Isky rockers & shafts #2231415
01/10/17 03:52 AM
01/10/17 03:52 AM
Australia
P
Project kickin A Offline OP
P
Australia
I have a set of old Isky iron rockers here and the shafts they came with look like stock shafts, I'm thinking of using a pair of Harland Sharp shafts I have spare just wondering if its going to cause any issues?
Re: Isky rockers & shafts [Re: Project kickin A] #2231535
01/10/17 12:44 PM
01/10/17 12:44 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
HS shafts have a hard chrome surface because they use roller bearings in their rockers. I seem to recall rollers don't like plain steel shafts and non-roller rockers don't like hard chrome shafts. When I had those Isky rockers I used TRW shafts which were a stock replacement BUT are thicker and stronger with a polished finish. What you really want is a shaft that's going to stay round - unlike the stockers that went oval when you torqued them down. HS's are expensive. See if TRWs are still available or something like Hughes maybe.
Re: Isky rockers & shafts [Re: Project kickin A] #2231598
01/10/17 01:56 PM
01/10/17 01:56 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Have bronze bushings installed and the rocker arms blueprinted. They will work better with the hardened shafts.
Re: Isky rockers & shafts [Re: Project kickin A] #2231636
01/10/17 03:03 PM
01/10/17 03:03 PM
Washington
madscientist Offline
Washington
There was a place called Rocker Arm Specialties. I don't know the name any more. They can bush your rockers if you want, change the ratio a bit (IIRC) and probably have shafts in stock.
You'll have to google it as I think the name has changed.
Re: Isky rockers & shafts [Re: Project kickin A] #2231802
01/10/17 07:20 PM
01/10/17 07:20 PM
If your going to buy new rocker arm shafts buy the ones you need directly from Isky twocents Or buy a set of his special made H.D. banana grooved shafts for those ductile iron rocker arms from Gary at RAS,530-242-1316 twocents
Re: Isky rockers & shafts [Re: madscientist] #2231804
01/10/17 07:24 PM
01/10/17 07:24 PM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
Originally Posted By madscientist
There was a solace called Rocker Arm Specialties. I don't know the name any more. They can bush your rockers if you want, change the ratio a bit (IIRC) and probably have shafts in stock.
Their name the last time I checked was Rocker Arms Unlimited. I had a set of Isky's done by them a few years ago but, I'd heard the company changed hands again since then.
They narrowed each rocker arm, bored and bushed them and provided all new hardware, shafts and hold downs. I think I paid a little over $500.
They are a work of art and are set up, spaced and ready to bolt on but, be prepared to wait. I was quoted a 2-3 week turn around time but, it was more like 3-4 months.
I'd use them again but, just not for anything I needed quickly.
I believe the name of the original owner who came back to the new company is Gary. He answers the phone; give them a call.
