Re: Cold weather 400 block.
[Re: 70dusterjohn]
#2225564
01/02/17 02:15 PM
01/02/17 02:15 PM
Thumperdart
State of confusion
We busted our block #2 and it was half filled .. Had it sleeved and is still living .. Heck I have seen a buddies 400 all but one need sleeves so he did all 8 half filled and 12 years later still running 9 flat .. Street driven a lot .. My 2 cents YEP and Pettis does em all day long...........
[Re: mopar dave]
#2225652
01/02/17 04:23 PM
01/02/17 04:23 PM
Posts: 4,457 Washington
madscientist
Washington
I have installed literally hundreds of sleeves.
If a machine shop can't or won't do a sleeve it's time to move on.
It's a very basic machine operation.
[Re: 70dusterjohn]
#2225679
01/02/17 04:50 PM
01/02/17 04:50 PM
Posts: 4,072 Mo.
racerx
Mo.
We busted our block #2 and it was half filled .. Had it sleeved and is still living .. Heck I have seen a buddies 400 all but one need sleeves so he did all 8 half filled and 12 years later still running 9 flat .. Street driven a lot .. My 2 cents Interesting... @ what weight was his car? The reason I'm asking is cause as the saying goes weight kills parts ,so curios of the weight at 9.0's.
[Re: madscientist]
#2225685
01/02/17 04:55 PM
01/02/17 04:55 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
It's a very basic machine operation. Just curious but how much would it cost to buy, install, bore, and finish hone 8 sleeves?
[Re: pittsburghracer]
#2225692
01/02/17 05:02 PM
01/02/17 05:02 PM
madscientist
Washington
It's a very basic machine operation. Just curious but how much would it cost to buy, install, bore, and finish hone 8 sleeves? I used to charge 25-40 for the sleeve, depending on the sleeve and 85 dollars for the first hole. To do a V8 total was 450 plus the sleeves. I save at least 6 different T/A blocks plus I can't say how many fork lift engines plus all the 1 and 2 sleeve deals I did. When done correctly, you'd be hard pressed to even see the sleeve.
[Re: racerx]
#2225721
01/02/17 05:40 PM
01/02/17 05:40 PM
Posts: 1,613 Deerfield, Ohio
70dusterjohn
Deerfield, Ohio
We busted our block #2 and it was half filled .. Had it sleeved and is still living .. Heck I have seen a buddies 400 all but one need sleeves so he did all 8 half filled and 12 years later still running 9 flat .. Street driven a lot .. My 2 cents Interesting... @ what weight was his car? The reason I'm asking is cause as the saying goes weight kills parts ,so curios of the weight at 9.0's. It is right around 2950..
[Re: madscientist]
#2225724
01/02/17 05:44 PM
01/02/17 05:44 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
My local shop (now retired) did a couple of sleeves for me on different blocks 35-40 years ago and he did a GREAT job. I just can't justify the money some guys are throwing at stock blocks. To each their own I guess
[Re: 70dusterjohn]
#2225730
01/02/17 05:57 PM
01/02/17 05:57 PM
Posts: 4,072 Mo.
racerx
Mo.
We busted our block #2 and it was half filled .. Had it sleeved and is still living .. Heck I have seen a buddies 400 all but one need sleeves so he did all 8 half filled and 12 years later still running 9 flat .. Street driven a lot .. My 2 cents Interesting... @ what weight was his car? The reason I'm asking is cause as the saying goes weight kills parts ,so curios of the weight at 9.0's. It is right around 2950.. ok....Thaxs
[Re: mopar dave]
#2225741
01/02/17 06:17 PM
01/02/17 06:17 PM
Posts: 20,188 Park Forest, IL
slantzilla
Park Forest, IL
Friend of mine has done literally dozens of sleeves in his home shop with one of these. He bought it from a shop that my Dad worked at in the '40s. Dad used to bore motors in chassis with it. My buddy used to charge $40 for the sleeve and $40 to put it in and finish boring it. It amazes me that any shop with modern equipment can't/won't do a sleeve.
[Re: slantzilla]
#2225768
01/02/17 06:36 PM
01/02/17 06:36 PM
madscientist
Washington
Friend of mine has done literally dozens of sleeves in his home shop with one of these. He bought it from a shop that my Dad worked at in the '40s. Dad used to bore motors in chassis with it. My buddy used to charge $40 for the sleeve and $40 to put it in and finish boring it. It amazes me that any shop with modern equipment can't/won't do a sleeve. Luckily, I've only had to do a few sleeves with a boring bar like that. It works fine, it's just slower than newer tooling.
