Page 3 of 4 1 2 3 4
Re: converter selection, need some pointers [Re: dvw] #2219203
12/22/16 07:51 PM
12/22/16 07:51 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Kris at Continental Converter is/has passed the business on but that's who I've used for many years and never sent one back for an adjustment............ beer
Re: converter selection, need some pointers [Re: Thumperdart] #2219204
12/22/16 07:58 PM
12/22/16 07:58 PM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
He's sending a lot of stuff to Dice Performance Converters.... LANCASTER DOM !!!!!!
Re: converter selection, need some pointers [Re: Chassisman] #2219205
12/22/16 08:00 PM
12/22/16 08:00 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Like what and since when?
Re: converter selection, need some pointers [Re: dartman366] #2219233
12/22/16 09:07 PM
12/22/16 09:07 PM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
Dynamic in Ct. got my stall WAYYY wrong twice in a row..cost me a season of racing. They said to send it back a 3rd time (they wouldnt pay shipping)....i told them GFYS.
Sent the same converter to PTC and they nailed the 4800 stall DEAD ON the 1st time.
Re: converter selection, need some pointers [Re: gregsdart] #2219291
12/22/16 10:46 PM
12/22/16 10:46 PM
Mt. Vernon, Ohio
dartman366 Offline OP
Mt. Vernon, Ohio
Originally Posted By gregsdart
Just a guess on what will please you for driveability; it sounds like a stock configuration 10 3/4 Mopar converter, set up to act just like a factory original yet be built for the abuse a 540 can deliver is what will work well for you. I used exactly that converter behind a 535 cube wedge with a 590 cam in it, and it stalled plenty high yet was tight enough to not flash a lot higher at a light throttle application. If you take the K factor into consideration, it will give you an idea of what it will do in the car. Those converters were used behind 340s ,383s, and street hemis I believe. The stall behind a street hemi was about 2800 from what I have read, and 2400 behind a 340. That same converter stalled quite a bit higher behind my 535, like mid 3,000 or more.
A couple of things make me think this might be the right path for you. You want street drivability over ultimate performance for one. The other is street traction. A motor like that ought to be able to fry the tires at low speeds anyway, so a high stall loose converter just isn't needed much there.
GregI hope you are not inplying that this car is street driven as it hasn't seen the highway or city street in over 20 years, it is a dedicated bracket car, altho I would just love to take a blast thru the neighborhood just once and pizz off the neighbor's down the street. drive
Re: converter selection, need some pointers [Re: dartman366] #2219315
12/22/16 11:19 PM
12/22/16 11:19 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I noticed this, think he meant to post in the Other vert thread, that's looking for a more street friendly up vert.
Re: converter selection, need some pointers [Re: dartman366] #2219608
12/23/16 02:01 PM
12/23/16 02:01 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I noticed this, think he meant to post in the Other vert thread, that's looking for a more street friendly vert.
I thought the same thing.
It's either that or too much/too little coffee.
Re: converter selection, need some pointers [Re: dartman366] #2219614
12/23/16 02:09 PM
12/23/16 02:09 PM
So. Burlington, Vt.
So. Burlington, Vt.
While I haven't purchased too many converters for myself, I have helped many many people get their combos sorted out through the years.
I'd be surprised if out of all those combos there were more than 20 where the converter seemed close enough on the first shot where it got left in the car.
Most end up going back at least once. Several ended up going somewhere other than where they where made to get "fixed"...... Some just got replaced with something else.
I'm always amazed at how you can give the exact same info, and request the same stall to two different converter shops, and get back two completely different performing units, with huge differences in stall....... And sometimes neither is what you asked for.
Somewhere on this thread someone mentioned how many times a converter shop will try and give you what they think is what you should have, regardless of what you ask for...... Because they know better than you.
My feeling is......... Just give me what I ask for..... Even if it's wrong and will make the car slower. At least then I'll learn something.
Re: converter selection, need some pointers [Re: fast68plymouth] #2219676
12/23/16 03:51 PM
12/23/16 03:51 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
You are correct Dwayne, I have known guy's that have gone thru the same thing, some times some thing's seem to be a crap shoot, I had forgotten that I do have a TCI streetfighter converter part#142200 that I had purchased from Chapper a couple of years ago that need's a starter ring gear replaced,, may take it to Quickdraw and get it fixed and have him evaluate it and see if he can do anything with it to make it work for me, if not then I will go with a new build.
Re: converter selection, need some pointers [Re: dartman366] #2219810
12/23/16 07:55 PM
12/23/16 07:55 PM
indy
E
eds dart Offline
eds dart  Offline
E
indy
have to give props to ATI. years ago when i was looking for a race converter researched many companies, COAN is local to me. learned that ATI manufactures all the components for the converter in house, they also at the time claimed that they had more stock and super stock nhra class records than anyone else. that really sold me. stall was perfect first shot, converter has been back one time for a freshening. still getting it done. there are many great converter companies, i can highly recommend ATI
Re: converter selection, need some pointers [Re: dartman366] #2219867
12/23/16 10:03 PM
12/23/16 10:03 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Jason at quick draw does ours. It is a PTC converter. I have no Problems with them. Both have done me good.
Re: converter selection, need some pointers [Re: dartman366] #2219871
12/23/16 10:13 PM
12/23/16 10:13 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Everyone is going to suggest who they use. Turbo Action, ATI, etc all the big name places are going to give you pretty much the same thing. Call them, tell them what you have and what you want to do, and let them build you a unit. It's simple as that.
If your local guy has Wallies and bracket race wins under his belt, go with them. If not, don't. There is no benefit to going local when it cost $75 to ship a converter anywhere in the country, and the difference can be a round win.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: converter selection, need some pointers [Re: dartman366] #2219875
12/23/16 10:24 PM
12/23/16 10:24 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
my friend larry owned a torque converter rebuilding shop---he said most of the catalog converters are loose (inefficient) and poorly done---at one time he was courting speedway to be their builder---they were waffling around on his prices--so larry ordered 3 converters from speedway which were drop shipped from their supplier (i think in georgia)----larrys family is from nebraska so he goes there alot--he took their product to their plant--opened the boxes and cut open their converters right in front of them---all 3 had surface rust on the inside possibly because they had been on the shelf so long and hadnt been properly oiled after welding----speedway still not liking larrys price just said we we will talk to the plant about that----and that was it----larry has since retired and sold off most his equipment...
Re: converter selection, need some pointers [Re: savoy64] #2219889
12/23/16 10:51 PM
12/23/16 10:51 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Bracket racing converters are normally set up on the loose side so you can drive the stripe easier. The looser the converter, the smaller incremental loss in ET when you rip the throttle driving the stripe. They don't pay anymore more to the purse if you're setting ET records.
Re: converter selection, need some pointers [Re: dartman366] #2219891
12/23/16 10:53 PM
12/23/16 10:53 PM
gregsdart Online content
gregsdart  Online Content
oops. Totally blew that one. I must have read another thread and somehow answered yours! blush
Edit again; that was Hemiragtops post I read,,, rolleyes I'm going to take a nap,,,,
Re: converter selection, need some pointers [Re: dartman366] #2227738
01/05/17 01:40 PM
01/05/17 01:40 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Lenny's has been behind motors ranging from 446-512 in my Arrow and has been flawless. This is without a dyno sheet so I'm sure there might be more in it. He picked up 5 mph in the original Hughes the first time he touched it.
5.53 @ 125 1/8th on the launch control..more left in her!
Re: converter selection, need some pointers [Re: Eric] #2228241
01/05/17 11:12 PM
01/05/17 11:12 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
he is on my short list. up
Re: converter selection, need some pointers [Re: dartman366] #2230213
01/08/17 06:50 PM
01/08/17 06:50 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
one day after submitting my tech sheet Lenny call's and we discuss my need's,, two weeks after I submit my tech sheet to TCI I still have no response,,,guess who is going to get my bussiness.
Re: converter selection, need some pointers [Re: dartman366] #2230443
01/08/17 10:50 PM
01/08/17 10:50 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
I've been happy with Lenny's product
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: converter selection, need some pointers [Re: Eric] #2230520
01/09/17 12:29 AM
01/09/17 12:29 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I had Lenny build a 8" converter for my 408 after I killed my 9.5" $450 Edge racing Converter. It never 60' within .1 of the Edge and .2 in the 1/8. After building and dynoing my 434 I called Lenny and talked about my converter. He said it should be good, so I tried it, 18% slip in the 1/8. So I call him back and he says it's to loose and to send it back. He tightened it up 500 rpms (at almost $275) 5100 from 5600.
I ran a best of 1.38 several times with the 408 and a $450 9.5" Edge converter. After adding 100+ HP and probably that much torgue, plus spending over $1500 on a converter from Ultimate I have ran a best 60' of 1.44.
I'll look elsewhere for my converters.
Page 3 of 4 1 2 3 4
