Page 3 of 3 1 2 3
Re: Cold weather 400 block. [Re: mopar dave] #2225270
01/02/17 01:31 AM
01/02/17 01:31 AM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
I would sleeve it. After all, it's not in the car yet and it's winter🤓
Re: Cold weather 400 block. [Re: ccdave] #2225326
01/02/17 02:34 AM
01/02/17 02:34 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Best Machine suggested not sleeving and to fill instead. short block is already together, not backing up now. thanks
Re: Cold weather 400 block. [Re: mopar dave] #2225362
01/02/17 04:57 AM
01/02/17 04:57 AM
Do not fill the block now unless you want to take it apart and have it rehoned after letting the fill cure twocents
I don't like or use block filler due to the block having to different heat zones when running, one above the fill and the other one where the fill is, the cylinder walls expand differently with fill due to that is what I have seen work
Re: Cold weather 400 block. [Re: Cab_Burge] #2225454
01/02/17 12:22 PM
01/02/17 12:22 PM
Mt Morris Michigan
Mt Morris Michigan
The fill was done before any machining. I looked around my area for some time trying to find someone with good rep that could sleeve the block. I found 1 place, but they were booked for 6-9 months, so I called Best Machine in Detroit. Best told me to fill it instead. Most places don't install those sleeves correctly. It is now filled above the soft plugs.
Re: Cold weather 400 block. [Re: mopar dave] #2225469
01/02/17 12:48 PM
01/02/17 12:48 PM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
Doesn't Muscle Motors sleeve blocks?
Re: Cold weather 400 block. [Re: ccdave] #2225486
01/02/17 01:02 PM
01/02/17 01:02 PM
Mt Morris Michigan
Mt Morris Michigan
I thought the same, but when I spoke to them it didn't sound like it. They were not big on the idea of sleeving this block.
Re: Cold weather 400 block. [Re: mopar dave] #2225495
01/02/17 01:11 PM
01/02/17 01:11 PM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
I wonder why these Mopar shops don't want to sleeve blocks?? I thought sleeving blocks was a common procedure with the lack of affordable aftermarket blocks out there.
Re: Cold weather 400 block. [Re: ccdave] #2225525
01/02/17 01:43 PM
01/02/17 01:43 PM
Mt Morris Michigan
Mt Morris Michigan
sounds like a tricky process as you want to press the sleeve in without moving the other cylinders over. I'm not a machinest so I only know what iv read on the subject. I hear a lot of stories about leaking issues.
Re: Cold weather 400 block. [Re: mopar dave] #2225559
01/02/17 02:12 PM
01/02/17 02:12 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
We busted our block #2 and it was half filled .. Had it sleeved and is still living .. Heck I have seen a buddies 400 all but one need sleeves so he did all 8 half filled and 12 years later still running 9 flat .. Street driven a lot .. My 2 cents
Re: Cold weather 400 block. [Re: 70dusterjohn] #2225564
01/02/17 02:15 PM
01/02/17 02:15 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
YEP and Pettis does em all day long...........
Re: Cold weather 400 block. [Re: mopar dave] #2225652
01/02/17 04:23 PM
01/02/17 04:23 PM
Washington
madscientist Offline
Washington
I have installed literally hundreds of sleeves.
If a machine shop can't or won't do a sleeve it's time to move on.
It's a very basic machine operation.
Re: Cold weather 400 block. [Re: 70dusterjohn] #2225679
01/02/17 04:50 PM
01/02/17 04:50 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Interesting... work @ what weight was his car? The reason I'm asking is cause as the saying goes weight kills parts ,so curios of the weight at 9.0's.
Re: Cold weather 400 block. [Re: madscientist] #2225685
01/02/17 04:55 PM
01/02/17 04:55 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Just curious but how much would it cost to buy, install, bore, and finish hone 8 sleeves?
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Cold weather 400 block. [Re: pittsburghracer] #2225692
01/02/17 05:02 PM
01/02/17 05:02 PM
Washington
Washington
I used to charge 25-40 for the sleeve, depending on the sleeve and 85 dollars for the first hole.
To do a V8 total was 450 plus the sleeves. I save at least 6 different T/A blocks plus I can't say how many fork lift engines plus all the 1 and 2 sleeve deals I did.
When done correctly, you'd be hard pressed to even see the sleeve.
Re: Cold weather 400 block. [Re: racerx] #2225721
01/02/17 05:40 PM
01/02/17 05:40 PM
Deerfield, Ohio
Deerfield, Ohio
It is right around 2950..
Re: Cold weather 400 block. [Re: madscientist] #2225724
01/02/17 05:44 PM
01/02/17 05:44 PM
PA.
"Little"John
"Little"John
PA.
My local shop (now retired) did a couple of sleeves for me on different blocks 35-40 years ago and he did a GREAT job. I just can't justify the money some guys are throwing at stock blocks. To each their own I guess
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Cold weather 400 block. [Re: 70dusterjohn] #2225730
01/02/17 05:57 PM
01/02/17 05:57 PM
Mo.
racerx Offline
racerx  Offline
Mo.
ok....Thaxs up
Re: Cold weather 400 block. [Re: mopar dave] #2225741
01/02/17 06:17 PM
01/02/17 06:17 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Friend of mine has done literally dozens of sleeves in his home shop with one of these. He bought it from a shop that my Dad worked at in the '40s. Dad used to bore motors in chassis with it. biggrin
My buddy used to charge $40 for the sleeve and $40 to put it in and finish boring it.
It amazes me that any shop with modern equipment can't/won't do a sleeve. shruggy
Re: Cold weather 400 block. [Re: slantzilla] #2225768
01/02/17 06:36 PM
01/02/17 06:36 PM
Washington
Washington
Luckily, I've only had to do a few sleeves with a boring bar like that.
It works fine, it's just slower than newer tooling.
Re: Cold weather 400 block. [Re: mopar dave] #2226985
01/04/17 11:08 AM
01/04/17 11:08 AM
SouthEast Michigan
P
PETE@BESTMACHINE Offline
P
SouthEast Michigan
Dave I told you not to sleeve it because its a waste of money. Do the math, after its bored for the OD of the new sleeve and finished bored you are right back were you started or less. A Melling CSL269 sleeve has a OD of 4.5950 that a over bore of .253 or .1265 per side. How much is left in the block ? About .0175, install sleeve and bore for 4.375 and you have a cylinder bore thickness at .127. Most shops do not have the equipment to bore the cylinder straight and the sleeve will not sit square at the bottom. We have a Rottler F68 Block CNC machine and it will bore straight, we do sleeves when it makes sense to do it. Hard block will help to support the thin spots found on many stock blocks.
Page 3 of 3 1 2 3
