Anyone have an old CRANE cam catalog?
#2225813
01/02/17 07:54 PM
01/02/17 07:54 PM
Posts: 1,058 Dallas, Texas
FC7cuda
Dallas, Texas
Need help identifying the specs for this cam please.
Thanks Tom
68 Charger 70 Cuda
Re: Anyone have an old CRANE cam catalog?
[Re: FC7cuda]
#2225851
01/02/17 08:51 PM
01/02/17 08:51 PM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
It's not in my 2010 catalog, but going by the numbers it should be:
solid flat tappet, 275@.050, .400 lobe lift, 104lsa.
[Re: FC7cuda]
#2226524
01/03/17 07:43 PM
01/03/17 07:43 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
You can contact Crane and they will give you the info on the cam.
[Re: FC7cuda]
#2226570
01/03/17 09:00 PM
01/03/17 09:00 PM
Posts: 1,826 South Bend
John Brown
South Bend
Thanks Tom In my 78 and 79 catalogue I'm showing a F275/400-8 cam for 273-340-360 and 67-79 318 LA, if that comes close to being what your cam is made to fit. Crane says 275 degrees @.050, 316-316 degrees advertised, 108 centerline on this one though yours appears to be ground on a 104 centerline, .028 hot on intake, .030 hot on exhaust, 0.600 gross valve lift on intake and 0.600 gross valve lift on exhaust also.
[Re: FC7cuda]
#2226656
01/03/17 10:32 PM
01/03/17 10:32 PM
FC7cuda
Dallas, Texas
Thanks everyone, I'll contact Crane to be sure, but it sounds like John hit the nail!
Tom
68 Charger 70 Cuda
