Page 4 of 4 1 2 3 4
Re: Mopar stage 6 heads [Re: fast414] #2210573
12/09/16 11:10 AM
12/09/16 11:10 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
....and Summit actually shows both the 4150 and the 4500 intake for $249. Bet if they don't happen to have it on shelf, you can't get them.
Re: Mopar stage 6 heads [Re: fast414] #2210650
12/09/16 01:33 PM
12/09/16 01:33 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Blo---By the looks of the front end of that car...... I'm gonna say you were expecting more than 11.20's.
Any idea what it weighs?
Brad, didn't those intakes basically have MW sized port runners that were necked down to std port openings at the flange? Or am I remembering that wrong?
I think I only tested two motors on the dyno with one of those...... Yours and one other.
As I recall yours had some work done to it, but I don't recall how it compared power-wise to the others.
The other motor that I tried one on the intake was ootb, and it was down on power in the lower and mid-range, and had a narrower band up top where the big numbers were.
I would think the spacers(mounted and blended) and a new TF intake would probably be better, but how much better would be the question.
I would think in a "race" application, the heads opened to MW size, with MW spacers would be in order and either an Indy or Super Victor manifold.
Re: Mopar stage 6 heads [Re: fast414] #2210676
12/09/16 02:29 PM
12/09/16 02:29 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
It weighs 3,150 with driver.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Mopar stage 6 heads [Re: fast68plymouth] #2210704
12/09/16 03:07 PM
12/09/16 03:07 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Correct, which goes to my comment that the Stage VI intake was really intended for a MW 4500 build.
My Helgeson-ported intake made more peak HP, although only by a couple, than every other intake we tested that time. However, it also had a big dip in the torque curve under 4K RPM that the other intakes didn't have. I think it was too big in the plenum and had too much runner taper for a standard-port 440" engine; modified like mine and used with another 50 cubes and it might work OK for this 500 crate combination.
Re: Mopar stage 6 heads [Re: fast414] #2211303
12/10/16 04:10 PM
12/10/16 04:10 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
I was hoping for mid 10's laugh2
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Mopar stage 6 heads [Re: BloFish] #2211315
12/10/16 04:28 PM
12/10/16 04:28 PM
BradH Offline
BradH  Offline
Found a couple of pics of the RH-modified Stage VI 4150 intake. Compare these to an unmodified intake and you'll see where Helgesen did a lot of radiusing of the transition into the runners because of major turbulence issues he found "as cast".
Re: Mopar stage 6 heads [Re: BloFish] #2211843
12/11/16 03:06 PM
12/11/16 03:06 PM
So. Burlington, Vt.
So. Burlington, Vt.
Race weight? Or 3150 + driver?
Obviously it's not that hard to go mid-10's with a 500" motor in an A body.....although at the same time I'm not so sure that just replacing the heads on the motor with those CNC ported ones will be enough to get you from 11.20's to 10.50's without a few ofher changes too.
Re: Mopar stage 6 heads [Re: fast414] #2212019
12/11/16 07:47 PM
12/11/16 07:47 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Yeah, that's with me in it. I'm sure with some knowledgeable suspension tuning and this head work, 10.50's are easily obtainable.
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Mopar stage 6 heads [Re: fast414] #2248946
02/07/17 03:16 AM
02/07/17 03:16 AM
Someplace you aren't
SomeCarGuy Online content
SomeCarGuy  Online Content
Dwayne,
If a worked set were to be found on the cheap, is there a substantial gain to running an RB intake on a B block? Or just skip these and run any of the other good choices out there?
I want my fair share
Re: Mopar stage 6 heads [Re: fast414] #2249089
02/07/17 02:10 PM
02/07/17 02:10 PM
So. Burlington, Vt.
So. Burlington, Vt.
IMO, they would have to be priced extremely wallet friendly, and be basically "done" by a reputable shop before I would even consider them.
They only make any sense if you already have them, and/or can do the work yourself.
There are just too many other options out there now to make stage 6's an "attractive" choice these days.
Page 4 of 4 1 2 3 4
