10x1.75 B body brake drum with 4.5" bolt pattern - HELP
#2227320
01/04/17 08:21 PM
01/04/17 08:21 PM
Posts: 643 Toronto, Ontario, Canada
plazomat
Happy New Year!!!
So I guess I got an odd ball case, 1 69 Plymouth B body with 7.25 rear end 10x1.75 brake drums with 4.5" bolt pattern.
Anyone know how to get a new set of drums? the ones I have are old and crusty and won't last much longer.
I read somewhere jeep drums could be used with some sparky persuation but after a few hours on the google still can't find the post..
Anyone have a solution?
Thanks Plaz
Re: 10x1.75 B body brake drum with 4.5" bolt pattern - HELP
[Re: plazomat]
#2227383
01/04/17 09:58 PM
01/04/17 09:58 PM
RapidRobert
kinda WAG ing but what about some SBP drums (I bought new Centric ones last year, overseas items but were cheap) & redrill em to BBP? & precision open up the registers or just meatball open em up & use lug centric lug nuts. for the pattern make a 4.5" circle (takes a bit of work cuz the register is open) so harder to locate the center dot location & make a pinpoint mark anywhere appropriate on the drum on that circle then make another pinpoint mark on the circle on a straight tangent line 2.645" away then (3) more then drill the five of em out on your drill press. with care on the dia of those 5 holes you might be able to locate the drum that way & use hub centric wheels/lug nuts.
[Re: RapidRobert]
#2227392
01/04/17 10:11 PM
01/04/17 10:11 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
kinda WAG ing but what about some SBP drums (I bought new Centric ones last year, overseas items but were cheap) & redrill em to BBP? & precision open up the registers or just meatball open em up & use lug centric lug nuts. for the pattern make a 4.5" circle (takes a bit of work cuz the register is open) so harder to locate the center dot location & make a pinpoint mark anywhere appropriate on the drum on that circle then make another pinpoint mark on the circle on a straight tangent line 2.645" away then (3) more then drill the five of em out on your drill press. with care on the dia of those 5 holes you might be able to locate the drum that way & use hub centric wheels/lug nuts. That won't work, there isn't anywhere near enough offset in the center of an SBP drum to re-drill. I'm really not sure why you're running a 7 1/4. Might be time to either 1, install 10x2.5 brakes or 2, swap to an 8 1/4 or 8 3/4 axle.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
[Re: plazomat]
#2227402
01/04/17 10:22 PM
01/04/17 10:22 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Doc diff has a complete 10x2 1/2" rear drum assembly, backing plate and all, for less than those two drums. Unfortunately, he is out of stock right now.
[Re: goldduster318]
#2227403
01/04/17 10:23 PM
01/04/17 10:23 PM
RapidRobert
That won't work, there isn't anywhere near enough offset in the center of an SBP drum to re-drill. Noted
