Building low compression 440 (first post) #2210995
12/10/16 12:38 AM
12/10/16 12:38 AM
MONTANA
Benson Offline OP
Benson  Offline OP
MONTANA
Hi, this is my first post on this particular forum. I recently purchased a 1975 440 and 727 torqueflight out of a Chrysler imperial. During stripping the engine down to the bare block, I was surprised to find the engine has little internal wear what so ever. No ridge in cylinders at all. Due to the low compression of this 440 (most likely 8:1 compression), I'm questioning what power I can make with an intake, carb and cam swap. The motor is going into a 84 dodge Short box 4x4 pickup with 3.55 gears and a auto trans. The truck weighs about 5000 lbs give or take. I would like to make 375 hp or slightly better. Any advice? Thanks for any input
Re: Building low compression 440 (first post) [Re: Benson] #2211008
12/10/16 12:57 AM
12/10/16 12:57 AM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Welcome to the forum smile
Are you just planning to re-ring, hone and reassemble? Now would be the time for better pistons. Actual CR may not even be 8:1... What's the budget? work
In a 5000 lb truck I'd recommend a short cam with lots of low-end torque. 375 hp should be easy from a 440.
Re: Building low compression 440 (first post) [Re: Benson] #2211011
12/10/16 01:07 AM
12/10/16 01:07 AM
Pa. U.S.A.
moparborn Offline
moparborn  Offline
Pa. U.S.A.
Do you have a budget?
Closed chamber heads and thin head gaskets are a good start.
Re: Building low compression 440 (first post) [Re: Benson] #2211029
12/10/16 01:36 AM
12/10/16 01:36 AM
MONTANA
Benson Offline OP
Benson  Offline OP
MONTANA
I am on a budget. I would say im willing to spend 3,000 on this engine. Im looking to re ring/re bearing and re assemble this engine. Have a set of 250# casting heads I'm looking to possibly use. If i can find a set of 915# castings, it will opt for those with aluminum heads being out of the question.
Re: Building low compression 440 (first post) [Re: Benson] #2211064
12/10/16 03:06 AM
12/10/16 03:06 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Best bang for the buck will be just cleaning it up and running it. Dont go changing rings and bearings. If it turns over freely now, we can postulate it will run ok. In other words, these rings and bearings are seated and should work fine now unless a bearing is spun and your screwed anyway. Sounds like you have a perfect candidate for just bolting on a few things. Compression ratio will suck, but changing pistons is money and you will end up figuring out it has some taper to it and want to bore eventually. Then standard hi comp pistons are garbage to you.
Another member recently tore down and engine and spent some money, on a budget, then had to spend more since you basically cannot just tear into one and piece meal the thing. You might find that thread, i think it was 71adam440 or something like that.
Pick your cam and a good timing set. Then look to the heads, maybe do a valve job or guides. You could find a set of 915 heads sure, spend money on them, then trash them later when you decide on a full rebuild and aluminum heads. That's just cash burned for a small improvement.
If you go the low buck route(many people have done these), plenty of budget becomes available for other parts of the truck. You'll soon find things to spend on. Or buy new rings and bearings now and buy them again for the full rebuild, which could be as soon as something goes awry doing a rering and bearing job.
I want my fair share
Re: Building low compression 440 (first post) [Re: Benson] #2211089
12/10/16 04:48 AM
12/10/16 04:48 AM
For your deal and budget I would look at using a set of 440 6 pak forged pistons with new rings, bearings and a better camshaft and timing set. You should have the new parts balanced to that crankshaft and balancer so it doesn't shake with the new parts thumbs Make sure and use that original torque converter also as those motors are externally balanced by using weights on the converter and balancer.
Good luck, let us know what you decide to do thumbs
Re: Building low compression 440 (first post) [Re: SomeCarGuy] #2211094
12/10/16 05:02 AM
12/10/16 05:02 AM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I found a 1973 440 MH engine and trans on the Tacoma, WA CL for $100.00 and beat 5 other guys to the seller to pick it up. It had been bought from a wrecked MH 20 years earlier and stored at a body shop, covered up and it looks it up . It is sitting in my shop now and when it warms up around here, I will pull the spark plugs, drain the oil and examine it, if it passes I will give it 4 qts of fresh Walmart 10w30 oil and spin over the oil pump with my 1/2" drill motor while I turn the motor over with a breaker bar at least 2 or 3 complete revolution and check a mechanical oil pressure gauge to see where it falls. If it looks good then I will do a compression test while it hangs on the cherry picker (it came assembled with starter, alternator, ThermoQuad, etc.) Parts alone are well worth the $100.00 and it is for a club project rat rod so expectations are not high and the chassis is a model A frame with a T-Bucket body, so it should be fun for all. up
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Building low compression 440 (first post) [Re: Benson] #2211100
12/10/16 05:47 AM
12/10/16 05:47 AM
Tacoma, Washington USA
Adam71Charger Offline
Hey somecarguy that was I. I ended up spending over budget because I found some bad bearings, and decided to re ring and re bearing. That was inexpensive, but when I got the bright idea to use an autozone tool to get rid of the ridge at the top of the cylinders, I messed them up good. So, i had to have the block bored, and since I was already shelling out for block work, I got the crank ground and then figured I may as well get new rods and pistons.
Basically I learned that with good used short block, with at the most new rings, bearings, and drill hone, all you need is a pair of sidewinder or 440 source heads, aluminum intake, good carb, cam, possibly new pushrods and lifters, and you can have a 400+ hp engine for about $2000
Re: Building low compression 440 (first post) [Re: Benson] #2211116
12/10/16 09:59 AM
12/10/16 09:59 AM
SE Indiana
K
kowalski440 Offline
kowalski440  Offline
K
SE Indiana
Re: Building low compression 440 (first post) [Re: Benson] #2211245
12/10/16 02:46 PM
12/10/16 02:46 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Don't worry about what it might make for hp.
Just use the appropriate parts for the application and it will make what it makes.
As mentioned, keep the cam duration pretty short.
The 250 heads are a one year only, sort of odd ball deal.
They are essentially open chamber 516 heads with 1.74 exhaust valves.
So, they have the underwhelming 516 intake port.
Not really an issue for this type of build.
A little bowl work and a decent valve job would be worth it IMO, along with machining for posi-seals and setting them up with an appropriate spring.
Look the exhaust seats over good, if they're pounded out pretty wide, for that application, I think hardened exhaust seats would be a wise move.
Probably outside of your budget, but IMO the best way to update that short block would be to change the pistons to some KB quench domes.
It's really the best way to gain the compression and not grossly adversely affect the octane requirement........ Other than flat tops and closed chamber heads.
Re: Building low compression 440 (first post) [Re: Benson] #2211309
12/10/16 04:21 PM
12/10/16 04:21 PM
MONTANA
Benson Offline OP
Benson  Offline OP
MONTANA
Thanks for all the input everyone. I'm looking to stay away from the machine shop in this one. The link that kowalski440 posted contains an interesting buildup, sort of what I'm going for. To summarize the article, they used an m1 single plane intake, headers, 850 cfm carbs, 516 heads. Made alot power surprisingly. I'm going to run a dual plane intake, a decent carb (850 seems a little much, not sure if my 440 will run that carb without being super rich), and either a .509 purple cam or the .484 lift can. A good port job on the heads as well to insure good flow (If a set of 915# casting come up, I will snag em, but otherwise it's the 452# or 250# heads I have.) And a set of headers as well.
Re: Building low compression 440 (first post) [Re: Benson] #2211318
12/10/16 04:33 PM
12/10/16 04:33 PM
Central NC
gch Offline
gch  Offline
Central NC
Have your heads milled to increase compression a bit.It can only help.
I have a 75 Newport with a stock rebuilt 440.Runs fine.Maybe I will get off my butt and put my C body 1 3/4 Hooker headers on there as well as the Performer intake and 750 vacuum secondary on the shelf.Probably have a small cam I can throw in there as well.With the 11" converter(on the shelf) and 3.21 limited slip in the 9.25 I can be blues brothers fast.
Re: Building low compression 440 (first post) [Re: Benson] #2211320
12/10/16 04:35 PM
12/10/16 04:35 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I understand that we're all working w/in a budget, but keep in mind that not doing the proper machining where required isn't a good idea. There's "budget"... and there is "short sighted". Just my twocents , naturally.
Re: Building low compression 440 (first post) [Re: Benson] #2211323
12/10/16 04:36 PM
12/10/16 04:36 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Remember you have low compression, (I assume) a stock converter, 3.55's and a 5000 lb vehicle. I do not think you'd be happy with the .509. Even the .484 may be too much... twocents
Re: Building low compression 440 (first post) [Re: DrCharles] #2211334
12/10/16 04:55 PM
12/10/16 04:55 PM
As said I would (highly) reconsider your cam choices. You have a 5000 LB vehicle and you need low RPM torque. Your actual SCR is in the 7's likely. You are already torn down to the bare block & I would rebore & get it in the 9's and you might be able to get some pistons close to what yours are now so no rebalancing needed & HF has a gram scale for that regularly on sale for $9.99 & it was just as accurate as my buddys' high dollar one. or even drop in some std ones if on a real tight budget. Some file fit plasma moly rings in an overhaul kit (bearings/gaskets etc). (you can file fit em with a point file).
Re: Building low compression 440 (first post) [Re: DrCharles] #2211336
12/10/16 04:57 PM
12/10/16 04:57 PM
Harm City Md.
Dan Halen Offline
Dan Halen  Offline
Harm City Md.
I agree, either of these cams will make a pig out of your truck, way too much duration for the application.
Re: Building low compression 440 (first post) [Re: Benson] #2211340
12/10/16 05:02 PM
12/10/16 05:02 PM
missouri
ragin sonny Offline
ragin sonny  Offline
missouri
I agree I had a 84 4x4. Never could get a big enough cam in my hot rod so I put a purple shaft 484 in my 360 big mistake it sounded great it was a pig
Re: Building low compression 440 (first post) [Re: Benson] #2211343
12/10/16 05:17 PM
12/10/16 05:17 PM
So. Burlington, Vt.
So. Burlington, Vt.
For that application, I think you should be looking at something like a Comp 268h or similar.
Re: Building low compression 440 (first post) [Re: fast68plymouth] #2211354
12/10/16 05:45 PM
12/10/16 05:45 PM
iagree up
OP, I hate Mopar grind cams, especially the famous .484 down They are a old design in the mid 1970s and now outdated scope
Step into the 2000s and buy yourself a better cam up twocents
All OEM non Max wedge BB Mopars are starved for air and fuel through the stock heads shruggy
IHTHs thumbs
Re: Building low compression 440 (first post) [Re: Benson] #2211365
12/10/16 06:02 PM
12/10/16 06:02 PM
MONTANA
Benson Offline OP
Benson  Offline OP
MONTANA
What about something with 250-270 duration or slightly less, or will this be too much? How much lift? I'm settled on a dual plane intake, probably eddy performer rpm and a 750 Holley carb. I have also considered putting 4:10 gears in to help as well. Am currently running 31 inch tires. Also, there is no machining to be done here. I doubt my particular engine has even 30,000 miles. The truck right now has a warmed over 318 (eddy 600 cfm carb, performer intake and cam, ported heads, headers) that is crippled by low compression as it sits. Makes no torque in all reality, but pulls good above 3000 rpm. Would like to keep my stock converter, or go with a slightly better one. Will it be a night and day difference from the 318?
