Re: Who makes these roller rockers?
[Re: MR_P_BODY]
#2221844
12/27/16 09:21 PM
12/27/16 09:21 PM
Posts: 1,073 oregon
greendart408
oregon
Cat.... Roller on the shaft
[Re: rpagan]
#2221855
12/27/16 09:51 PM
12/27/16 09:51 PM
Posts: 4,457 Washington
madscientist
Washington
I agree with Greendart. Looks like a Cat number on the rocker too. You are most likely correct. I didn't see the bearing on my first look. But, I can't see [censored] right now as my glasses are junk. Won't be fixed til late January. Cat and HS are the only ones I remember making a rocker like that.
[Re: SoCalRacer]
#2221873
12/27/16 10:31 PM
12/27/16 10:31 PM
Posts: 51 San Diego, USA
SoCalRacer
San Diego, USA
Thanks for the replies. It's hard to tell if there's a roller bearing in there, but rockers with no load are looser on the shaft than you'd expect with a plain bearing (like Crane), so I think they're rollers. I'll pull them off in the next couple days, as one has a questionable pin on the roller tip. I have Harland Sharps on the on my other car and they are beyond reproach.... these just don't seem the same build quality. MadMopars, I may be hitting you up for some spares....
If it ain't broke ... you're not pushing it hard enough.
[Re: SoCalRacer]
#2221926
12/27/16 11:52 PM
12/27/16 11:52 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
Would not run them in my lawnmower
1963 Plymouth Max Wedge 1971 Barracuda
[Re: SoCalRacer]
#2222029
12/28/16 02:30 AM
12/28/16 02:30 AM
Posts: 1,292 Tucson AZ,
MadMopars
Tucson AZ,
Thanks for the replies. It's hard to tell if there's a roller bearing in there, but rockers with no load are looser on the shaft than you'd expect with a plain bearing (like Crane), so I think they're rollers. I'll pull them off in the next couple days, as one has a questionable pin on the roller tip. I have Harland Sharps on the on my other car and they are beyond reproach.... these just don't seem the same build quality. MadMopars, I may be hitting you up for some spares.... The 1.5's puked the shaft bearings as seen in the first pic so I replaced them with all new bearings and used them for a bit longer. Later I switched to 1.6's and after 500 miles, the pins let go and ended up breaking several rockers. That failure could have been ALOT worse. Luckily it didn't drop the valves. I contemplated putting the 1.5's back on in a pinch but found a couple of the roller pins were loose on them as well. I won't chance using them again. It's your choice though. If you absolutely need some spares, let me know but it wouldn't be my first choice.
[Re: SoCalRacer]
#2222182
12/28/16 02:00 PM
12/28/16 02:00 PM
Posts: 14,511 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
It's pics and stories like that, that continue to keep me from using Chinese rockers.
My go to "budget" rockers are the Mancini/Harland's.
[Re: SoCalRacer]
#2222190
12/28/16 02:18 PM
12/28/16 02:18 PM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
Why do guys get so thrifty on rockers, in general not a personal question, some guy will spend the money on big cubes and buy the cheapest set of rockers found. It's something I've never understood.
Have a great day Iowan
"obsolete is neat"
[Re: Iowan]
#2222319
12/28/16 06:25 PM
12/28/16 06:25 PM
Posts: 452 Monrovia, So-Cal, USA
racerhog
Why do guys get so thrifty on rockers, in general not a personal question, some guy will spend the money on big cubes and buy the cheapest set of rockers found. It's something I've never understood. I agree...
Bob(Cowboy)Hogan Monrovia So-Cal
[Re: MadMopars]
#2222395
12/28/16 08:10 PM
12/28/16 08:10 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I went straight from Crane non roller shafts to TDs and after the first set of Crane rockers being labeled wrong I havent had any issue with rockers or the valve train.. up to 9600 rpm EDIT I still have 2 sets of the Crane rockers and 3 sets of different TD rockers.. all for SB
[Re: MadMopars]
#2222907
12/29/16 06:33 PM
12/29/16 06:33 PM
SoCalRacer
San Diego, USA
In all fairness, the CAT rockers on my motor were probably one of the most expensive parts sadly.
If I still had the 292/509 cam instead of the 296/557, I may have just put the stock rockers back on.
I did buy a new set of the 1.6 Crane Ductile Irons earlier this year but have yet to install them. I'm not sure when or if I'll screw around with roller rockers again. To many disappointments with geometry, strength and cost. Since the cam I am using is bigger than that I only foresee disaster. I got the car for a reasonable price, so it's worth it to drop a grand on some Harland Sharps to keep an otherwise good motor together. I've always wondered about those really inexpensive roller rockers... now I know.
[Re: SoCalRacer]
#2222927
12/29/16 07:22 PM
12/29/16 07:22 PM
madscientist
Washington
I did buy a new set of the 1.6 Crane Ductile Irons earlier this year but have yet to install them. I'm not sure when or if I'll screw around with roller rockers again. To many disappointments with geometry, strength and cost. Since the cam I am using is bigger than that I only foresee disaster. I got the car for a reasonable price, so it's worth it to drop a grand on some Harland Sharps to keep an otherwise good motor together. I've always wondered about those really inexpensive roller rockers... now I know. I'd buy the T&D long before I bought the HS rockers. Edit: and I would tell T&D to leave the bearings out and just run the rocker on the shaft. They will [censored] about it, but they will do it.
[Re: SoCalRacer]
#2222934
12/29/16 07:32 PM
12/29/16 07:32 PM
fast68plymouth
So. Burlington, Vt.
How big is the cam, solid or roller, what spring pressures?
