Re: W2 econo heads
[Re: littleVAL]
#2224021
12/31/16 01:56 PM
12/31/16 01:56 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
I found a couple of pictures of W2 heads. I found one with the ribs and one without (Econo, dual exhaust bolt pattern). Both have rocker arm pedistals.
Hope this helps for discussion.
-------------------------------------------------------------- Is there a W2 that took the standard LA rocker arm gear? If so, can you tell me which part number to look for?
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
Re: W2 econo heads
[Re: jeff500]
#2224030
12/31/16 02:12 PM
12/31/16 02:12 PM
Posts: 14,504 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The version just prior to the ones having the ribs around the head bolt holes are pretty thin in that area of the external wall. I had a brand new one, hardly milled at all, crack wide open there during installation. Torquing the head bolts......"snap". I was pretty surprised how thin it was.
The only ones I would even consider would be the ones with the ribs.
Re: W2 econo heads
[Re: jeff500]
#2224065
12/31/16 03:01 PM
12/31/16 03:01 PM
fast68plymouth
So. Burlington, Vt.
I'm not a w2 guru by any means, but I believe there are at least 3 "generations" of them.
The first basically look like stock heads externally.
The second have a more smoothed over exterior, no ribs around the outer bolt holes, and iirc they have "Mopar W2" cast into them on the exhaust side of the head. The letters are indented in, not raised.
The third has the ribs by the bolt holes, letters raised.
There might be other versions or variations within those versions as well.
Re: W2 econo heads
[Re: fast68plymouth]
#2224074
12/31/16 03:13 PM
12/31/16 03:13 PM
Posts: 20,184 PA.
pittsburghracer
"Little"John
"Little"John
PA.
My W2 Econo heads cracked right by where the W2 was cast on the outside part of the head under the exhaust port. Both heads leaked water out the crack. It was a shame because they ran easy 9's in my Duster with a little port work I did and stock 2.02 valves. The heads are still leaning against the wall in my shop but after that happened I sold off 2 sets of rockers and a W2 intake that I ported.
Re: W2 econo heads
[Re: jeff500]
#2224078
12/31/16 03:16 PM
12/31/16 03:16 PM
fast68plymouth
So. Burlington, Vt.
I believe only the first gen have the core plugs, but that might also be a first gen/econo only thing. Someone more knowledgable about them would have to clear that up.
I think the basics are:
Re: W2 econo heads
[Re: jeff500]
#2224162
12/31/16 05:50 PM
12/31/16 05:50 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
Here is a couple of pictures...yes..early w2 had freeze plugs on them..later did not...picture of standard length and long valve econo heads..
and second picture shows ribs vs non rib w2...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
