Twin turbo Small block #2218098
12/20/16 11:46 PM
12/20/16 11:46 PM
jacksonville,FLORIDA
slammedR/T Offline OP
Looking at building a twin turbo small block in the future, will be using a 48* R3 block but need to decide on what heads to run. I like my indy 360-1 cnc raised port heads and they are 6 bolt but Eddie keeps telling me to dump them.
So I was thinking of going W9 heads or the new Victor heads. I have a real good line on some 48* 6 bolt W9 heads with tall deck intake for a really good price. I was originally looking at the victor heads but I think they are 4 bolt only and think the 6 bolt head would hold the boost better.
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: Twin turbo Small block [Re: slammedR/T] #2218125
12/21/16 12:26 AM
12/21/16 12:26 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Why wouldn't your Indy's work boosted?
Re: Twin turbo Small block [Re: slammedR/T] #2218127
12/21/16 12:31 AM
12/21/16 12:31 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
The cylinder head doesn't mean much on a boosted motor. I made around 700hp with a .500" cam with only 250cfm of head.
How much are you looking to make? I'd guess a 360-1 would support 1500hp pretty easy.
Re: Twin turbo Small block [Re: justinp61] #2218128
12/21/16 12:31 AM
12/21/16 12:31 AM
They aren't known for the best reliability but I had a crack in number four once, since I had it fixed and sealed I haven't had any more issues with them.
racemagnum
Re: Twin turbo Small block [Re: dizuster] #2218130
12/21/16 12:33 AM
12/21/16 12:33 AM
looking for the 1500-2000 range, the cylinder heads matter over 1000hp trust me.
racemagnum
Re: Twin turbo Small block [Re: slammedR/T] #2218144
12/21/16 01:05 AM
12/21/16 01:05 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont know how much the W-9 would take pressure
wise.. they are a light head.. basically its a
cross between the W-7 and the W-8 and lightened
up to make a W-9.. if you could get a set of W-8s
they would be the BEST out there.. would the W-9
work.. sure
EDIT
what size turbos are you looking at to make 2000hp
and how much pressure.. I assume this will be a air
to water inner cooled
wave
Re: Twin turbo Small block [Re: slammedR/T] #2218196
12/21/16 02:44 AM
12/21/16 02:44 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
was thinking about the same as the P man.... W8 would be the go to head for boost.
Re: Twin turbo Small block [Re: MR_P_BODY] #2218202
12/21/16 02:57 AM
12/21/16 02:57 AM
Melbourne , Australia
LA360 Online boogie
LA360  Online Boogie
Try picking up some W8's if you can. Otherwise the Victor's would be worth looking at
Alan Jones
Re: Twin turbo Small block [Re: slammedR/T] #2218206
12/21/16 03:07 AM
12/21/16 03:07 AM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Last time I talked to Brett he told me I would have 5-7500k in a set of W8 heads
Re: Twin turbo Small block [Re: slammedR/T] #2218271
12/21/16 11:33 AM
12/21/16 11:33 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Weren't you thinking of a G3 build?
W9 are gonna take some machining to work. AMHIK
Re: Twin turbo Small block [Re: slammedR/T] #2218278
12/21/16 11:49 AM
12/21/16 11:49 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
There was a Duster on Drag Week with a boosted Indy headed small block. It was going faster everyday, I think he ended the week in the 8.70s? B3 Engines or something like that was on the back window.
68 Barracuda Formula S 340
Re: Twin turbo Small block [Re: slammedR/T] #2218323
12/21/16 01:02 PM
12/21/16 01:02 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
That duster has been 8.20's with indy heads and a single 98mm. At monster mopar it went 5.20's
Re: Twin turbo Small block [Re: slammedR/T] #2218344
12/21/16 01:52 PM
12/21/16 01:52 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The answer to "not enough CFM" is "more boost".
Boffin Emeritus
Re: Twin turbo Small block [Re: slammedR/T] #2218520
12/21/16 06:59 PM
12/21/16 06:59 PM
CJD AUTOMOTIVE Offline
I've got a twin turbo R3 with the new Victor heads and I'm right here in Jacksonville, too. Your welcome to call, come over, or talk with my engine builder.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
www.CJDAUTOMOTIVE.com
904-400-1802
"I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
Re: Twin turbo Small block [Re: CJD AUTOMOTIVE] #2218543
12/21/16 07:46 PM
12/21/16 07:46 PM
Sweet, when I get my truck running again I will have to cruise up there and check it out. Doing some upgrades I have been putting off and changing my oil pan
racemagnum
Re: Twin turbo Small block [Re: Bad340fish] #2221481
12/27/16 02:00 AM
12/27/16 02:00 AM
IL
knyech1 Offline
knyech1  Offline
IL
Big3. He was running an R3 block 400-something inch from what he told me, and he had to slow it way down because they wouldn't let him run faster than 8.50 with his cage, so he started out safe and tried to dial it in towards 8.50. He said its capable of 7's. I had a picture of the setup but can't find it smirk
Re: Twin turbo Small block [Re: slammedR/T] #2221526
12/27/16 05:01 AM
12/27/16 05:01 AM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
do a ebay search on w8 heads right now.. just a fyi
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: Twin turbo Small block [Re: slammedR/T] #2221542
12/27/16 10:00 AM
12/27/16 10:00 AM
SW WI
cudacustoms1 Offline
SW WI
How much HP can an R3 block take?
Re: Twin turbo Small block [Re: slammedR/T] #2221827
12/27/16 08:58 PM
12/27/16 08:58 PM
New York
polyspheric Offline
polyspheric  Offline
New York
More from a turbo than from NA or nitrous.
Boffin Emeritus
Re: Twin turbo Small block [Re: polyspheric] #2222085
12/28/16 08:35 AM
12/28/16 08:35 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
its not the flow of the indys they are prone to cracking and with boost it increases that even more so prevention is better than cure
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
