front disc brake conversion B-body.....anybody ever used one
#2222220
12/28/16 03:12 PM
12/28/16 03:12 PM
Posts: 11,912 APACHE JUNCTION AZ
Joesixpack
APACHE JUNCTION AZ
time to ditch the stock drum brakes on my 66 Belvedere saw this kit.....anybody ever used this one before? 1963-1974 B,& E body Chrysler front disc brake conversion.. . This is a 5 on 4 1/2" bolt pattern rotor.
This kit includes the following.
2- new drilled and slotted rotors
2- new calipers with semi metallic pads and correct mounting hardware
2- new spindles loaded with caliper mounting hardware and dust shields.
2- new rubber brake hoses
1- new bearing and seal kit. anybody ever used this kit? bolt on conversion? any other parts needed? i deleted the a-body reference out of the ad as it does not pertain to my question
Re: front disc brake conversion B-body.....anybody ever used one
[Re: Joesixpack]
#2222260
12/28/16 04:47 PM
12/28/16 04:47 PM
Posts: 74,992 U.S.S.A.
JohnRR
U.S.S.A.
Bill , whose kit is that ?
[Re: Joesixpack]
#2222267
12/28/16 04:54 PM
12/28/16 04:54 PM
Posts: 21,067 Niles , Ohio
therocks
Niles , Ohio
The small bolt pattern A bodys require different uppers.Not 100 % sure on lowers but I believe they need them also.It oooks like a later a body kit.if it is they work good.i used tall spindles on my 65 and prefer them to the shorter A body spindles.Rocky
Chrysler Firepower
[Re: therocks]
#2222405
12/28/16 08:27 PM
12/28/16 08:27 PM
JohnRR
U.S.S.A.
The small bolt pattern A bodys require different uppers.Not 100 % sure on lowers but I believe they need them also.It oooks like a later a body kit.if it is they work good.i used tall spindles on my 65 and prefer them to the shorter A body spindles.Rocky Would need a different upper control arm or the Dr. Diff spacer unless the knuckle is sized for the smaller ball joint. the lower arm is the same , the difference is the ball joint which has the same size stud for all a bodies and all brake sizes.
[Re: Joesixpack]
#2222818
12/29/16 03:20 PM
12/29/16 03:20 PM
JohnRR
U.S.S.A.
I'd be curious as to where the rotors are sourced from and if they cross to something you can buy at the local parts store , same for the calipers , nothing I hate worse than one off special parts that are $$$ and impossible to replace.
[Re: Joesixpack]
#2223373
12/30/16 02:49 PM
12/30/16 02:49 PM
Posts: 2,918 Calgary, Alberta Canada
a12rag
Lot has been said on disc brake conversions . . . SO there is my two cents worth . . . I have used F,M,J body spindles, calipers, etc . . . on two different cars (one a C body, and one a B body) . . . fit perfect - just needed a washer on the lower balls joint to spindle bolts. Used the rear mount and PROPER calipers (believe they are mid 80's 5th Ave. calipers, with the bleed screw in upper location), stainless steel hoses from Dr. Diff, and voila . . . (of course new master cylinder) . . . both cars stop perfect, no issues on alignment or bump steer, etc . . . .
If you don't want to search for all separate parts, go to Dr. Diff. Knowledgeable, and reasonable and you will be happy with the service.
Cheers,
[Re: Joesixpack]
#2223982
12/31/16 01:14 PM
12/31/16 01:14 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
You can buy slotted/drilled rotors separate on ebay. I like to get factory spindles and caliper brackets and buy the rest new. I put a disc kit on a roadrunner a few years back and ended up getting a notice about the spindles breaking. Probably just a small run, but remember this stuffs all made in China cheaply.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
