Re: Anyway to get a VIN tag on dash for car you want to restore?
[Re: DAYCLONA]
#2218298
12/21/16 12:16 PM
12/21/16 12:16 PM
Posts: 9,407 Brantford Ontario
69_SIX_PACK
Brantford Ontario
We had a neighbor across the street from the shop, who owned a cherry 69 A12 RR, one day the car caught fire (electrical trunk fire) while parked in his yard, 1/2 the car was basically gone, the (ORIGINAL) owner was devastated,naturally he turned to us to "save" his car, he didn't want just another A12, he wanted his car, as so many owners in this type of situation did, he knew a rebody was the only way, he found the donor (base RR) and demanded everything that could be salvaged from his car be transferred, including all "numbers", his car was restored to his wishes, basically reborn from it's ashes if you will, he had no intention to defraud anyone, nor did we, that how things were done, to some, that's saving a car, to others today, it's fraud, back in the day it was no harm, no foul, and today I still see it as no harm
I promised myself not to get into these discussions anymore cause I feel like I am just spinning my wheels. We have a difference of opinions. I am not sure where we have common ground other than we like Mopars. Your Watermelon Daytona is one of my favourite cars. But where you see it as saved I see it as not only an A12 was lost but it ended up taking another Road Runner with it. I can't control what other people choose to do with their property but if you asked my opinion I would have rather seen the numbers to have stayed intact on the donor car and just the parts switched over. I could dig that and would have found the car interesting. With it now, not soo much. Again I just don't see why switching over the numbers is important to you guys who claim not to be interested in numbers, investments, money etc...I must be missing something. Dave
[Re: EL5 71]
#2218404
12/21/16 03:15 PM
12/21/16 03:15 PM
Posts: 18,157 Mass
DAYCLONA
Mass
I believe it's just the way things are headed to save some of them. Rebodying has been around since man put wheels to an axle
[Re: 69_SIX_PACK]
#2218411
12/21/16 03:29 PM
12/21/16 03:29 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Dave, for some they "need" the numbers, the "numbers" are their part of self satisfaction in a rebody/restoration I guess, for me, like I stated, the only numbers that matter are the ones the RMV/DMV "likes", or the ones that I have a clean title to, and or a vehicle they came with... Someone on here once "challenged" me that I never used "numbers" from a /6,318 car on a vehicle of so called "greater value" numbers wise, I told them they lost that bet, I have used /6,318 numbers on some big blk higher end vehicles, because I truly don't care about the "numbers" in the sense that most restorer/investors/collectors do, if I buy a car much like the OP is interested in, my priority is a set of clean numbers to title/tag the vehicle, if "high end numbers" fall into my hand, so be it, usually my desired builds are already planned, long before the vehicle is found, personally I've never built a vehicle to "found" numbers, but I do know of plenty that have been built this way, often for personal reasons, not immediate resale Mike
[Re: Wizard]
#2218422
12/21/16 03:38 PM
12/21/16 03:38 PM
Posts: 8,902 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Again I just don't see why switching over the numbers is important to you guys who claim not to be interested in numbers, investments, money etc...I must be missing something. The only thing you seem to be missing Dave is the whole point of this thread. The OP has a car he wants to rebuild but it has no numbers.
[Re: DAYCLONA]
#2218605
12/21/16 09:38 PM
12/21/16 09:38 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
...... he didn't want just another A12, he wanted his car, ........ This statement really doesn't make any sense. You/ya'll/he took another car and put his running gear in it and maybe the dash frame and the numbers, with an electrical fire significant enough to destroy a car, even in the trunk, smoked the interior so reasonable assumption that was replaced, reasonable assumption that it took out the gauges and all of the harnesses, he might have been able to move over the front fenders, grille and front suspension, maybe front rims but again if it destroyed the car from the rear the rear rims were probably warped. So what exactly of "his car" was left, really no more his car than the VW down the street. Again to the original car of the thread, the reason the OP wants to save the car is he feels it's something special, EL1 4 speed, putting bogus numbers on the car loses all it's original identity. It would be nice if these cars got a rebuilt/salvage title then they would be branded so unsuspecting buyers would know. I thini I would be more open to it if that was the case. If people were truly wanting to be honest about what they were doing they would report it to any applicable registry to hopefully avoid the truth getting lost. The only reason to change numbers is to deceive someone, even if it's the DMV, there is an intention to deceive.
Careful, your character's showing!
[Re: Wizard]
#2218631
12/21/16 10:33 PM
12/21/16 10:33 PM
mopar346
I personally wouldn't go to that extent on a car, almost any car. Granted if a trunk gutter is good I would reuse it along with any other part but I would not just move the number section over but that's me I realize it is done regularly. And yes when just the number section is moved over it is in attempt to deceive in my view. Age old question, at what point is it no longer the original car. I have personally come to the conclusion that it is the passenger compartment/cage. Cowl, firewall, a-pillars, rockers, roof frame and rear quarter window structure area, you get my thought. Then I have to ask myself what if just one rocker needs replaced, or the cowl but the rear section is fine and then what about all the cars that were back halfed as a result of a collision and insurance repair early on. The water on that is very muddy, complete body replacement is not muddy. I'll try to stay out from here but would like to know the opinions to my first questions.
Only way to get a legal VIN
[Re: DAYCLONA]
#2218640
12/21/16 10:48 PM
12/21/16 10:48 PM
Posts: 29,656 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
I believe it's just the way things are headed to save some of them. Rebodying has been around since man put wheels to an axle Swapping VINs is not acceptable. Slavery has been 'around' for thousands of years but it will never be 'right'. So, your argument is invalid. Time spent doing wrong will never make the wrong right nor acceptable. The OP wanted a solution for a car with no VIN - which can be done legally as suggested on the first page of this thread. Apply to the DMV / BMV for a state issued VIN & be done with it - legally. Anyone suggesting otherwise is just damaging their own reputation worse than it already is. Quite frankly, I am astonished that Tom allows members that encourage felonies over & over again.
Re: Only way to get a legal VIN
[Re: EL5 71]
#2218671
12/21/16 11:42 PM
12/21/16 11:42 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
Im not really sure but I dont think asking questions or voicing opinions on rebodying and moving vins over is encouraging felonies. Certainly not in this particular thread, but I believe its a topic that many of us Mopar enthusiasts should talk about. Its hard to really draw a definitive line about this. Maybe alot of hemicuda ex-race car restorers should be in jail right now. Were they doing the right thing? The wrong thing? Installing a dash and VIN from another and calling it good has been suggested in this thread. I'm pretty sure that is illegal in all 50 States
[Re: Wizard]
#2219410
12/23/16 01:32 AM
12/23/16 01:32 AM
Posts: 4,437 Omaha Nebraska
Brian_wo
Omaha Nebraska
Funny,factory has two bare shells,one gets tags for a lowly slant six,the other a Hemi and suddenly one is a highly sought after,the other just a low dollar turd yet they both started out exactly the same.
What if a guy at the factory accidentally put tags on the wrong car and later had to change them? Or stamped the wrong numbers? Factory error now worth tens times more?
who is that guy?
[Re: GY3]
#2219538
12/23/16 12:50 PM
12/23/16 12:50 PM
Posts: 18,157 Mass
DAYCLONA
Mass
The ONLY reason for VIN swapping and not using a state issued VIN after the original is gone is MONEY. Plain and simple. Your INTENT to defraud may not be there but 5-6 owners down the road when the story is neglected to be told, what happens then? A big, nasty lawsuit and Feds getting involved, that's what! Your quote sounds more like urban myth, or scare tactics employed by goody 2 shoer's to dissuade said action(s), your comparing the action of outright high dollar deceit vs placing some low end valued numbers to a low end valued vehicle, both long forgotten, where's this "money"? Perhaps if someone took you for HUNDREDS OF THOUSANDS of dollars or MILLIONS, you'd have the resources to recoup a judgement, but we're talking your basic overvalued Mopar junk here that everyone thinks is big bucks, even in the real world where high end collectors suspect they've purchased a vehicle that is "suspect" in some way, shape or form, it moves from their collections via trades, auctions, private sales, etc DAMHIK
[Re: Brian_wo]
#2219548
12/23/16 01:02 PM
12/23/16 01:02 PM
Posts: 92 Iowa
Davtona
Iowa
Funny,factory has two bare shells,one gets tags for a lowly slant six,the other a Hemi and suddenly one is a highly sought after,the other just a low dollar turd yet they both started out exactly the same. No the two bodies are not the same. Some very specific Hemi only parts in the frame work of the Hemi car. They only made 50 of the Hemi's for example versus maybe 5000 of the slant 6 cars. Hence the difference in value. Moving the Hemi tags and numbers to the slant 6 body devalues the remaining 49 Hemi cars.
