Re: carbon fiber question
[Re: 80arrow]
#2214153
12/14/16 11:44 PM
12/14/16 11:44 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Check with your local fiberglass shop... on the back wall.. NHRA wants .032 alum.. so I would think the same will work... its plenty strong enough at that thickness but I dont know about fire
[Re: 80arrow]
#2214159
12/14/16 11:47 PM
12/14/16 11:47 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
What do you plan on cutting it with?
Mopar to the bone!!!
[Re: 80arrow]
#2214172
12/15/16 12:03 AM
12/15/16 12:03 AM
Posts: 81 VA
VPofGreen
VA
I did my door panels etc from sheet I got at Tim McAmis. IF you watch they will do $50 off the full sheet price occasionally. It is not on sale now though https://timmcamis.com/shop/4-x8-carbon-fiber-sheet.htmlNot sure about the rear bulkhead thickness. I used tungston carbide jigsaw blade, works great. Also some dremel cutting wheels, but they tend to break often. Clean up the edges with sanding block etc and you can run a sharpie along the cut edge to recolor it black. Make sure to wear full protection on skin and use a respirator.
[Re: wyldebill]
#2214228
12/15/16 02:26 AM
12/15/16 02:26 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
You can buy door panel size pieces onot ebay Buying a full sheet is cheaper.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 80arrow]
#2214316
12/15/16 11:37 AM
12/15/16 11:37 AM
Posts: 22,696 Bitopia
jcc
Bitopia
I'm thinking of getting a 4x8 sheet of carbon fiber to do my door panels and rear bulkhead. Any suggestions on where to get it and what thickness to use? I want to get it with one side glossy. Is the objective here cosmetics, insulation, strength/stiffness and/or spending money?
[Re: 80arrow]
#2214546
12/15/16 05:38 PM
12/15/16 05:38 PM
Thumperdart
State of confusion
I got a blem a few years ago from Unlimited Products and it came shiney on one side but I hid mine behind speaker material............I cut it w/upholstery scissors..........
[Re: 80arrow]
#2214562
12/15/16 06:03 PM
12/15/16 06:03 PM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
Ultracarbon sells it buy the sheet. Its far from cheap but you wont find a better quality.. http://www.ultra-carbon.com/products/4x8-carbon-fiber-flat-sheets/
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
[Re: jcc]
#2214662
12/15/16 09:01 PM
12/15/16 09:01 PM
Posts: 814 in front of the computer
80arrow
I'm thinking of getting a 4x8 sheet of carbon fiber to do my door panels and rear bulkhead. Any suggestions on where to get it and what thickness to use? I want to get it with one side glossy. Is the objective here cosmetics, insulation, strength/stiffness and/or spending money? Well its a race car so the main objective is to spend $ I guess ;-), lol. No mainly its for cosmetics. I'm redoing my car this winter and would like to do it the way I want it at this time. I'm tired of doing it to just get by and redoing stuff a year or two later. It'd be an added bonus if it reduces weight also. Looking for opinions and advice.
[Re: 80arrow]
#2214745
12/15/16 10:54 PM
12/15/16 10:54 PM
jcc
Bitopia
At least you aren't in denial. It is a pretty cool material to work with if its affordable, for its physical properties.
[Re: 80arrow]
#2214769
12/15/16 11:15 PM
12/15/16 11:15 PM
Posts: 684 St. Charles, MO.
Slingshot383
St. Charles, MO.
A straight 8 harness, 14 mil cloth wetted out with EA956, 2 plies, cured under vacuum will make a nice flat sheet to do door panels and trim parts with. The 14 mil twill weave is what you see a lot of as it looks fancier, but isn't any stronger than a straight weave. You would need a flat table, release film, Tedlar, A 4000, then a bleeder separator, perforated A 4000 or CHR III then bleeder cloth, then another layer of A4000 or Tedlar, breather material, either Felters N10 or #1000 glass, Tacky Tape and bagging film, and a vacuum pump.
1994 Undercover Chassis 125" altered
stack injected big block, soon blown and injected
Member of The Torque and Recoil Club
[Re: 80arrow]
#2214788
12/15/16 11:34 PM
12/15/16 11:34 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
I'm thinking of getting a 4x8 sheet of carbon fiber to do my door panels and rear bulkhead. Any suggestions on where to get it and what thickness to use? I want to get it with one side glossy. Buy it from McAmis, Haas, Jones etc and it will be the nice lite weight race carbon
[Re: 80arrow]
#2215175
12/16/16 05:32 PM
12/16/16 05:32 PM
Posts: 19,372 Las Vegas
Al_Alguire
Las Vegas
Not sure where you are located but I have two buddies that make carbon out here in the west. Can get you info if you like.
[Re: Slingshot383]
#2215316
12/16/16 09:34 PM
12/16/16 09:34 PM
80arrow
A straight 8 harness, 14 mil cloth wetted out with EA956, 2 plies, cured under vacuum will make a nice flat sheet to do door panels and trim parts with. The 14 mil twill weave is what you see a lot of as it looks fancier, but isn't any stronger than a straight weave. You would need a flat table, release film, Tedlar, A 4000, then a bleeder separator, perforated A 4000 or CHR III then bleeder cloth, then another layer of A4000 or Tedlar, breather material, either Felters N10 or #1000 glass, Tacky Tape and bagging film, and a vacuum pump. I think I'd be better off to buy it done, lol. I've got no experience with carbon fiber or fiberglass.
[Re: Al_Alguire]
#2215317
12/16/16 09:35 PM
12/16/16 09:35 PM
80arrow
Not sure where you are located but I have two buddies that make carbon out here in the west. Can get you info if you like. I live in northern Minnesota. I'll have to pay shipping no matter where I get it
