Page 4 of 6 1 2 3 4 5 6
Re: "Landy Lump" scoop too obnoxious for 10-sec Street Car? [Re: keefe] #2214752
12/15/16 11:00 PM
12/15/16 11:00 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
I really really like the look
Re: "Landy Lump" scoop too obnoxious for 10-sec Street Car? [Re: BradH] #2214759
12/15/16 11:04 PM
12/15/16 11:04 PM
If your going to be a leader, your going to make a lot of people look at your backsides whistling up stirthepot devil
Re: "Landy Lump" scoop too obnoxious for 10-sec Street Car? [Re: BradH] #2214770
12/15/16 11:16 PM
12/15/16 11:16 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
That would work for me!!
If you're going to get something like that done, might as well make it fit the stuff you want to use.
Re: "Landy Lump" scoop too obnoxious for 10-sec Street Car? [Re: BradH] #2214772
12/15/16 11:17 PM
12/15/16 11:17 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Personally I really like the looks and the fact that it will actually WORK vs just a clearance bump in the old non working well scoop.........LOL!!!
Re: "Landy Lump" scoop too obnoxious for 10-sec Street Car? [Re: BradH] #2214784
12/15/16 11:28 PM
12/15/16 11:28 PM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
Looks killer!
Re: "Landy Lump" scoop too obnoxious for 10-sec Street Car? [Re: BradH] #2214786
12/15/16 11:32 PM
12/15/16 11:32 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Looks great and should work better too!
Re: "Landy Lump" scoop too obnoxious for 10-sec Street Car? [Re: BradH] #2214787
12/15/16 11:33 PM
12/15/16 11:33 PM
K
KOS Offline
KOS  Offline
K
i love it.....good job
Re: "Landy Lump" scoop too obnoxious for 10-sec Street Car? [Re: KOS] #2214804
12/16/16 12:03 AM
12/16/16 12:03 AM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
Love it or hate it, it is what it is now. shruggy It'll certainly be more functional, regardless.
I think The MoPig is going to be taking on more of a Drag Pak flavor, beyond just the scoop. I'm switching the front tires to M&H radial skinnies, which will lower the front a bit and add a bit of rake, plus I may drop the torsion bars a bit more, too, to get the ride height & stance I have in mind.
I've also decided to re-paint the bumpers in the body color, black out the grill, put a front air dam on it, etc. So, it'll not only have a new -- and hopefully faster -- engine combination, but something of a re-imaging, too. It'll look less like a common(?) street car that happens to run in the 10s, and more like a street/strip car that I'm hoping will be able to get into the LOW 10s.
He11, I may even get custom "MOPIG" plates for it. whistling
Re: "Landy Lump" scoop too obnoxious for 10-sec Street Car? [Re: keefe] #2214807
12/16/16 12:05 AM
12/16/16 12:05 AM
BradH Offline OP
BradH  Offline OP
Originally Posted By keefe
I think it looks good Brad. I have something similar,
AAR/Stinger's bolt on A-body hood with 4 1/2" Twin Snorkel(1031XLSc). I got to give Dustedu a big thumbs up, I saw it on his car and he gave me all the imfo...
Keefe - Is your car any closer to running again than mine? grin And Douglas better have his sh!t running when I come rumbling back into MIR, too. tonguue
Re: "Landy Lump" scoop too obnoxious for 10-sec Street Car? [Re: cudaman1969] #2214811
12/16/16 12:10 AM
12/16/16 12:10 AM
BradH Offline OP
BradH  Offline OP
Originally Posted By cudaman1969
Originally Posted By BradH
This is what it looks like this afternoon.
To each his own but me no likey.
Not a problem! You no pay-ee for it, either. haha
Re: "Landy Lump" scoop too obnoxious for 10-sec Street Car? [Re: BradH] #2214829
12/16/16 12:29 AM
12/16/16 12:29 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I like it, looks great!!
Re: "Landy Lump" scoop too obnoxious for 10-sec Street Car? [Re: BradH] #2214846
12/16/16 12:56 AM
12/16/16 12:56 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Dig it man................. punkrocka
Re: "Landy Lump" scoop too obnoxious for 10-sec Street Car? [Re: Thumperdart] #2214854
12/16/16 01:19 AM
12/16/16 01:19 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
1000% improvement. I think it's tasteful and functional which is the perfect balance.
Re: PICS OF "DRAG PAK'D" T/A HOOD SCOOP ADDED [Re: BradH] #2214968
12/16/16 08:54 AM
12/16/16 08:54 AM
Mo.
racerx Offline
racerx  Offline
Mo.
That will work for me thumbs do you have plans for an air pan?
Re: PICS OF "DRAG PAK'D" T/A HOOD SCOOP ADDED [Re: racerx] #2214974
12/16/16 09:54 AM
12/16/16 09:54 AM
BradH Offline OP
BradH  Offline OP
Yep. I've already cut out a cardboard template and will be making it out of a thin piece of wood panel, same stuff that I used with my previous one. It did such an effective job of reducing heat transfer that you could put your hand on the top of the hood and feel the temperature difference between where the hood was exposed to engine heat and where it was noticeably cooler above where the air pan sealed up against it.
Re: PICS OF "DRAG PAK'D" T/A HOOD SCOOP ADDED [Re: BradH] #2214988
12/16/16 11:07 AM
12/16/16 11:07 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Will look better after paint...and the nekkid female Viking mural.. grin
Re: PICS OF "DRAG PAK'D" T/A HOOD SCOOP ADDED [Re: BradH] #2215014
12/16/16 11:57 AM
12/16/16 11:57 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
That is a good idea for an air pan.
One of the nicest ones I have seen was made out of a trashcan lid. Watched a couple of guys make a trash can air pan on a Buick on Drag Week 2014 trying to squeeze a few hundredths out to stay on the board.
68 Barracuda Formula S 340
Re: PICS OF "DRAG PAK'D" T/A HOOD SCOOP ADDED [Re: BradH] #2215503
12/17/16 05:30 AM
12/17/16 05:30 AM
Mo.
racerx Offline
racerx  Offline
Mo.
was there an performance advantage with the seal hood?
Re: PICS OF "DRAG PAK'D" T/A HOOD SCOOP ADDED [Re: BradH] #2215525
12/17/16 10:39 AM
12/17/16 10:39 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Looks good, I like it.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: PICS OF "DRAG PAK'D" T/A HOOD SCOOP ADDED [Re: BradH] #2215541
12/17/16 11:32 AM
12/17/16 11:32 AM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
I like that a lot! It'll look great on your Challenger.
