Re: What Happened?? [Re: moparphilll] #2211805
12/11/16 01:53 PM
12/11/16 01:53 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Put a plate in it and start it up. Not the first one I've seen break. I personally have had 2 do this. Replaced the plates and never had another issue with either car.
Doug
Re: What Happened?? [Re: moparphilll] #2213504
12/13/16 08:34 PM
12/13/16 08:34 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
You might get by with installing a new flex plate (and new bolts) and driving it, but my luck is the trans will die in short order. Since the trans is out, I'd send it in for a rebuild. The possible neutral drop cause for the damage flex plate, and the visual appearance of the trans itself would warrant a rebuild in my book.
Other then the normal motor concerns with buying a car like this, I would not have issues with the motor. It was hanging up on the broken flex plate, once that was resolved, the motor turned over OK. Gene
Re: What Happened?? [Re: moparphilll] #2213520
12/13/16 09:00 PM
12/13/16 09:00 PM
dogdays Offline
dogdays  Offline
Does Joe Dirt have a relative living up in the Dakotas?
I wish you well, Chargers are not to be wasted.
If you get tired of it, I've got a farm somewhere up US 52 that you can haul it to.......
R.
Re: What Happened?? [Re: moparphilll] #2213605
12/13/16 11:21 PM
12/13/16 11:21 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Could be that is was cracked for a while and someone kept driving and due to time and vibration it busted out the rest of the way in one swift bang.
I agree with sending the trans for a check, at a minimum pull the pan and look for metal parts, 727s aren't bad about showing material but you should get an idea by the smell of the fluid and any metal in the pan. twocents
Careful, your character's showing!
Re: What Happened?? [Re: mopar346] #2213892
12/14/16 02:57 PM
12/14/16 02:57 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
This , I have no idea how a neutral drop is responsible for that ???
There is no HARD mechanical connection between the back of the crank and the mainshaft of the transmission , total FLUID coupling inside the torque converter .
Neutral drops will only affect the trans internals , drive shaft and the rear end.
The many hours of running with that misalignment because one dowel pin was missing is what crack and ultimately broke that flexplate.
I'd be looking at the convertor snout and the bushing in the front drum for wear, along with changing the front seal.
Post up a picture of the converter snout ...
Re: What Happened?? [Re: moparphilll] #2213920
12/14/16 03:53 PM
12/14/16 03:53 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
That's a fairly common failure on the early Cummins trucks. I've seen a cracked plate on a gas engine too.
I wouldn't be overly concerned. Someone just let it a cracked one go to long and it finally failed.
- Stu Harmon
Re: What Happened?? [Re: JohnRR] #2214301
12/15/16 10:28 AM
12/15/16 10:28 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
x2. You should have two dowel pins - and you'll need the 2nd one when you put that back together... Unless you want another broken plate.
Re: What Happened?? [Re: moparphilll] #2214395
12/15/16 01:28 PM
12/15/16 01:28 PM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
Make sure both locating dowels are in the back of the block
Re: What Happened?? [Re: MO_PA] #2214399
12/15/16 01:33 PM
12/15/16 01:33 PM
Fargo ND
moparphilll Offline OP
Fargo ND
where do you get those dowels or do u just get one out of another block?
Re: What Happened?? [Re: moparphilll] #2214402
12/15/16 01:35 PM
12/15/16 01:35 PM
Fargo ND
Fargo ND
Found out the car had been Towed on car Dolly from Washington state to North Dakota...The drive shaft was NOT removed tsk
Re: What Happened?? [Re: moparphilll] #2214417
12/15/16 01:56 PM
12/15/16 01:56 PM
JohnRR Offline
JohnRR  Offline
That didn't cause the flexplate to break , but with that knowledge I would be going thru the trans. Pay close attention to the mainshaft surface that rides in the rear support and the rear support itself.
Re: What Happened?? [Re: moparphilll] #2214420
12/15/16 01:57 PM
12/15/16 01:57 PM
Western Md.
skicker Online tonguue
"The Champ"
skicker  Online Tonguue
"The Champ"
Western Md.
The pump is not in the rear of the trans. Shouldn't have mattered should it? shruggy
I'd agree its a good practice to remove it especially when going that far...but it could've never done that damage...
I believe the missing dowel is the reason for the damage... twocents
...FAFO...
Re: What Happened?? [Re: skicker] #2214435
12/15/16 02:13 PM
12/15/16 02:13 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Typically flat towing w/ the driveshaft left in is limited to something like 35 miles at fairly low speeds. I wouldn't chance it, I'd go through the transmission before attempting to install it. 2¢
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: What Happened?? [Re: moparphilll] #2214457
12/15/16 02:59 PM
12/15/16 02:59 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
You need both dowel pins. That top hole looks a bit oblong, like the trans case was moving?
With the transmission apart, you could even check the run out to the trans pump housing in the case and correct it if needed.
For offset dowel pins:
http://www.robbmcperformance.com/products/dowels.html
I would go through the trans and rebuild it. If your mechanically inclined, you could do it for $100-200 depending on the quality of parts used.
Re: What Happened?? [Re: 451Mopar] #2214512
12/15/16 04:27 PM
12/15/16 04:27 PM
Fargo ND
Fargo ND
GREAT Thanks for info and Link!!
Re: What Happened?? [Re: moparphilll] #2214850
12/16/16 01:09 AM
12/16/16 01:09 AM
missouri
ragin sonny Offline
ragin sonny  Offline
missouri
PHIL,YOU HAVE MOPAR'S BIGGEST LOW STALL TRUCK CONVERTER. UPGRADE TO A BETTER/SMALLER CONVERTER/FLEXPLATE WHEN YOU REBUILD YOUR TRANS. THAT THING IS PROBABLY FULL OF TRASH ANYWAY. YOU'LL WANT A NEW CLEAN CONVERTER FOR THAT CHARGER. NICE CAR.
Re: What Happened?? [Re: mopargem] #2214911
12/16/16 02:44 AM
12/16/16 02:44 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Originally Posted By mopargem
Are the locator dowl pins in the bell housing. Misalignment can cause a flex plate to fail
Correct diagnoisis🔝.
It happens quite often from storing the block on the floor with the dowels pointing to the ground.
Since the are tapers they need to be pulled out so more than the taper is engaged to the transmission holes, which also have a lead in.
Re: What Happened?? [Re: moparphilll] #2214920
12/16/16 03:12 AM
12/16/16 03:12 AM
minnesota
dondon Offline
dondon  Offline
minnesota
I had a cracked flex plate on my 72 duster. I put a new flex plate on and three weeks later it broke again, so I knew I had a probelm. I was told the torque convertor (front punp) bushing was worn out, which caused the convertor to wobble and crack the flex plate. Replaced the bushing in the front pump and the convertor. Probelm solved.
Re: What Happened?? [Re: dondon] #2215456
12/17/16 02:15 AM
12/17/16 02:15 AM
Fargo ND
Fargo ND
Thanks for all the input: up I am going to replace torque converter and get dool installed have not took pan off the tranny yet to see what it lloks like..
Re: What Happened?? [Re: moparphilll] #2216476
12/18/16 08:16 PM
12/18/16 08:16 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Hard to really see the condition of the converter snout in the picture, but in my experience missing pins or a mis-aligned bellhousing will usually junk the front pump bushing and converter snout far before it would break the flex plate.
So with that said, I would at least change the front pump bushing and seal if you don't go through the whole trans.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
