10x1.75 B body brake drum with 4.5" bolt pattern - HELP #2227320
01/04/17 08:21 PM
01/04/17 08:21 PM
Toronto, Ontario, Canada
plazomat Offline OP
plazomat  Offline OP
Happy New Year!!!
So I guess I got an odd ball case, 1 69 Plymouth B body with 7.25 rear end 10x1.75 brake drums with 4.5" bolt pattern.
Anyone know how to get a new set of drums? the ones I have are old and crusty and won't last much longer.
I read somewhere jeep drums could be used with some sparky persuation but after a few hours on the google still can't find the post..
Anyone have a solution?
Plaz
Re: 10x1.75 B body brake drum with 4.5" bolt pattern - HELP [Re: plazomat] #2227345
01/04/17 09:03 PM
01/04/17 09:03 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Re: 10x1.75 B body brake drum with 4.5" bolt pattern - HELP [Re: John_Kunkel] #2227353
01/04/17 09:10 PM
01/04/17 09:10 PM
plazomat Offline OP
plazomat  Offline OP
Yikes....I guess when you have unobtainium the price is yours to set...at least it gives the orginal mopar P/Ns to help chase..
Plaz
Re: 10x1.75 B body brake drum with 4.5" bolt pattern - HELP [Re: plazomat] #2227383
01/04/17 09:58 PM
01/04/17 09:58 PM
kinda WAG ing but what about some SBP drums (I bought new Centric ones last year, overseas items but were cheap) & redrill em to BBP? & precision open up the registers or just meatball open em up & use lug centric lug nuts. for the pattern make a 4.5" circle (takes a bit of work cuz the register is open) so harder to locate the center dot location & make a pinpoint mark anywhere appropriate on the drum on that circle then make another pinpoint mark on the circle on a straight tangent line 2.645" away then (3) more then drill the five of em out on your drill press. with care on the dia of those 5 holes you might be able to locate the drum that way & use hub centric wheels/lug nuts.
Re: 10x1.75 B body brake drum with 4.5" bolt pattern - HELP [Re: RapidRobert] #2227392
01/04/17 10:11 PM
01/04/17 10:11 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
That won't work, there isn't anywhere near enough offset in the center of an SBP drum to re-drill.
I'm really not sure why you're running a 7 1/4. Might be time to either 1, install 10x2.5 brakes or 2, swap to an 8 1/4 or 8 3/4 axle.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: 10x1.75 B body brake drum with 4.5" bolt pattern - HELP [Re: plazomat] #2227402
01/04/17 10:22 PM
01/04/17 10:22 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Doc diff has a complete 10x2 1/2" rear drum assembly, backing plate and all, for less than those two drums. Unfortunately, he is out of stock right now.
Don't be the exception.
Re: 10x1.75 B body brake drum with 4.5" bolt pattern - HELP [Re: goldduster318] #2227403
01/04/17 10:23 PM
01/04/17 10:23 PM
Noted
Re: 10x1.75 B body brake drum with 4.5" bolt pattern - HELP [Re: goldduster318] #2227459
01/04/17 11:28 PM
01/04/17 11:28 PM
plazomat Offline OP
plazomat  Offline OP
I have a 8.75 waiting to get rebuilt, needed a band-aid for now. few other projects need to get done on car before rear end swap...
jeep used a rear drum that was 10 * 1.75 it needed some small mods from I can recall - just gotta find that post...
Plaz
Re: 10x1.75 B body brake drum with 4.5" bolt pattern - HELP [Re: plazomat] #2228518
01/06/17 11:44 AM
01/06/17 11:44 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
I have almost new 10-1-3/4 drums. And I also have whole set up for 10-2-1/2 drums plates shoes wc almost new
Re: 10x1.75 B body brake drum with 4.5" bolt pattern - HELP [Re: plazomat] #2231394
01/10/17 03:13 AM
01/10/17 03:13 AM
plazomat Offline OP
plazomat  Offline OP
What are you asking for the 10-1-3/4 drums?
Plaz
Re: 10x1.75 B body brake drum with 4.5" bolt pattern - HELP [Re: plazomat] #2231557
01/10/17 01:04 PM
01/10/17 01:04 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
I paid 100 each for them and they have 25 1/4 mile passes
