Re: A833 Three Number Stamp
[Re: ogopogo]
#2916817
04/30/21 03:53 AM
04/30/21 03:53 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
The numbers on my transmission were 2" high, 2-3/8" wide. I downloaded for free the font Placard Condensed (not Placard MT Std Cond which is similar but not as correct) and made a master "602" with numbers 2" high. I think the rubber stamp needs some margin around the perimeter, so it needs to be slightly larger.
At RubberStamps.net, I uploaded my master and ordered a stamp 2.5" high x 3" wide, part number WOODSTAMP77, about $24. This is one stamp with three numbers, which is better than three stamps of one number each..
Because the margin around the rubber part of the stamp in the last photo seems unnecessarily large, it looks like maybe I could have ordered a smaller stamp 2.25" high x 2.5" wide, but I don't know if that size is available.
[Re: ogopogo]
#2916848
04/30/21 08:14 AM
04/30/21 08:14 AM
Posts: 892 MA
steve70
MA
Anyone have the dimensions of this stamp ,height by width?
1970 Challenger T/A 4 speed
[Re: ogopogo]
#2922208
05/13/21 07:11 PM
05/13/21 07:11 PM
Posts: 3,267 Connecticut
1972CudaV21
Connecticut
On the tail shaft of a 727 transmission, I’ve seen hand-painted numbers with 3 digits. Is there any relationship between the 3 numbers and a part number?
China is the enemy.
[Re: srt]
#2922688
05/15/21 04:34 AM
05/15/21 04:34 AM
1972CudaV21
Connecticut
Don't quote me on this, I read here years ago that designates the prop shaft to be used. If anyone can verify, I'd like to hear, and also find out if there is a spreadsheet. Are you referring to the driveshaft yoke?
China is the enemy.
[Re: srt]
#2922931
05/15/21 07:20 PM
05/15/21 07:20 PM
1972CudaV21
Connecticut
I believe it may have to do with the assembly number of the driveshaft. Post (or article) I read years ago and probably have it filed someplace. Again do not quote me on this. It may have been sonething aboiut the yokes at each end. i.e. trac pac behind an auto vs 4 speed a non hemi / 440 was spec'ed for a dana may have required different rear yoke? What was the tail shaft you have from? That image is from an online magazine and not mine. I’m rebuilding my 727 and I’d like to learn more about inspection marks, numbers, etc. Here is another from a member on here:
China is the enemy.
