Who/How to Repair Headlight Trim Ring #2213022
12/13/16 03:51 AM
12/13/16 03:51 AM
Seattle, WA
rss Offline OP
rss  Offline OP
Seattle, WA
I was a bit overzealous in trying to remove a rusted screw from one of my headlight assemblies, which resulted in this tab breaking off. It appears that the tabs were attached to the trim ring with two very small spot welds. I'm assuming that someone must have run into this before, so am hoping for some thoughts on how to make this repair.
Re: Who/How to Repair Headlight Trim Ring [Re: rss] #2213191
12/13/16 10:43 AM
12/13/16 10:43 AM
moparx Offline
moparx  Offline
if you are good with a tig, you could drill two tiny holes where the spots were on the tab, form a piece of copper sheet the same diameter as the ring od, clamp the three pieces together where the original tab was located with the copper plate on the very outside of the ring, then tig together. i'm not sure of the tig rod to use, but i think it is 308 in about 1/16" diameter. [the ring and tab are stainless] the copper is used in case you would burn through the ring, the rod would have a backing for the fill. or just get another ring ? aren't they all the same if in the same position [high or low] ? just a thought.
beer
Re: Who/How to Repair Headlight Trim Ring [Re: rss] #2213198
12/13/16 10:50 AM
12/13/16 10:50 AM
Indianapolis, IN
B5Cuda440-6 Offline
B5Cuda440-6  Offline
Indianapolis, IN
It's tough to tell from the picture, but if those are the trim rings for the 70 or 72-74 Cuda 1 head light system, I have 2 extra NOS pieces if you are interested. Send me a PM.
Re: Who/How to Repair Headlight Trim Ring [Re: rss] #2213483
12/13/16 07:49 PM
12/13/16 07:49 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
The auto industry uses adhesives to bond sheet metal together on new cars. You could easily use a two part adhesive to reattach that tab. I'm not talking about JB weld. Go to an auto body shop and see if they would squeeze out a little bit from their applicator gun.
Re: Who/How to Repair Headlight Trim Ring [Re: burdar] #2213794
12/14/16 11:23 AM
12/14/16 11:23 AM
moparx Offline
moparx  Offline
that is a good alternative. if going that route, clean, clean, and clean again the area of attachment. then rough up the bond area and clean again. when the body shop gives you a dab, have your clamping system ready. a "c" clamp or a like vicegrip will work for this. and if you can, using the bucket as a jig, bolt the ring in place, including the tab. glue and clamp, removing the squeeze out. let set up over night before removing the vice grips or "c" clamp. the panel adhesive is surprisingly stronger than you think.
beer
Re: Who/How to Repair Headlight Trim Ring [Re: rss] #2213826
12/14/16 12:27 PM
12/14/16 12:27 PM
St. Louis, Mo
3
318 Stroker Online content
318 Stroker  Online Content
St. Louis, Mo
I think I'd start with a Moparts ad in the parts wanted section. I'll bet a lot of guys have a lot of them in their parts stash, and I can't imagine they'd want much for one.
Re: Who/How to Repair Headlight Trim Ring [Re: rss] #2213987
12/14/16 06:41 PM
12/14/16 06:41 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I bet Dorman makes a new replacement if not a resto type need.
Don't be the exception.
Re: Who/How to Repair Headlight Trim Ring [Re: rss] #2214146
12/14/16 11:35 PM
12/14/16 11:35 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Do you need it to work or be perfect?
2 quick tack welds from a mig will fix that right up.
Takes longer to clamp the parts than to zap it.
Angry white pureblood male
Re: Who/How to Repair Headlight Trim Ring [Re: rss] #2214223
12/15/16 02:18 AM
12/15/16 02:18 AM
ohio
bbtrux Offline
bbtrux  Offline
ohio
absolutely correct. even a mig will work. If a buddy has stainless wire in his machine that would be best.
Re: Who/How to Repair Headlight Trim Ring [Re: rss] #2216820
12/19/16 03:33 AM
12/19/16 03:33 AM
Seattle, WA
rss Offline OP
rss  Offline OP
Seattle, WA
It's for a driver (70 Cuda) so it doesn't need to be perfect. Just needs to work. Thanks for all the replies. I like the adhesive idea, but honestly was just thinking about trying JB Weld. If it doesn't hold up, I can always try another option. I have a mig welder but was afraid that might be overkill. I'll practice on some smaller stuff first if I decide to go that route.
Thanks again!
Re: Who/How to Repair Headlight Trim Ring [Re: rss] #2216839
12/19/16 05:42 AM
12/19/16 05:42 AM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
I think I have one I can send you if you want. PM me if you do so I won't forget to look
Re: Who/How to Repair Headlight Trim Ring [Re: rss] #2216954
12/19/16 01:58 PM
12/19/16 01:58 PM
fargo,nd
fk5hemi Offline
fk5hemi  Offline
fargo,nd
Why all the screwing around on a $5 part?
Re: Who/How to Repair Headlight Trim Ring [Re: rss] #2222546
12/29/16 12:44 AM
12/29/16 12:44 AM
missouri, USA
moparmojo Offline
moparmojo  Offline
missouri, USA
How about two small holes drilled where the spot welds go through the tab then solder them on .
