Bad battery cause of a rough idle?
#2240184
01/24/17 12:46 AM
01/24/17 12:46 AM
Posts: 1,261 Phoenix, AZ
Belvedere1
Phoenix, AZ
Could a weak battery or one that is going south be the cause of a rough idle or miss at a hot idle? Everything is smooth with the idle, revs nicely and idles great up until the temp reaches 180 deg and then it wants to idle down really rough to the point of a miss and surge situation. Engine is a 451, solid cam 254/.520, MP electronic ign, MP distributor, chrome box, 800 Eddy carb, 20 deg initial timing. It will idle at 1000/1100 rpm when cold but as the temp comes up it will idle down to 600 or so. It runs really good except at idle. I'll have the battery tested here in the next day or so but just looking to see if this may be cause?
Re: Bad battery cause of a rough idle?
[Re: Belvedere1]
#2240190
01/24/17 12:54 AM
01/24/17 12:54 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
It could if it was drawing your system voltage down, like PacNorth says, what's the voltage?
[Re: Belvedere1]
#2240201
01/24/17 01:05 AM
01/24/17 01:05 AM
Posts: 21,845 Kirkland, Washington
Pacnorthcuda
I cant find my meter, so I'll take it out and have it tested. That's not going to tell you the whole picture. If you get 12.5 give or take on the batt, great. But the real story is the volts, while the engine is running rough.
[Re: Belvedere1]
#2240213
01/24/17 01:19 AM
01/24/17 01:19 AM
RapidRobert
but just looking to see if this may be cause? I'm thinking elsewhere. I would start by removing the idle mixture screws & shooting a 2 second blast of brake kleen in the (2) ports with the thin red straw then reinstall the screws. turn them in to lightly seated before removal & count the turns to easily return them to their original positions when done & they might need richening. carb might need cleaning. Keep us posted.
[Re: Belvedere1]
#2240224
01/24/17 01:39 AM
01/24/17 01:39 AM
RapidRobert
this just happened correct? Something changed (dirt or vac leak I'm guessing). I would still blast out the idle mixture ports (easy to do & not invasive)
[Re: Belvedere1]
#2240250
01/24/17 02:33 AM
01/24/17 02:33 AM
Posts: 16,163 Mesa, Arizona
dart4forte
Mesa, Arizona
Could a weak battery or one that is going south be the cause of a rough idle or miss at a hot idle? Everything is smooth with the idle, revs nicely and idles great up until the temp reaches 180 deg and then it wants to idle down really rough to the point of a miss and surge situation. Engine is a 451, solid cam 254/.520, MP electronic ign, MP distributor, chrome box, 800 Eddy carb, 20 deg initial timing. It will idle at 1000/1100 rpm when cold but as the temp comes up it will idle down to 600 or so. It runs really good except at idle. I'll have the battery tested here in the next day or so but just looking to see if this may be cause? Low voltage to a Orange box will eventually kill it. It's struggling to draw amperage from a weak system. As it starts to go south the motor may start backfiring. Put a good battery in the car and change out the box. Think it runs bad, try running an MSD with a bad battery.
Abe Lincoln
[Re: Belvedere1]
#2240253
01/24/17 03:01 AM
01/24/17 03:01 AM
Posts: 10,233 Someplace you aren't
SomeCarGuy
Do you run a choke? Maybe it masks a vac leak. Check ground for your ECU, but likely that would just kill it and not run rough. While at it check to see if VR is getting a good ground too.
I want my fair share
[Re: Belvedere1]
#2240254
01/24/17 03:02 AM
01/24/17 03:02 AM
dart4forte
Mesa, Arizona
I hope it hasn't started to wipe out the box. I do have a spare orange box that I ran for years with no issues. I just found the sticker on the battery and its much older than I thought, April 2010! I really don't know how it has lasted this long. Batteries here are good for about 2 years tops. Needless to say I will be getting a new battery. I would say that your box is toast. Doesn't take much for them to go. I've seen them loose their ground and pop. If you need a spare I have several laying around.
Abe Lincoln
[Re: Belvedere1]
#2240384
01/24/17 01:44 PM
01/24/17 01:44 PM
dart4forte
Mesa, Arizona
After I replace the battery Ill swap in the old orange box and go for a drive. I have a bracket I bought from Hergfest that bolts to the firewall. I have the ECU bolted to the bracket. I also run a separate ground from the box. The bracket also allows for an airgap between the the box and the firewall.
Abe Lincoln
