Air cleaner #2228787
01/06/17 06:44 PM
01/06/17 06:44 PM
Washington
madscientist Offline OP
Washington
I need an air cleaner. I have a junk chrome deal now, that needs an adapter. I'm good and sick of it.
So what air cleaner do I need that will fit a 4150, and not kill power? Need it under the hood on a small block with a Strip Dominator.
I like the looks of the K&N with the filter top and I've used K&N filters since sometime in the 70's when they came out, but I don't want to kill any power, or at least limit my loss.
What says MoParts?????????????
Re: Air cleaner [Re: madscientist] #2228795
01/06/17 07:01 PM
01/06/17 07:01 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
R2C. Check out their basses and lids. They dont like cotton filters or lids. I use a wix filter
Re: Air cleaner [Re: mopar dave] #2228805
01/06/17 07:20 PM
01/06/17 07:20 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
All air filters are a RESTRICTION!
FACT!
haha laugh2
'63 Dodge 330
11.19 @ 121 mph
Re: Air cleaner [Re: GY3] #2228806
01/06/17 07:26 PM
01/06/17 07:26 PM
MR_P_BODY Offline
Happy Birthday MR_P_BODY  Offline
FACT!
haha laugh2
If you only knew what your laughing at tsk
some day you MIGHT learn
wave
Re: Air cleaner [Re: madscientist] #2228809
01/06/17 07:30 PM
01/06/17 07:30 PM
MR_P_BODY Offline
How big can you get away with... 14" dia...
how tall.. I will go out to the shop and see
what element I have out there... its rated at
1000 cfm and is 2" tall.. I didnt see that they
offered a 3" but the 2" flows more than the K&M 3"
EDIT
Wix racing... 1000+ cfm
wave
Re: Air cleaner [Re: madscientist] #2228822
01/06/17 07:42 PM
01/06/17 07:42 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
WIX Racing paper..............best filter I ever used and gave and threw away my K&N choking junk.........
Re: Air cleaner [Re: madscientist] #2228823
01/06/17 07:43 PM
01/06/17 07:43 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I like the 16" dia. spun aluminum ones that the roundy-round guys use. K&N use to have a nicely shaped 16" base and lid too.
Re: Air cleaner [Re: MR_P_BODY] #2228832
01/06/17 07:57 PM
01/06/17 07:57 PM
Washington
Washington
EDIT
wave
I think with the flat base that is on there now I can only get a 2 inch filter on there. It's not a good filter on there now.
With the right base I think I can go 3 inch by 14 in diameter.
Re: Air cleaner [Re: mopar dave] #2228834
01/06/17 07:58 PM
01/06/17 07:58 PM
Washington
Washington
I'll google R2C and have a look.
Thanks.
Re: Air cleaner [Re: madscientist] #2228836
01/06/17 08:02 PM
01/06/17 08:02 PM
MR_P_BODY Offline
EDIT
wave
If you go with a high flow element a 2" will
out flow a 3" from most companies.. myself..
I dont care for the drop base units BUT if you
have to then you have to.. but still go with
the high flow element
EDIT
If you go with Wix make sure its a RACE element
for the added flow
wave
Re: Air cleaner [Re: madscientist] #2228841
01/06/17 08:08 PM
01/06/17 08:08 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
EDIT
wave
WIX has a cfm chart and the 14x3 I use flows around 1000 cfm iirc......
Re: Air cleaner [Re: madscientist] #2228852
01/06/17 08:25 PM
01/06/17 08:25 PM
East Coast
A/MP Offline
A/MP  Offline
East Coast
I cannot speak about the Wix race filter because I have not done any true testing. I went from the 2" Wix race to the K&N 4". I went faster with the K&N and now more consistent. Since I have not tried a 4" Wix(not sure if it exists) this cannot be a true comparison. Nonetheless, what that tall K&N filter(w/o oil)will do, is straighten out the air flow and give a better and consistent signal to the carb. Thinking about the K&N stack with filter 5"filter/5" stack. I do not go 200 + mph in the 1/4 but the Pro Stocks do and they use K&N filters to stabilize the air that enters the carbs(pre- 2016).
Re: Air cleaner [Re: Thumperdart] #2228854
01/06/17 08:28 PM
01/06/17 08:28 PM
MR_P_BODY Offline
Wix refers the high flow ones as "Advanced
Performance Filters"... here is a 14" X 3.01"
283-46945R... rated at 1000+ cfm
wave
Re: Air cleaner [Re: madscientist] #2228866
01/06/17 08:40 PM
01/06/17 08:40 PM
Texas
mprhound Offline
mprhound  Offline
Texas
Look at R2C dry cleanable element also, I have used it the past 2 dragweeks and am very happy with it
Re: Air cleaner [Re: BSB67] #2228932
01/06/17 10:31 PM
01/06/17 10:31 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I have one of those for my dominator. They are nice.
Re: Air cleaner [Re: madscientist] #2228989
01/06/17 11:38 PM
01/06/17 11:38 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Small air filters are a RESTRICTION!
Fixed that for you.
Boffin Emeritus
Re: Air cleaner [Re: mopar dave] #2228990
01/06/17 11:40 PM
01/06/17 11:40 PM
Washington
Washington
Damn those things are very nice, but do they fit a BLP B4X carb???????
Re: Air cleaner [Re: madscientist] #2229009
01/06/17 11:55 PM
01/06/17 11:55 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
They fit a standard dominator. Heres mine. I painted the lid.
Re: Air cleaner [Re: madscientist] #2229010
01/06/17 11:55 PM
01/06/17 11:55 PM
MR_P_BODY Offline
What I'm putting on my Rampage is a dual snorkel
so I can run tubing forward down to opening in
my fascia... nice big snorkels so I can run a 4"
tube for each side... I have a cowl hood but I
want to pick up the air from the front end
wave
Re: Air cleaner [Re: MR_P_BODY] #2229020
01/07/17 12:02 AM
01/07/17 12:02 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Thats most likely the best way. Nice cool air.
