Re: 64 plymouth question / engine tranny swap
[Re: doba]
#2234156
01/14/17 07:12 PM
01/14/17 07:12 PM
Posts: 4,715 Wichita
GY3
Wichita
What headers will fit a 360 in a 64 plymouth belvedere and what hasta be done to put in the newer 727 trans with a floor shifter? Thanks Unsure of the headers as I've never run a SB in one. Use the Schumacher/Imperial Services trans mount and the later 727 bolts in to the older crossmember.
[Re: doba]
#2234211
01/14/17 08:37 PM
01/14/17 08:37 PM
Posts: 10 SESD
doba
SESD
Probably going to be using some type of a ratchet shifter my buddy has a Hurst promatic that might end up in it.. I really do like the old pushbutton trans but the one I got from my duster is freshly rebuilt with a manual valve body so if I can make it work out I will for now.. I know I can use later headers if I swap out to the later k frame but I don't really want to go that route.. I seen a 64 at my local track last year with a 360 in it wish I would asked the guy a few questions about it now lol
