Re: Icon piston feedback
[Re: Blown 68 R/T]
#2230877
01/09/17 04:12 PM
01/09/17 04:12 PM
Posts: 5,080 organ
maximum entropy
organ
i've used a bunch of 'em with no issues.
[Re: Blown 68 R/T]
#2230927
01/09/17 05:51 PM
01/09/17 05:51 PM
Posts: 2,933 Finalnd, Perkele
jyrki
Finalnd, Perkele
It depends of many things, but it's propably not a brand thing. Like said above, usually the thinnest point is between the intake valve pocket and the top ring land. I believe this depends of the application, how deep and large are teh valve reliefs and how high is the top ring land. We have used Icons in boosted application, it's a 400 with 4.15" stroke 440 pistons, and so far no problems. But if you plan to make big power you should use custom pistons for boosted application.
Plynouth VIP '67 TT IC EFI
[Re: FastmOp]
#2230928
01/09/17 05:51 PM
01/09/17 05:51 PM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
I run 30 pounds of boost on the 440source icons. No issues You are my hero lol. I love both of your cars on so many levels. It would be cool to see an expose on the a-body and the new car too. I've been a fan ever since the driveway burn out video from way back!
[Re: jyrki]
#2230941
01/09/17 05:59 PM
01/09/17 05:59 PM
KOS
It depends of many things, but it's propably not a brand thing. Like said above, usually the thinnest point is between the intake valve pocket and the top ring land. I believe this depends of the application, how deep and large are teh valve reliefs and how high is the top ring land. We have used Icons in boosted application, it's a 400 with 4.15" stroke 440 pistons, and so far no problems. But if you plan to make big power you should use custom pistons for boosted application. BINGO !!!
[Re: Jeremiah]
#2231065
01/09/17 08:31 PM
01/09/17 08:31 PM
Posts: 5,762 Hot Rod Ridge
FastmOp
Hot Rod Ridge
I run 30 pounds of boost on the 440source icons. No issues You are my hero lol. I love both of your cars on so many levels. It would be cool to see an expose on the a-body and the new car too. I've been a fan ever since the driveway burn out video from way back! Thanks for the kind words. 😉 I forgot about those old driveway videos lmao😎 I built a launch pad at the new place, I have a starting line and 60 foot lay'd out lol. My cars are not show cars, there just rough ole hot rods that I have a lot of fun with 😆 Did you use to be in the old mofarts chat room with Blown71X and AL and Devil and the rest of the crew? Was thinking you might be Hay-zuse 😈
[Re: Blown 68 R/T]
#2231073
01/09/17 08:42 PM
01/09/17 08:42 PM
Posts: 7,506 Az
Crizila
Az
Need new pistons for 440 Procharged street/strip motor. Had Diamonds then used Probe. Been looking at Icon, need the 2618's to handle the boost. Are they decent or should I look at Diamond, JE or Ross?? Recommended by my Engine builder. I runem in my Procharged small block with as much as 20 psi boost - 110 race gas and water injection - no cooler.
Fastest 300
