front disc brake conversion B-body.....anybody ever used one #2222220
12/28/16 03:12 PM
12/28/16 03:12 PM
APACHE JUNCTION AZ
Joesixpack Offline OP
APACHE JUNCTION AZ
time to ditch the stock drum brakes on my 66 Belvedere
saw this kit.....anybody ever used this one before?
1963-1974 B,& E body Chrysler front disc brake conversion.. . This is a 5 on 4 1/2" bolt pattern rotor.
This kit includes the following.
2- new drilled and slotted rotors
2- new calipers with semi metallic pads and correct mounting hardware
2- new spindles loaded with caliper mounting hardware and dust shields.
2- new rubber brake hoses
1- new bearing and seal kit.
anybody ever used this kit? bolt on conversion? any other parts needed?
i deleted the a-body reference out of the ad as it does not pertain to my question
Re: front disc brake conversion B-body.....anybody ever used one [Re: Joesixpack] #2222228
12/28/16 03:36 PM
12/28/16 03:36 PM
Phoenix, AZ
Belvedere1 Offline
Belvedere1  Offline
Phoenix, AZ
I just bought a kit from Doctor Diff, have not installed it yet but everything I need is there and I can keep the sway bar and still run the stock 14" wheels. I getting rid of the factory 4 piston Bendix setup. I will be keeping the booster and master cylinder, prop valve, etc. Check out what he has to offer, his website is very user friendly in helping decide what you need/want.
Lee
Re: front disc brake conversion B-body.....anybody ever used one [Re: Joesixpack] #2222260
12/28/16 04:47 PM
12/28/16 04:47 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Bill , whose kit is that ?
Re: front disc brake conversion B-body.....anybody ever used one [Re: Joesixpack] #2222267
12/28/16 04:54 PM
12/28/16 04:54 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
The small bolt pattern A bodys require different uppers.Not 100 % sure on lowers but I believe they need them also.It oooks like a later a body kit.if it is they work good.i used tall spindles on my 65 and prefer them to the shorter
A body spindles.Rocky
Chrysler Firepower
Re: front disc brake conversion B-body.....anybody ever used one [Re: JohnRR] #2222302
12/28/16 05:54 PM
12/28/16 05:54 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
this kit if from EBAY SELLER tomsclassic eBay item number:330762316708.
Re: front disc brake conversion B-body.....anybody ever used one [Re: therocks] #2222405
12/28/16 08:27 PM
12/28/16 08:27 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Would need a different upper control arm or the Dr. Diff spacer unless the knuckle is sized for the smaller ball joint.
the lower arm is the same , the difference is the ball joint which has the same size stud for all a bodies and all brake sizes.
Re: front disc brake conversion B-body.....anybody ever used one [Re: Joesixpack] #2222487
12/28/16 11:04 PM
12/28/16 11:04 PM
AndyF Offline
AndyF  Offline
Looks like a factory late model A body setup so it should work just fine on '62 to '72 B body cars. Might want to double check to see what the piston size is on the calipers and you'll want the calipers to hang to the front in order to get the hose routing correct. Should clear just fine unless you've retrofitted a sway bar on to the car.
Re: front disc brake conversion B-body.....anybody ever used one [Re: Joesixpack] #2222818
12/29/16 03:20 PM
12/29/16 03:20 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I'd be curious as to where the rotors are sourced from and if they cross to something you can buy at the local parts store , same for the calipers , nothing I hate worse than one off special parts that are $$$ and impossible to replace.
Re: front disc brake conversion B-body.....anybody ever used one [Re: Joesixpack] #2223373
12/30/16 02:49 PM
12/30/16 02:49 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Lot has been said on disc brake conversions . . . SO there is my two cents worth . . . I have used F,M,J body spindles, calipers, etc . . . on two different cars (one a C body, and one a B body) . . . fit perfect - just needed a washer on the lower balls joint to spindle bolts. Used the rear mount and PROPER calipers (believe they are mid 80's 5th Ave. calipers, with the bleed screw in upper location), stainless steel hoses from Dr. Diff, and voila . . . (of course new master cylinder) . . . both cars stop perfect, no issues on alignment or bump steer, etc . . . .
If you don't want to search for all separate parts, go to Dr. Diff. Knowledgeable, and reasonable and you will be happy with the service.
Cheers,
Re: front disc brake conversion B-body.....anybody ever used one [Re: Joesixpack] #2223928
12/31/16 11:16 AM
12/31/16 11:16 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I have found that doctor diff has the most knowledge and fair prices. I buy as much stuff from him as I can. No worries that way.
Re: front disc brake conversion B-body.....anybody ever used one [Re: Joesixpack] #2223982
12/31/16 01:14 PM
12/31/16 01:14 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
You can buy slotted/drilled rotors separate on ebay. I like to get factory spindles and caliper brackets and buy the rest new. I put a disc kit on a roadrunner a few years back and ended up getting a notice about the spindles breaking. Probably just a small run, but remember this stuffs all made in China cheaply.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
