Bulk replating: i.e, latches, wiper motors, etc...
#2218294
12/21/16 12:14 PM
12/21/16 12:14 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Hey gang...
Getting to the point now where I need to consider replating many components on my Superbird. I'm not looking to replate everything.. The car is in overall great shape, so stuff I can't see, like inside the doors, will be cleaned, treated and corrosion-controlled. But, things like door latches/strikers, wiper motor, housing, etc, I would like to get done to have a nice fresh look. I have reached out to S.F already. Are there any other firms that specialize/know Chryslers?
Thanks.. T
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
Re: Bulk replating: i.e, latches, wiper motors, etc...
[Re: hemi68charger]
#2218318
12/21/16 12:57 PM
12/21/16 12:57 PM
Posts: 306 Georgia
69bfan
Georgia
Troy, Have you checked within your area for a plater? I live in Northwest GA, but close enough to the Marietta / Atlanta GA. area that there are several platers that will do small jobs for us. They will not disassemble or assemble the components, they will only plate the parts. They charge basically on the weight of the parts left with them. I will usually try to accumulate enough parts to make it worth there efforts and mine. Typically 20 to 30 pounds and they will usually only charge me $75 to $100. I also have 3 restoration shops that will send me components to be refinished. That is a lots of small parts. I will bead blast and wire brush the parts and then bag and box based upon the finish required, clear, silver, yellow or black zinc. They will not do black phosphate. For parts like door latches, coil brackets, brake boosters, etc. you can save yourself some substantial money if you do lots of the labor yourself and do not outsource component rebuilds.
www.restorationpartsandmaterials.comCorrect Mopar weatherstripping is our specialty, but we stock and supply a wide assortment for all of your restoration needs. www.dalescudashop.comCorrect style exhaust tips and hardware, fresh air seals, go wings, Cuda & Challenger rear window louvers, hood pin kits
[Re: magiccuda]
#2218888
12/22/16 12:10 PM
12/22/16 12:10 PM
Posts: 306 Georgia
69bfan
Georgia
Good point, like anything where you are at the mercy of having to ship your parts off to someone to have them done and have no ideal on who is doing the work. That is why I am fortunate that I have been able to actually drop off my work at the facility and know that they are doing the work in house. I know that a chrome shop in the Atlanta area was advertising plastic plating in house only to find out they they were outsourcing the work. What was really bad was that they were not even using one of the better platers.
[Re: AAR#2]
#2219876
12/23/16 10:30 PM
12/23/16 10:30 PM
Posts: 91 Alaska, USA
Jalaska907
Alaska, USA
I'd like to know how you all can send out fasteners in bulk for plating, and then manage to get them all back to their proper locations?
When I disassembled my car I made baggies of every nut/bolt/bracket/etc. Since plating houses don't generally deal with small details like keeping everything sorted, I found this the perfect opportunity to get into plating. What an absolute blessing it has been to be able to plate on demand and ensure things get back to their correct location. The other plus is it allows me to tailor the finish to exactly what I need. Do you plate for yourself or business? If so, what all can you plate?
Justin Baldwin Kenai, AK
[Re: Jalaska907]
#2219890
12/23/16 10:53 PM
12/23/16 10:53 PM
Posts: 1,145 ontario calif
ns1aar
ontario calif
Try Eric on the board here 3404@oh.rr.com been doing my wiper motor and bulk plating for years
NS1AAR
[Re: Jalaska907]
#2220003
12/24/16 03:56 AM
12/24/16 03:56 AM
Posts: 768 Dry Heat AZ
AAR#2
Dry Heat AZ
When I disassembled my car I made baggies of every nut/bolt/bracket/etc. Since plating houses don't generally deal with small details like keeping everything sorted, I found this the perfect opportunity to get into plating. What an absolute blessing it has been to be able to plate on demand and ensure things get back to their correct location. The other plus is it allows me to tailor the finish to exactly what I need. Do you plate for yourself or business? If so, what all can you plate? I do it for myself mostly, turned into a separate hobby, currently do Zinc Phosphate, Manganese Phosphate, Electrodeposited zinc (vary the brighteners to achieve a multitude of finishes), finish with a chromate in clear/blue, yellow, black, or OD. Now that I have a really good handle on these I'm looking into sulfuric acid anodizing.
[Re: hemi68charger]
#2220075
12/24/16 12:20 PM
12/24/16 12:20 PM
Posts: 3,691 MO
cdp
MO
http://www.dynamicrenovation.netThe plated stuff for my A12 and a 56 xk140. Not the cheapest route, but quality, workmanship is awesome. Gold cad, silver, black phosphate, etc.
[Re: 62maxwgn]
#2220357
12/24/16 07:22 PM
12/24/16 07:22 PM
Posts: 1,923 Medina, Ohio
HEMICUDA
Medina, Ohio
Try Eric on the board here 3404@oh.rr.com been doing my wiper motor and bulk plating for years Same here,you get the results you expect,he can give you whatever finish you want and it doesn't take forever and you won't need a second job to pay the bill ! Leave Eric alone, he is busy doing a bunch of my parts right now. I've been using Eric for years, helps he's a good friend and only 15 miles from my shop. Eric hand plates every part no matter what it is, nothing goes in a tumble basket like all the production platers use.
[Re: VCODE]
#2222175
12/28/16 01:49 PM
12/28/16 01:49 PM
Posts: 8,489 Candler,NC / Myrtle Beach, SC
JDMopar
Eric has done stuff for me too, and as others have said.....he does excellent work.
[Re: hemi68charger]
#2222861
12/29/16 04:46 PM
12/29/16 04:46 PM
Posts: 1,782 Miami, FL
wylde8
Miami, FL
I may not be the OP, but this info will benefit me greatly as well. Looks like all the options posted are considerably cheaper than the place I've been using.
1971 Dodge Charger
At Moparts, the concensus is there is no consensus.
