Vintage bias ply front tires, 6.70-15 or 7.10-15?? #2237829
01/20/17 01:05 PM
01/20/17 01:05 PM
Virginia
HemiStan Offline OP
HemiStan  Offline OP
Virginia
I am about to purchase some bias ply front tires for my '66 Satellite but am having some difficulty deciding what tires/rims I need. I am looking for a combination similar to what the cars would have run "back in the day". I have attached a few photos of what I am looking for. I was initially thinking a 4 1/2" wide wheel with a 7.10-15 tire but after looking at the recommended rim widths for that size, they are recommending a wheel closer to a 5 1/2 minimum width.
What did they run back in the day? A 6.70-15 tire on a 4 1/2" wheel or a 7.10-15 tire on a 5 or 5 1/2" wheel?
Thanks!
Stan
Re: Vintage bias ply front tires, 6.70-15 or 7.10-15?? [Re: HemiStan] #2237831
01/20/17 01:07 PM
01/20/17 01:07 PM
Virginia
HemiStan Offline OP
HemiStan  Offline OP
Virginia
Here are a couple more photos for reference.
Thanks!
Stan
Re: Vintage bias ply front tires, 6.70-15 or 7.10-15?? [Re: HemiStan] #2237841
01/20/17 01:23 PM
01/20/17 01:23 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Those are tall tires. The Moroso 7.10 front tire is 28" tall. The 7.60 is 29". I would guesstimate the 6.70 would be about 26". Not tall enough in my opinion.
Re: Vintage bias ply front tires, 6.70-15 or 7.10-15?? [Re: HemiStan] #2237886
01/20/17 02:24 PM
01/20/17 02:24 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I have 6.70-15s on a 4.5 inch Cragar on my car and this is what it looks like...
Re: Vintage bias ply front tires, 6.70-15 or 7.10-15?? [Re: GTX MATT] #2237887
01/20/17 02:25 PM
01/20/17 02:25 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Side profile
They're 28.5 inches tall, these are them
https://www.summitracing.com/parts/cok-568800/overview/
Re: Vintage bias ply front tires, 6.70-15 or 7.10-15?? [Re: HemiStan] #2237912
01/20/17 03:19 PM
01/20/17 03:19 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
There are vintage Stahl front runners, 7.10-15 on a 4" wide wheel. These came off an old Roadrunner Super Stocker. I put one on my Duster just for laughs, doesn't even remotely fit. Definitely need to be on a B body. They are REALLY tall for maximum run out.
Repro BFG Silvertowns look the part. Coker Tire sells Pro Trac front runners in various sizes.
'71 Duster
'72 Challenger
'17 Ram 1500
Re: Vintage bias ply front tires, 6.70-15 or 7.10-15?? [Re: HemiStan] #2237934
01/20/17 03:53 PM
01/20/17 03:53 PM
I started NHRA Stock class racing in the early 1970s, we ran 7.60.15 Firestones on 5.0 inch wide steelies on our 1968 GTX A/SA Hemi car, we later switch to a set of Fenton 4.0 aluminums wheels. A lot of the other Mopar B bodies ran 8.00x15 and 8.20x15 front tires up scope
I had a set of Stahl 8.20x15 on my 1963 Plymouth Belvedere stocker 415 HP M.W. car, I did have to turn the torsion bar height up a little bit to make them clear and steer better thumbs wrench
Re: Vintage bias ply front tires, 6.70-15 or 7.10-15?? [Re: Cab_Burge] #2238069
01/20/17 07:35 PM
01/20/17 07:35 PM
Virginia
HemiStan Offline OP
HemiStan  Offline OP
Virginia
Thanks for the replies and photos! I appreciate it.
My brother put a set of 7.10-15's on his '53 Coronet and they seem wider that the Moroso or Stahl 7.10's. If a set of "new" bias ply 7.10'-15's will fit on a 4 1/2" wheel, that is probably the way I will go.
RMCHGR: How wide is the treat pattern on those Stahls that you have?
Thanks.
Stan
Re: Vintage bias ply front tires, 6.70-15 or 7.10-15?? [Re: HemiStan] #2238076
01/20/17 07:59 PM
01/20/17 07:59 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
About 5" wide.
'71 Duster
'72 Challenger
'17 Ram 1500
Re: Vintage bias ply front tires, 6.70-15 or 7.10-15?? [Re: RMCHRGR] #2238332
01/21/17 11:44 AM
01/21/17 11:44 AM
moparx Online content
moparx  Online Content
back in my "nu-be" days, i once ran 7.10x15 b.f.goodrich silvertown's on 15x4 cragar ss wheels on my charger. used 50lbs. air pressure if i remember right. the tread width was only 4 1/4" on those tires.
beer
Re: Vintage bias ply front tires, 6.70-15 or 7.10-15?? [Re: moparx] #2238772
01/22/17 12:37 AM
01/22/17 12:37 AM
fullmetaljacket Offline
I used to run these vintage Super Stock Formula 1's before they started drying up too much to be safe at speed.
Wish some reputable company or Coker reproduced them and I'd be first in line.
Re: Vintage bias ply front tires, 6.70-15 or 7.10-15?? [Re: HemiStan] #2238777
01/22/17 12:44 AM
01/22/17 12:44 AM
Utah, USA
1964superstock Offline
Utah, USA
Other supplier of vintage tall skinny tires for corvettes and thunderbirds. The real reason these tires are made however. But they happen to fit old mopars too.
Coker tires does not seem to have the greatest reputation.
http://www.forwardlook.net/forums/forums/thread-view.asp?tid=28798
1. http://www.kelseytire.com/pages/antique&classictires.html (Dealer for Goodyear Super Cusion tires)
2. http://www.mamotorworks.com/corvette-1-297.html
3. http://www.widewhitetires.com/GoodyearCollector.html
4. http://www.zip-corvette.com/ProductDetails/ProductDetails.aspx?pid={9efe31f1-7f8f-496d-b5e4-54a69f0222e3}&gid={f864e68e-bf1d-428f-a3a5-2ee83fd43515}&GroupName=Goodyear&pname=62-64+Goodyear+Super+Cushion+Tire+-+1%22+Whitewall&Referer=&Alias=&ptct=SGR-SR&CTitle=&
5. Willies Antique Tires
Classic tyre stockists
5257 W Diversey Avenue
Chicago
Illinois
IL 60639
USA
Tel: +1 773 622 4037
Fax: +1 773 622 0623
6. http://www.lucasclassictires.com/
http://www.lucasclassictires.com/biasprices031611r2.htm
800-952-4333
2850 Temple Ave., Long Beach, CA 90806
Phone 562-595-6721 • Fax 562-595-0381
Hours: 9am - 5pm Pacific Time
Monday - Friday
7. http://www.dbtires.com/tires.html Radial tires that look old, such as redlines.
Re: Vintage bias ply front tires, 6.70-15 or 7.10-15?? [Re: HemiStan] #2238786
01/22/17 12:55 AM
01/22/17 12:55 AM
Utah, USA
Utah, USA
7.10 X 15 bias ply silvertown tires from Coker tire. Nearly 28 inches tall and skinny. Mosher uses these tires all the time.
https://www.cokertire.com/710-15-bf-goodrich-blackwall.html
http://www.etmags.com/vintage_v.html
Video showing these tires mounted on ET Vintage V 15x4 mags, installed on beautiful '63 Plymouth Savoy at Moshers.
https://www.youtube.com/watch?v=qzyDNmand7Y
http://www.moparsbymosher.com/projects/gregberrys63/assembly/004-x2.htm
Re: Vintage bias ply front tires, 6.70-15 or 7.10-15?? [Re: HemiStan] #2238789
01/22/17 12:59 AM
01/22/17 12:59 AM
Utah, USA
Utah, USA
Few other options. I bought some 7.10x15 Goodyear supercushion tires from Kelsey tires a few years ago. I'm not sure if they still make that particular size, but they look great.
http://www.mamotorworks.com/Corvette/product/tire-goodyear-super-cushion-blackwall-bias-ply-643137-1
http://www.mamotorworks.com/Corvette/product/goodyear-power-cushion-blackwall-bias-ply-tire-643142-1
Re: Vintage bias ply front tires, 6.70-15 or 7.10-15?? [Re: HemiStan] #2238930
01/22/17 12:25 PM
01/22/17 12:25 PM
Minn
SportF Offline
SportF  Offline
Minn
With Firestone 6.70 15's on my 62 Dodge, they hit on one side, barely fit on my 63 Plymouth (as Cab stated). Might want to mock something up before buying.
Re: Vintage bias ply front tires, 6.70-15 or 7.10-15?? [Re: HemiStan] #2239268
01/22/17 06:55 PM
01/22/17 06:55 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I used the Pro-Trac Competition Front from Coker Tire size 215/70/15 on my Savoy. They worked and looked well for a strip car but you really wouldn't want to do any cornering with them.
Very small contact patch and they push into the corner. They have a fat sidewall width and a 3" tread width. I'm on the street more now so I replaced them with M/T S/T radials and The car handles better but doesn't look as cool shruggy
Gus beer
64 Plymouth Savoy
Dana 60
Re: Vintage bias ply front tires, 6.70-15 or 7.10-15?? [Re: HemiStan] #2239511
01/23/17 12:25 AM
01/23/17 12:25 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I ran the Moroso 7.10 on my street/strip car for 20 years.When I updated the rims I went with the MT fronts to match the ET Streets out back.
They are good in the street and have been 145 mph in the 1/4.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Vintage bias ply front tires, 6.70-15 or 7.10-15?? [Re: hemi-itis] #2239704
01/23/17 11:54 AM
01/23/17 11:54 AM
Virginia
HemiStan Offline OP
HemiStan  Offline OP
Virginia
Thanks for the pictures and information everyone! That helps out a lot. It looks like I am leaning towards a vintage style bias-ply 7.10-15 on a 4 1/2 wide rim. I haven't totally decided on which tire I am going with. I think I like the tires with the slight pie crust edge like the vintage Stahls. I will have to check the different suppliers and see what is out there.
Thanks again!
Stan
Re: Vintage bias ply front tires, 6.70-15 or 7.10-15?? [Re: HemiStan] #2239706
01/23/17 11:56 AM
01/23/17 11:56 AM
hemi-itis Offline
hemi-itis  Offline
Check that the speed rating is good for the speed you will go!
Re: Vintage bias ply front tires, 6.70-15 or 7.10-15?? [Re: hemi-itis] #2239712
01/23/17 12:07 PM
01/23/17 12:07 PM
And the weight carrying abilities as per the side wall ply.
