68 Dart 8 3/4 parking brake hardware
#2221905
12/27/16 11:27 PM
12/27/16 11:27 PM
Posts: 1,306 Laveen, Arizona
GTSDart340
Laveen, Arizona
My Dart is missing the parking brake hardware in the drum. It's there an oreilly part number for it? Thanks!
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
Re: 68 Dart 8 3/4 parking brake hardware
[Re: GTSDart340]
#2221977
12/28/16 01:14 AM
12/28/16 01:14 AM
RapidRobert
their site has alot of the smaller brake items such as clips/springs etc but likely not the long lever if you are missing that which'd be a Mopar specific item. the ones from any 10" 8&3/4 & maybe even the 11 inchers would be the same but you'd need to locate a rear end or just a brake assy.
[Re: GTSDart340]
#2222192
12/28/16 02:27 PM
12/28/16 02:27 PM
Posts: 16,146 Mesa, Arizona
dart4forte
Mesa, Arizona
You might want to try Finelines. There's also a complete kit if you want everything fresh. Just a note, 68s came with two different setups. Early builds used the 67 and below which used the short passenger side cable and later builds used the cable that crossed over along the reared to the driver side.
Abe Lincoln
