You will scatter the engine all across the salt with a typical drag car oiling system. You will not be able to sustain 8000rpm for more than a mile at that rpm/ hp. Dry sump or leave it parked in the garage.
Yeas that ole #4 main will be cherry red at the end of a mile
yea yea the ole nascrap trick of running a hose from oil pump to the unused port at the rear to " slow oil down" makes me laugh
when I get to see inside one a see that happening I will believe it
reminds me I have asked my wife to take some of my cremated ashes and drop a spoonful at a time down the carb of a hot engine running wide azz open so I can finally see what is going on in there--she does not have to move the timing and do it over and over I just want one glance LOL
DRY SUMP well designed by someone that KNows!! Your only hope and that idea by sasquatch about a well designed Charlies pan is one to take to heart
