RB A body headers #2225815
01/02/17 07:59 PM
01/02/17 07:59 PM
Virginia Beach, VA
O
Old School Offline OP
O
Virginia Beach, VA
Getting ready to install my 588" RB in my 68 cuda. It has Indy 572-13 heads. It also has a Hemi Denny coil over front end. It will also have a motor plate. Do not want fenderwell or partial fenderwells. Would TTI headers be my best choice? Looking for the most room to work on the car.
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: RB A body headers [Re: Old School] #2225832
01/02/17 08:18 PM
01/02/17 08:18 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I don't believe there is a "correct" raised exhaust port/RB engine/A body header offered from TTI, although with your aftermarket front end parts the B/E body version might fit.
Re: RB A body headers [Re: Old School] #2225939
01/02/17 10:49 PM
01/02/17 10:49 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
a custom header would be money well spent.... "IF" there is someone near you to do the task.
Re: RB A body headers [Re: J_BODY] #2225995
01/02/17 11:56 PM
01/02/17 11:56 PM
Virginia Beach, VA
O
O
Virginia Beach, VA
Does anybody have any reviews for chris acor at acors performance? he is pretty close to me, so maybe thinking about a set of custom stainless headers and full exhaust.
Re: RB A body headers [Re: Old School] #2226016
01/03/17 12:22 AM
01/03/17 12:22 AM
North Carolina
Jake W Offline
Jake W  Offline
North Carolina
Since your in Virginia Beach Mike Balf Racecars is by far the best place to go locally. He and a few if his guys make some badass stainless headers for most of the fast drag cars around.
757-200-4616
5776 Arrowhead Dr # 110
Virginia Beach, VA 23462
Re: RB A body headers [Re: Jake W] #2226020
01/03/17 12:27 AM
01/03/17 12:27 AM
Virginia Beach, VA
O
O
Virginia Beach, VA
757-200-4616
Awesome thanks Jake I will check them out tomorrow
Re: RB A body headers [Re: Old School] #2226160
01/03/17 05:33 AM
01/03/17 05:33 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Forget about working on the car without cutting and drilling holes in things for access. Fenderwalls are your best bet for still being able to work on the car. That big engine is going to need some Abby enormous pipes!
Re: RB A body headers [Re: Dave Hall] #2226279
01/03/17 01:34 PM
01/03/17 01:34 PM
with how pricey they are, an option would be a weld up header kit from speedway motors or others. the SM one is cheap & all you would need is a chop saw and someone who is a good welder & some trial & error fitment.
Re: RB A body headers [Re: Old School] #2226350
01/03/17 03:20 PM
01/03/17 03:20 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I have TTIs on a 512 RB in a Duster, Indy EZ heads; spark plug access on right side for #s 2, 4 & 6 is pretty tough and the car doesn't have a motor plate. Can't imagine accessing #s 2 & 4 if it had a plate.
Re: RB A body headers [Re: topside] #2226541
01/03/17 08:12 PM
01/03/17 08:12 PM
Why do you think having a front motor plate would make getting to those spark plugs worse confused shruggy
I've used both stock BB A body motor mounts with several different brands of headers and stock A body exhaust manifolds and I've had BB A body race and street cars with front motor plate and getting to the plugs, especially on the passenger side with either is not easy or really hard to me confused The front motor plate allows you to set up the crankshaft height and center line to your preferences up Not so with stock type mounts or adapter mounts shruggy
I was spoiled on the first three BB A body cars that I had and raced, they all had Hooker fender well headers on them, changing plugs was a breeze whistling
Re: RB A body headers [Re: Cab_Burge] #2226575
01/03/17 09:06 PM
01/03/17 09:06 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I imagine he goes under the 2-4 header from the front to change plugs, depending on plate used = difficulty.
Re: RB A body headers [Re: cudaman1969] #2226626
01/03/17 09:53 PM
01/03/17 09:53 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Yep... I have Hedman B-body headers on my lowdeck A-body with Andy's motor plate, which makes for easier plug access than the OP's combo, and
I can only reach #2 and #4 from under the car. #6 is simply impossible without the 1-1/2" access hole I drilled in the inner fender sawzall
It's been a long time since I ran Hooker fenderwells with an RB A-body but don't remember thinking that plug access was "a breeze" even back then wink
Re: RB A body headers [Re: DrCharles] #2226861
01/04/17 01:38 AM
01/04/17 01:38 AM
Mt.Vernon IL
Twin Turbo Mower Offline
Mt.Vernon IL
I have these for my dart 572-13 heads indy rb block and alterkation coil over front suspension and motor plate.
Header #440-214
2-1/4" 572-13 STEP HEADERS
Some of the lower tubes hit the cross bolts for the mains and had to be dinged. The #7 tube had to be dinged for the steering shaft. The old upper shock mount on the passenger side had to be cut out on the corner for the #2 tube that goes over #4 and #6 tubes.
Re: RB A body headers [Re: cudaman1969] #2226909
01/04/17 03:21 AM
01/04/17 03:21 AM
I never had to use anything other than a spark plug socket and or a 5/8 or 13/16 box end wrench to remove them, all the fenderwell header pipes went up and back towards the cut out in the inner fenderwells on both the Hookers and Hedman BB A body headers thumbs scope
Re: RB A body headers [Re: Twin Turbo Mower] #2226982
01/04/17 10:56 AM
01/04/17 10:56 AM
Virginia Beach, VA
O
O
Virginia Beach, VA
Header #440-214
would you have pics of the headers? Thanks
Re: RB A body headers [Re: Old School] #2227156
01/04/17 03:39 PM
01/04/17 03:39 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Yup, Cab & Cudaman - gotta reach in from the front to access 2 & 4 with the TTIs.
Re: RB A body headers [Re: Old School] #2227375
01/04/17 09:34 PM
01/04/17 09:34 PM
Virginia Beach, VA
O
O
Virginia Beach, VA
I'm on the list for some custom stainless steel headers.should be next month. Actually building the whole exhaust in stainless. Going with 2 1/4" with a 4"collector.
Re: RB A body headers [Re: Old School] #2227376
01/04/17 09:36 PM
01/04/17 09:36 PM
Mt.Vernon IL
Mt.Vernon IL
Header #440-214
My engine is out of the car right now as I had my heads milled. Do you want pics of them out of the car or when its together? I do not think I took any with these headers in the car. My previous set was on my old motor which was a low deck 556 with tti 2" to 2 1/8".
