68 Dart 8 3/4 parking brake hardware #2221905
12/27/16 11:27 PM
12/27/16 11:27 PM
Laveen, Arizona
GTSDart340 Offline OP
Laveen, Arizona
My Dart is missing the parking brake hardware in the drum. It's there an oreilly part number for it? Thanks!
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
Re: 68 Dart 8 3/4 parking brake hardware [Re: GTSDart340] #2221977
12/28/16 01:14 AM
12/28/16 01:14 AM
their site has alot of the smaller brake items such as clips/springs etc but likely not the long lever if you are missing that which'd be a Mopar specific item. the ones from any 10" 8&3/4 & maybe even the 11 inchers would be the same but you'd need to locate a rear end or just a brake assy.
Re: 68 Dart 8 3/4 parking brake hardware [Re: RapidRobert] #2222108
12/28/16 11:28 AM
12/28/16 11:28 AM
moparx Offline
moparx  Offline
i believe the 10" and 11" e-brake hardware are size specific only. i'm pretty sure megaparts has the equalizer bar [the slotted bar that goes between the shoes under the wheel cylinder]. not sure about the pivot arm the cable hooks to though.
beer
Re: 68 Dart 8 3/4 parking brake hardware [Re: GTSDart340] #2222192
12/28/16 02:27 PM
12/28/16 02:27 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
You might want to try Finelines. There's also a complete kit if you want everything fresh. Just a note, 68s came with two different setups. Early builds used the 67 and below which used the short passenger side cable and later builds used the cable that crossed over along the reared to the driver side.
Abe Lincoln
Re: 68 Dart 8 3/4 parking brake hardware [Re: dart4forte] #2222265
12/28/16 04:49 PM
12/28/16 04:49 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Parking brake lines are the same 7-1/4 to 8-3/4, also everything 10" drum related is pretty much the same except for the backing plate. twocents
JB Rhinehart, Realist
A-Body's RULE!
