Bulk replating: i.e, latches, wiper motors, etc... #2218294
12/21/16 12:14 PM
12/21/16 12:14 PM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Hey gang...
Getting to the point now where I need to consider replating many components on my Superbird. I'm not looking to replate everything.. The car is in overall great shape, so stuff I can't see, like inside the doors, will be cleaned, treated and corrosion-controlled. But, things like door latches/strikers, wiper motor, housing, etc, I would like to get done to have a nice fresh look. I have reached out to S.F already. Are there any other firms that specialize/know Chryslers?
Thanks..
Troy
Houston Mopar Connection Club
Re: Bulk replating: i.e, latches, wiper motors, etc... [Re: hemi68charger] #2218318
12/21/16 12:57 PM
12/21/16 12:57 PM
Georgia
69bfan Offline
69bfan  Offline
Georgia
Troy,
Have you checked within your area for a plater? I live in Northwest GA, but close enough to the Marietta / Atlanta GA. area that there are several platers that will do small jobs for us. They will not disassemble or assemble the components, they will only plate the parts. They charge basically on the weight of the parts left with them. I will usually try to accumulate enough parts to make it worth there efforts and mine. Typically 20 to 30 pounds and they will usually only charge me $75 to $100. I also have 3 restoration shops that will send me components to be refinished. That is a lots of small parts. I will bead blast and wire brush the parts and then bag and box based upon the finish required, clear, silver, yellow or black zinc. They will not do black phosphate. For parts like door latches, coil brackets, brake boosters, etc. you can save yourself some substantial money if you do lots of the labor yourself and do not outsource component rebuilds.
www.restorationpartsandmaterials.com
Correct Mopar weatherstripping is our specialty, but we stock and supply a wide assortment for all of your restoration needs.
www.dalescudashop.com
Correct style exhaust tips and hardware, fresh air seals, go wings, Cuda & Challenger rear window louvers, hood pin kits
Re: Bulk replating: i.e, latches, wiper motors, etc... [Re: hemi68charger] #2218834
12/22/16 07:37 AM
12/22/16 07:37 AM
Georgia
magiccuda Offline
magiccuda  Offline
Georgia
Be careful who you use. I have used a couple of places around the ATL area and have ran into long weights and crappy work. Ran into one person that was trying to be a middle man did nothing but got stuff brought to him and then farmed the parts out to the lowest priced shop. It got so bad that I gave up and just went with rebop stuff. I have heard that tri city in TN, is good but have not used them. so good luck
Re: Bulk replating: i.e, latches, wiper motors, etc... [Re: magiccuda] #2218888
12/22/16 12:10 PM
12/22/16 12:10 PM
Georgia
69bfan Offline
69bfan  Offline
Georgia
Good point, like anything where you are at the mercy of having to ship your parts off to someone to have them done and have no ideal on who is doing the work. That is why I am fortunate that I have been able to actually drop off my work at the facility and know that they are doing the work in house. I know that a chrome shop in the Atlanta area was advertising plastic plating in house only to find out they they were outsourcing the work. What was really bad was that they were not even using one of the better platers.
Re: Bulk replating: i.e, latches, wiper motors, etc... [Re: hemi68charger] #2218947
12/22/16 01:24 PM
12/22/16 01:24 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Yes be careful, these platers that do industrial things don't care about your car, they promise the moon and deliver crap. It is not what you want. Use someone who cares about old cars.
Re: Bulk replating: i.e, latches, wiper motors, etc... [Re: NANKET] #2219352
12/23/16 12:09 AM
12/23/16 12:09 AM
CentralVA.
BBCoronet Offline
BBCoronet  Offline
CentralVA.
Just had some Dart bumpers done at Tri-City and they do very nice work......
Re: Bulk replating: i.e, latches, wiper motors, etc... [Re: hemi68charger] #2219661
12/23/16 03:24 PM
12/23/16 03:24 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Take your hood latch, catch and trunk latch and send them to SF - no reason to get cheap now.
The rest of the stuff you take to a plater in your area. Heck it's Texas there should be one on every corner. Go look at their work and show them what you have and make them explain what they are going to do.
Cheapest is not best when it comes to this stuff.
Re: Bulk replating: i.e, latches, wiper motors, etc... [Re: hemi68charger] #2219798
12/23/16 07:39 PM
12/23/16 07:39 PM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
I'd like to know how you all can send out fasteners in bulk for plating, and then manage to get them all back to their proper locations?
When I disassembled my car I made baggies of every nut/bolt/bracket/etc. Since plating houses don't generally deal with small details like keeping everything sorted, I found this the perfect opportunity to get into plating. What an absolute blessing it has been to be able to plate on demand and ensure things get back to their correct location. The other plus is it allows me to tailor the finish to exactly what I need.
Re: Bulk replating: i.e, latches, wiper motors, etc... [Re: AAR#2] #2219876
12/23/16 10:30 PM
12/23/16 10:30 PM
Alaska, USA
Jalaska907 Offline
Jalaska907  Offline
Alaska, USA
Do you plate for yourself or business? If so, what all can you plate?
Justin Baldwin
Kenai, AK
Re: Bulk replating: i.e, latches, wiper motors, etc... [Re: Jalaska907] #2219890
12/23/16 10:53 PM
12/23/16 10:53 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
Try Eric on the board here 3404@oh.rr.com been doing my wiper motor and bulk plating for years
NS1AAR
Re: Bulk replating: i.e, latches, wiper motors, etc... [Re: Jalaska907] #2220003
12/24/16 03:56 AM
12/24/16 03:56 AM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
I do it for myself mostly, turned into a separate hobby, currently do Zinc Phosphate, Manganese Phosphate, Electrodeposited zinc (vary the brighteners to achieve a multitude of finishes), finish with a chromate in clear/blue, yellow, black, or OD. Now that I have a really good handle on these I'm looking into sulfuric acid anodizing.
Re: Bulk replating: i.e, latches, wiper motors, etc... [Re: hemi68charger] #2220075
12/24/16 12:20 PM
12/24/16 12:20 PM
MO
cdp Offline
cdp  Offline
MO
http://www.dynamicrenovation.net
The plated stuff for my A12 and a 56 xk140. Not the cheapest route, but quality, workmanship is awesome.
Gold cad, silver, black phosphate, etc.
Re: Bulk replating: i.e, latches, wiper motors, etc... [Re: ns1aar] #2220128
12/24/16 01:55 PM
12/24/16 01:55 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Same here,you get the results you expect,he can give you whatever finish you want and it doesn't take forever and you won't need a second job to pay the bill ! twocents
Re: Bulk replating: i.e, latches, wiper motors, etc... [Re: 62maxwgn] #2220357
12/24/16 07:22 PM
12/24/16 07:22 PM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
Leave Eric alone, he is busy doing a bunch of my parts right now. I've been using Eric for years, helps he's a good friend and only 15 miles from my shop.
Eric hand plates every part no matter what it is, nothing goes in a tumble basket like all the production platers use.
Re: Bulk replating: i.e, latches, wiper motors, etc... [Re: hemi68charger] #2221119
12/26/16 03:05 PM
12/26/16 03:05 PM
WNY
slimert Offline
slimert  Offline
WNY
Another vote for Eric! thumbs up
Re: Bulk replating: i.e, latches, wiper motors, etc... [Re: hemi68charger] #2222099
12/28/16 10:37 AM
12/28/16 10:37 AM
Ashland City, Tennessee
Aar1064 Offline
Aar1064  Offline
Another vote for Neil Jenks at dynamicrenovations.net for the hardware. If you prep your parts the price is fairly reasonable. I bagged, numbered, and labeled all parts, created a spread sheet with all the details and included it in box of parts and they came back exactly as labeled. Made installation a lot easier. He's a Mopar guy so he has a working knowledge of appropriate finishes for a lot of these parts.
Re: Bulk replating: i.e, latches, wiper motors, etc... [Re: slimert] #2222142
12/28/16 12:57 PM
12/28/16 12:57 PM
White Plains, NY
VCODE Online boogie
VCODE  Online Boogie
White Plains, NY
Eric
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: Bulk replating: i.e, latches, wiper motors, etc... [Re: VCODE] #2222175
12/28/16 01:49 PM
12/28/16 01:49 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
Eric has done stuff for me too, and as others have said.....he does excellent work. bow up
Re: Bulk replating: i.e, latches, wiper motors, etc... [Re: hemi68charger] #2222277
12/28/16 05:03 PM
12/28/16 05:03 PM
USA
Suregrip391 Online content
Suregrip391  Online Content
USA
Eric did my jack mast, awesome work!
Re: Bulk replating: i.e, latches, wiper motors, etc... [Re: hemi68charger] #2222861
12/29/16 04:46 PM
12/29/16 04:46 PM
Miami, FL
W
wylde8 Offline
wylde8  Offline
W
Miami, FL
I may not be the OP, but this info will benefit me greatly as well. Looks like all the options posted are considerably cheaper than the place I've been using.
1971 Dodge Charger
At Moparts, the concensus is there is no consensus.
