carbon fiber question #2214145
12/14/16 11:34 PM
12/14/16 11:34 PM
in front of the computer
8
80arrow Offline OP
80arrow  Offline OP
I'm thinking of getting a 4x8 sheet of carbon fiber to do my door panels and rear bulkhead. Any suggestions on where to get it and what thickness to use? I want to get it with one side glossy.
Re: carbon fiber question [Re: 80arrow] #2214153
12/14/16 11:44 PM
12/14/16 11:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Check with your local fiberglass shop... on the back
wall.. NHRA wants .032 alum.. so I would think the
same will work... its plenty strong enough at that
thickness but I dont know about fire
wave
Re: carbon fiber question [Re: 80arrow] #2214159
12/14/16 11:47 PM
12/14/16 11:47 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
What do you plan on cutting it with?
Mopar to the bone!!!
Re: carbon fiber question [Re: 80arrow] #2214172
12/15/16 12:03 AM
12/15/16 12:03 AM
VA
VPofGreen Offline
VPofGreen  Offline
VA
I did my door panels etc from sheet I got at Tim McAmis. IF you watch they will do $50 off the full sheet price occasionally. It is not on sale now though
https://timmcamis.com/shop/4-x8-carbon-fiber-sheet.html
Not sure about the rear bulkhead thickness.
I used tungston carbide jigsaw blade, works great. Also some dremel cutting wheels, but they tend to break often. Clean up the edges with sanding block etc and you can run a sharpie along the cut edge to recolor it black. Make sure to wear full protection on skin and use a respirator.
Re: carbon fiber question [Re: 80arrow] #2214179
12/15/16 12:18 AM
12/15/16 12:18 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I cut my carbon wing with a regular ole jig saw
Re: carbon fiber question [Re: FastmOp] #2214180
12/15/16 12:21 AM
12/15/16 12:21 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I did all my trim work on my CF hood with a jig saw
and a .040X4" cut off wheel on my air grinder
wave
Re: carbon fiber question [Re: 80arrow] #2214190
12/15/16 12:37 AM
12/15/16 12:37 AM
Midland,Tx
wyldebill Offline
wyldebill  Offline
Midland,Tx
You can buy door panel size pieces onot ebay
Re: carbon fiber question [Re: wyldebill] #2214228
12/15/16 02:26 AM
12/15/16 02:26 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Buying a full sheet is cheaper.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: carbon fiber question [Re: 80arrow] #2214234
12/15/16 02:31 AM
12/15/16 02:31 AM
East Coast
A/MP Offline
A/MP  Offline
East Coast
Carbon fiber is a general term. Just like there are many weaves and grades of fiberglass so too for CF. Many pitfalls when buying the product. Go to a fiberglass supplier. They have lists of the products available. You are better off buying CF that has epoxy in it. In order for the CF to be strong, it must be thoroughly wetted with epoxy. This is where most people screw up. You also need a vacuum press for complete saturation, air bubble removal ans moldability. Be wary of sheets that come from over seas, their quality is always suspect. Use a cut off wheel. It does not leave loose strands.
Re: carbon fiber question [Re: 80arrow] #2214316
12/15/16 11:37 AM
12/15/16 11:37 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Is the objective here cosmetics, insulation, strength/stiffness and/or spending money? work
Re: carbon fiber question [Re: 80arrow] #2214546
12/15/16 05:38 PM
12/15/16 05:38 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I got a blem a few years ago from Unlimited Products and it came shiney on one side but I hid mine behind speaker material............I cut it w/upholstery scissors.......... thumbs
Re: carbon fiber question [Re: 80arrow] #2214562
12/15/16 06:03 PM
12/15/16 06:03 PM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
Ultracarbon sells it buy the sheet. Its far from cheap but you wont find a better quality..
http://www.ultra-carbon.com/products/4x8-carbon-fiber-flat-sheets/
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: carbon fiber question [Re: 80arrow] #2214599
12/15/16 07:24 PM
12/15/16 07:24 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
Floyd Lippencott IV
Re: carbon fiber question [Re: jcc] #2214662
12/15/16 09:01 PM
12/15/16 09:01 PM
8
80arrow Offline OP
80arrow  Offline OP
Well its a race car so the main objective is to spend $ I guess ;-), lol. No mainly its for cosmetics. I'm redoing my car this winter and would like to do it the way I want it at this time. I'm tired of doing it to just get by and redoing stuff a year or two later. It'd be an added bonus if it reduces weight also. Looking for opinions and advice.
Re: carbon fiber question [Re: 80arrow] #2214745
12/15/16 10:54 PM
12/15/16 10:54 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
At least you aren't in denial. grin up
It is a pretty cool material to work with if its affordable, for its physical properties.
Re: carbon fiber question [Re: 80arrow] #2214769
12/15/16 11:15 PM
12/15/16 11:15 PM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
A straight 8 harness, 14 mil cloth wetted out with EA956, 2 plies, cured under vacuum will make a nice flat sheet to do door panels and trim parts with. The 14 mil twill weave is what you see a lot of as it looks fancier, but isn't any stronger than a straight weave. You would need a flat table, release film, Tedlar, A 4000, then a bleeder separator, perforated A 4000 or CHR III then bleeder cloth, then another layer of A4000 or Tedlar, breather material, either Felters N10 or #1000 glass, Tacky Tape and bagging film, and a vacuum pump.
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
Re: carbon fiber question [Re: 80arrow] #2214788
12/15/16 11:34 PM
12/15/16 11:34 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Buy it from McAmis, Haas, Jones etc and it will be the nice lite weight race carbon
Re: carbon fiber question [Re: 80arrow] #2215175
12/16/16 05:32 PM
12/16/16 05:32 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Not sure where you are located but I have two buddies that make carbon out here in the west. Can get you info if you like.
Re: carbon fiber question [Re: Slingshot383] #2215316
12/16/16 09:34 PM
12/16/16 09:34 PM
8
80arrow Offline OP
80arrow  Offline OP
I think I'd be better off to buy it done, lol. I've got no experience with carbon fiber or fiberglass.
Re: carbon fiber question [Re: Al_Alguire] #2215317
12/16/16 09:35 PM
12/16/16 09:35 PM
8
80arrow Offline OP
80arrow  Offline OP
I live in northern Minnesota. I'll have to pay shipping no matter where I get it
