of a rough idle? [Re: dart4forte] #2240378
01/24/17 01:35 PM
01/24/17 01:35 PM
Phoenix, AZ
Phoenix, AZ
After I replace the battery Ill swap in the old orange box and go for a drive.
Re: Bad battery cause of a rough idle? [Re: Belvedere1] #2240384
01/24/17 01:44 PM
01/24/17 01:44 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I have a bracket I bought from Hergfest that bolts to the firewall. I have the ECU bolted to the bracket. I also run a separate ground from the box. The bracket also allows for an airgap between the the box and the firewall.
Abe Lincoln
