Cuda drivers door difference #2223505
12/30/16 06:17 PM
12/30/16 06:17 PM
Nashville, TN
MOPARMIKE69 Offline OP
Nashville, TN
Is the only difference between a 1970 and a 1973 cuda door the extra beam in the middle of the door?
Can you use a 1973 door on a 1970?
Thanks for your help.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Cuda drivers door difference [Re: MOPARMIKE69] #2223551
12/30/16 07:13 PM
12/30/16 07:13 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
If cudas are like challengers (and in many ways they are) the cat whiskers attach differently. 70 has slots for a clip and 71+ has holes for screws.
Re: Cuda drivers door difference [Re: MOPARMIKE69] #2223603
12/30/16 08:54 PM
12/30/16 08:54 PM
Washington/Las Vegas
1971 Gran Coupe Offline
In mid year, not sure when, the door frames were changed. It affects the window regulator. An early regulator will not fit the later door frames, but the later regulators will work in the early door frames. I found this out when I sold a regulator that was going into a 71. He had the later style doors and the regulator was restricted for full travel from the gear hitting the frame. Neither of us knew at the time about the changeover. He was able to trim the 70 regulator gear down and then it worked fine. Hope this helps.
Re: Cuda drivers door difference [Re: MOPARMIKE69] #2223686
12/30/16 11:12 PM
12/30/16 11:12 PM
Alabama
BigMoneyLewis Offline
Alabama
Don't forget about the concave / convex door handles , or was that Challenger only ?
Greg
gregward@mchsi.com phone 256-852-0955
Re: Cuda drivers door difference [Re: BigMoneyLewis] #2223778
12/31/16 01:20 AM
12/31/16 01:20 AM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
concave '70 Challenger
convex '70 Barracuda
flat 1972-'74 Barracuda & Challenger
the change took place somewhere during the '71 model year
Re: Cuda drivers door difference [Re: MOPARMIKE69] #2225180
01/01/17 11:48 PM
01/01/17 11:48 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
the door lock itself is a 70 only..
Re: Cuda drivers door difference [Re: MOPARMIKE69] #2225197
01/02/17 12:07 AM
01/02/17 12:07 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
1970 doors have more holes for the door panel clips at the bottom. Later years 'skipped' every other hole, so from memory the hole / clip count dropped from 7 to 4.
