New COMP CAMS Nitriding wearing off? #2218795
12/22/16 03:11 AM
12/22/16 03:11 AM
USA
B5496RR Offline OP
B5496RR  Offline OP
USA
Please take a look at the new Nitrided COMP cams I just received from COMP Cams. Is this normal for the Nitrided black finish to wear off just from touching it by hand??
This is a custom ordered Nitrided camshaft from Comp Cams.
Re: New COMP CAMS Nitriding wearing off? [Re: B5496RR] #2218801
12/22/16 03:32 AM
12/22/16 03:32 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
I used to use Comp Cams exclusively
Lately, experiences by myself and others have led me to never purchase their products again!
Everything from crappy hydraulic roller lifters to flat tappet lifters that eat themselves to their ridiculous tech advice points to a company going down the tubes rather quickly.
Re: New COMP CAMS Nitriding wearing off? [Re: B5496RR] #2218813
12/22/16 04:30 AM
12/22/16 04:30 AM
Cab_Burge Online work
Cab_Burge  Online Work
I would call them and ask for a will call tag on the cam to have them look at it now before using it twocents I have one on its way(custom hydraulic flat lifter cam grind nitrided) now for a SB Mopar pump gas stroker motor, if it looks like yours I will have them pick it up and replace it
Re: New COMP CAMS Nitriding wearing off? [Re: Cab_Burge] #2218823
12/22/16 05:53 AM
12/22/16 05:53 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
Nitriding isn't a surface treatment as such, but a process that hardens the metals surface to a shallow depth. Not sure what's going on with the surface of your lobes though.
Alan Jones
Re: New COMP CAMS Nitriding wearing off? [Re: LA360] #2218873
12/22/16 11:40 AM
12/22/16 11:40 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I thought the black coating was there to just prevent rust.
Re: New COMP CAMS Nitriding wearing off? [Re: B5496RR] #2218903
12/22/16 12:34 PM
12/22/16 12:34 PM
USA
B5496RR Offline OP
B5496RR  Offline OP
USA
Im hoping it's only a coating to prevent rust.
Maybe others with chime in
I have a call into Comp cams and I'm waiting to hear back from them now
Re: New COMP CAMS Nitriding wearing off? [Re: B5496RR] #2218905
12/22/16 12:34 PM
12/22/16 12:34 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Just a question?
Before you came on here and expressed your concerns did you contact Comp about this. If so what did they say? If not why???
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: New COMP CAMS Nitriding wearing off? [Re: W.I.N. Racing] #2218914
12/22/16 12:43 PM
12/22/16 12:43 PM
USA
B5496RR Offline OP
B5496RR  Offline OP
USA
WIN racing,
Looks like we posted at the same time.
I have a call and pictures into them. Waiting to hear back.
I posted here last night while comp was closed hoping someone could shEd some light on this so I could sleep, if you know what I mean
Re: New COMP CAMS Nitriding wearing off? [Re: B5496RR] #2218968
12/22/16 01:54 PM
12/22/16 01:54 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
That looks typical to me. I had a crankshaft offset ground an then had it plasma ion nitride, came back all black, it was a strange type of finish like you said you could effect it by rubbing it but not completely remove it . I had the crankshaft polished on the journals after. If your worried about the stuff on the bearings journals and lobes, you could probably polish with scotchbrite. The stuff on the surface isn't the nitriding, it goes .010-.030 deep.
Re: New COMP CAMS Nitriding wearing off? [Re: B5496RR] #2219009
12/22/16 02:48 PM
12/22/16 02:48 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Is that black stuff "Parkerizing"? It's supposed to wear off quickly work
Re: New COMP CAMS Nitriding wearing off? [Re: B1MAXX] #2219014
12/22/16 02:51 PM
12/22/16 02:51 PM
iagree
I was told years ago that nitriding (a chemical hardening process)would penetrate down into the parent metal .030 up
Parkerizing is the process used to make the black coating on most flat tappet cams work
Re: New COMP CAMS Nitriding wearing off? [Re: B5496RR] #2219033
12/22/16 03:09 PM
12/22/16 03:09 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Nitriding process:
"The plasma nitriding process began in the 1920's as an alternative to conventional gas nitriding. After World War II the plasma nitriding process received widespread acceptance in Germany, Russia, China and Japan. The process was not introduced into the United States until after 1950 and has only been used as a production process for the past 20-25 years.
As technology progressed so did the plasma nitriding process. Improved controls and, in later years, the microprocessor have allowed engineers to consistently control the metallurgical properties of the nitride layer. This control, shorter cycle times, simplified masking techniques, less product distortion and a consistent reproducible process have lead to an increase in the popularity of the process in recent years.
The nitriding cycle begins by placing the product into the vacuum chamber and evacuating the chamber to a desired vacuum pressure. Upon reaching the desired vacuum, the unit is back-filled with a process gas to begin the preheating cycle. The standard preheating cycle ranges in temperature from 850 to 1050 Fahrenheit. When the preset heating time has elapsed, the product is subjected to an ion bombardment to clean impurities from the surface. The process gas is ionized by a voltage that is applied to the product.
This ionized gas collides with the product removing impurities from the surface and preparing the product for the nitriding process to begin. When the product surface has been cleaned sufficiently, the nitriding cycle begins. A controlled flow of nitrogen, hydrogen and methane are introduced into the chamber and ionized by the voltage applied to the product. The plasma generated by the ionization envelops the surface of the product with a blue-violet glow. The combination of the heat and energy of the plasma cause the gasses to react with nitride forming elements in the steel.
As the process gasses react with the elements in the steel, a wear resistant layer is formed. This layer can consist of a gamma prime Fe4N or an epsilon Fe2-3 N composition depending on the percentage of each gas in the chamber. The choice of the particular composition would depend on the application of the product in the field. In addition to increasing the steel's abrasion-resistance, the nitride layer also improves the fatigue strength and reduces the friction coefficient. The nitriding cycle is continued for 2 to 72 hours until the desired case depth of 0.002" to 0.024" is achieved. The processing time is dependent on the composition of the steel being nitrided and the required case depth. Low alloy steels are generally processed for longer cycle times."
I've been told it takes about 30hrs to do the cams.
Re: New COMP CAMS Nitriding wearing off? [Re: B5496RR] #2219055
12/22/16 03:40 PM
12/22/16 03:40 PM
USA
B5496RR Offline OP
B5496RR  Offline OP
USA
Thanks to all for the valuable information.
I have read that nitrided camshafts do not have the Parkerizing coating applied. Not sure if that is true or not.
Comp cams called me and said they are reviewing my pictures and will call back soon.
My gut feeling is that the cam is okay, but the look of a few lobes just didn't look right.
My opinion is the same or similar tone B1Maxx and others
@Fast, I assume you have seen many Nitrided camshafts. Do you have an opinion that you could share regarding the black substance on the lobes?
Re: New COMP CAMS Nitriding wearing off? [Re: GY3] #2219062
12/22/16 03:50 PM
12/22/16 03:50 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I know MANY on the CC wagon but I call Isky direct and go that route w/springs and cams...........Had a CC failure years ago at Pettis on the dyno and freshened it up and went w/a solid Isky ft and all was good........
Re: New COMP CAMS Nitriding wearing off? [Re: B5496RR] #2219152
12/22/16 06:03 PM
12/22/16 06:03 PM
So. Burlington, Vt.
So. Burlington, Vt.
I don't recall having anything "rubbing off" on the nitrided cams, but because of what the process is I don't think I'd be too alarmed/concerned about it.
I guess I don't feel like the nitriding can just "rub off", so I probably would just clean it and run it, but I'll be interested in hearing what they(Comp) say about it and whether or not my actions would have been the right call or not.
Re: New COMP CAMS Nitriding wearing off? [Re: B5496RR] #2219456
12/23/16 07:25 AM
12/23/16 07:25 AM
P
Porter67 Offline
Porter67  Offline
P
Comp has several articles online of there process...
Depending on the speed and makeup of these nitrogen ions, some of them penetrate as far as .010-inches deep into the cam, while others bond themselves into the surface strata. The process creates three separate layers during the process. The deep layer, which provides strength against metal fatigue, is called the diffusion zone. A middle layer, called the compound zone, guards against abrasion and increases strength, while the surface layer affects the initial wear-in behavior of the cam, and gains lubricity from the nitriding process.
Re: New COMP CAMS Nitriding wearing off? [Re: B5496RR] #2219536
12/23/16 12:46 PM
12/23/16 12:46 PM
USA
B5496RR Offline OP
B5496RR  Offline OP
USA
I heard back from Comp cams. They couldn't make heads or tails of whether or not the camshaft is okay or not. They suggested that I send it back to them for inspection.
However, they are working a reduced schedule between Christmas and New year's which is understandable. But that means I wouldn't get the camshaft back for at least two weeks if this cam indeed checks out okay. If it's deemed faulty them I'm looking at three weeks for new cam to be ground and Nitrided.
This completely blows my plans for getting the engine back together and in the car during my vacation time over the break unless I decide to run the cam as is.
I would only assume that Comp would simply grind me a new cam simply to keep the customer happy and not have another bad product out in the field.
Comp did state " I'm not sure how it made it past quality control". I replied back with yeah, me either... Thanks Comp!
I gut feeling says the cam is okay, my eyes tell me otherwise...
@All, for those of you who have used a Nitrided cam, does the black finish wear off after break in or normal use? Or is the black finish always present?
Re: New COMP CAMS Nitriding wearing off? [Re: B5496RR] #2219541
12/23/16 12:53 PM
12/23/16 12:53 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
There completely blows my plans for getting the engine back together and in the car during my vacation time over the break.
I'd like to say I'm surprised.
I'm not.
Re: New COMP CAMS Nitriding wearing off? [Re: B5496RR] #2219546
12/23/16 01:00 PM
12/23/16 01:00 PM
Kirkland, Washington
Pacnorthcuda Offline
Wow. This does not speak well for Comp Cams.
Re: New COMP CAMS Nitriding wearing off? [Re: B5496RR] #2219571
12/23/16 01:31 PM
12/23/16 01:31 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
the black finish on my nitrided cam mostly wore off where the lifters ride. i had my valley cover off after a few hundred miles to just take a look at things. the lifters i pulled looked to be spinning ok. i also had a few small scrape marks on the cam where the black finish came off when i assembled the engine. i didn't handle it much so i didn't have any issues rubbing it off. seems to be ok though.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
